dash gauges not working!!!!!!!!!!!!! - Diesel Forum - TheDieselStop.com
Old 08-21-2006, 10:56 PM   #1 (permalink)
my buddy has a 2004 6.oh no and the dash gauges are not working, no tach,water temp,oil press., speedo, alternator???? the stealership told me that the pcm shuts down some stuff if the charging system is not working properly(alternator-batteries) batt."s show low w/ a system check and have not checked the alternator for him yet. is this a problem for the 6.0!!! all the fuses were ok and the relays unles you guys have some in put. help me out cause this guy hooking me up on a deer lease and i'm trying to hook m up.
2000 excursion superchips progamer,(ole ladies ride) no fuel milage increase but the power is there.
2000 f250 4x4,hypertech tuner ,no kitty,4in exhaust turbo back , air raid filter
97 f350 psd, c/c, 4x4,3.55ls, 285/75 goodyear MT/R's
shimmed w/ calif. kit, 10k mod, ported snorkel,hypermax downpipe,ps2000 propane
45hp superchip,pcm code TDE1, TEXAS TROPHY HUNTERS decal!!
looking for hunting opportunities in the north mississippi area or s/w tennessee, deer and hogs , let the littles ones walk
missplaced texan is offline
Old 08-22-2006, 07:54 AM   #2 (permalink)
Re: dash gauges not working!!!!!!!!!!!!!
[img]/ubbthreads/images/graemlins/smokin.gif[/img]make sure the alt. is putting out for one, & have the batt's checked. if they test ok after charging them then remove the batt. posts & leave off for about a min. or two, then reinstall them. now it will have to have a kamm reset after this, but it can only be done by ford w/ the testing equipment. then they have to perform a vgt learn procedure. this will recalibrate the icm. it will go through a gauge sweep to reset itself. if this ever happens to you, gauges sweeping in the future then you know that it has a low batt. concern. one bad batt. can cause all kinds of problems. not cranking fast enough will also keeping it from starting, cause the high pressure pump has to be rotating fast enough to create enough pressure to lite off. [img]/ubbthreads/images/graemlins/smile.gif[/img]
certified ford dealer 7.3L,6.0L & 6.4L diesel tech & foreman
dvtech is offline
