Dealer says 30K trans service requires flush w/ no filter?? - Diesel Forum - TheDieselStop.com
Old 02-06-2007, 02:34 PM   #1 (permalink)
My '04 has 25K, and I was going to do my trans service a little early, but when I called the dealer and spoke to the SA, he said the required trans service consists of a fluid flush without repl. the external filter, which is contrary to the owners manual.
I know the topic of torqueshift trans services has been covered here many times, and there have been many different answers.
My question is has this maintenance requirement been changed, or is he blowing smoke up my a--?
He quoted me a price of $130, but he insists the flush cleans the filter. When I asked how much extra for the filter, he continued to insist it is not needed.
The same SA also told me they don't recommend replacing the air filter until 60K.
I don't have a good feeling about this whole thing and I am leary that I might even get my truck back with regular ATF in it.
Am I being paranoid?
I don't mind paying more for a flush and filter, but I want it done right.
Your input will be appreciated.
'04 F250 Lariat, Oxford White, CC, 6.0 PSD, Torqueshift, 4x4, ESOF, FX4, 3.73 LS, Line X
jrc702 is offline
Old 02-06-2007, 02:50 PM   #2 (permalink)
Re: Dealer says 30K trans service requires flush w/ no filter??
flush is not required, it pays for the flush machine and adds profit and will not clean the inside filter as it is not a back flush through that filter.. Dropping pan and servicing the inside filter is usually optional but is not a bad idea the first time prior to warranty expiration to see if all is OK inside. Definitely change the external as it catches the fine stuff and may be obstructed.
2006 F450 CC Hauler bed 4x2 6.0 L Pstroke/Torqshift, Lariat, 4.30 r/a.
2006 F350 Lariat CC Dually 4X2, 6.0 TQShift 4.10 LS, STOCK.
36 foot double tandem axle flatbed trailer.
36 foot Sooner 6 horse large dressing/ mid tack.
15 horses with good balance from being hauled behind a P'stroke.
jimmy is offline
Old 02-06-2007, 03:00 PM   #3 (permalink)
AllOutFirefighter13's Avatar
<font color="blue"> Any SA that would go against what's in the owner's manual raises my BS flag. Get yourself 10 quarts of Mercon SP, an external filter, and an internal one, if you want to replace it. It's just like any other tranny change, and this tranny even has a drain plug. Even the gasket is re-useable. I did mine and it took between 9-10 quarts; most say around 8. To get the housing off the external filter, you can try using a ratchet, but you might have to switch to an impact wrench. Good luck!
Later,
On edit, I unrolled my external filter when I was through and for those that haven't, you should. I could actually see the metal flakes stuck to the material. Pretty cool! </font>
Joey
* '04 F250 XCab LWB 4X4 w/ FX4 *
* TorqShift *
* Manual 4WD *
* Carpet Delete *
* No. 2 ONLY *
* High-Idle Mod *
* Fumoto Valve *
AllOutFirefighter13 is offline
Old 02-06-2007, 03:58 PM   #4 (permalink)
I just had mine done at our local lube center. I laid on the floor in the bay and watched them. they replaced both filters, used the flush machine, used the same gasket, cleaned and wiped the pan and cleaned the magnet. It just had a very little grey sludge on it. Replaced with SP all for $125. Your service advisor sounds shady to me? Good luck with your project.
2003 6.0 crew cab
2005 escape
2006 Palomino Puma 30' fifth wheel
2 labs
1 hot wife
cgsharp74 is offline
Old 02-06-2007, 04:08 PM   #5 (permalink)
I am supprised that the local lube place had mercon sp. Hope they start carrying it in my area. Your price sounds better than what Ford charges. Only question I have is does the trans flush machine heat the trans fluid because the torqueshift has a thermostat that needs heated oil inorder to flush everything out of the trans.
2003 F250 SC SB 6.0 PSD 4X4 Lariat toreador Red/Arizona Beige, torqshift, 20K miles, engine build date: 1/8/03, truck build date: 1/29/03, all flashes except buzz & inductive, Leer cap, Warn front receiver, Spray-in bedliner, A pilar EGT, Boost & Trans Temp Gauges, high idle mod, CB, 250W oil pan heater with Marinco plug, everything else stock. 4 injectors replaced @ 4500 miles;2 VGT solenoids replaced @ 4500 & 8400 miles; EGR,EBP & MAP replaced @ 12800 miles; 2 turbos replaced @ 13700 & 15400 miles.
red03f250 is offline
Old 02-06-2007, 05:26 PM   #6 (permalink)
Your SA sucks. Show him in the owners manual and then have him explain why he doesn't do it.
SA like him give the good ones a black eye.
For the 8 bucks for the filter I change mine every oil change 7.5k and the flush every 30k.
O5 F-250 SuperDuty CC SWR 4x4 Lariat
8' box 6.0 PSD Tow Comand new 04/05
2001 40' Alfa Toyhouse
Pulls better stock than my 01 with a programmer
New engine at 42k . Hope my luck with this 6.0 is changed .
firesoutmatt is offline
Old 02-06-2007, 05:30 PM   #7 (permalink)
I hope you actually saw the bottles of Mercron SP go in the machine.
Was it motorcraft fluid ??
You would be the first I've heard that a quick lube place even had the SP.
$125.00 for a flush and both filters . They didn't charge enough or used Mercron V . 18 qrts for a flush at say 5 bucks a qrt = $90.00 for the fluid alone.
Old 02-06-2007, 05:32 PM   #8 (permalink)
Don't tell my cattle I have leather seats!!!!!!!!!! [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
2008 F250, Lariat, RED, V10, Loaded Ordered 12/16/07 took delivery 2/16/07
geezing is offline
Old 02-06-2007, 06:10 PM   #9 (permalink)
1SickHarley's Avatar
My Photos: (15)
Be lucky you don't have a Mag Hytec tranny pan and have to do 25 quarts.
NEW TRUCK.... 2007 Jeep Grand Cherokee SRT8 Black, Magnaflow Exhaust, Volant Cold Air Intake, and a nice system....
GO GATORS!!! 2007 National Champs Baby!! Ummm... Football AND Basketball
04 Harley Edition Solid Black, 8" Fabtech shocks and hangers and ladder bars, Superlift Springs, 38x15.50x20 Toyo Open Country M/T's, Weld 20x12 Cheyanne 8 rims, Fabtech Ladder Bars, AFE Intake, straight exhaust, SCT with Extreme Street from Eric at Innovative, Full SunCoast setup, SPEARCO INTERCOOLER(Thanks BBunting), Mag Hytec Tranny Pan, GReddy Turbo Timer,Alpine IVAD300 Flip out DVD player, Alpine 5 channel amp, JL 6x8 Seperates, JL Audio 12W7 Sub., JL Audio 500.1 amp., ISSPRO triple guages, sunroof, diff covers powder coated comp. orange, 03 Turbo, and oh yeah... 2005 Harley Edition Headlights.
My truck pics... http://community.webshots.com/user/1SickHarley
1SickHarley is offline
Old 02-06-2007, 08:27 PM   #10 (permalink)
I think he told me all I need to know and I won't be having the trans serviced at that dealer.
I'll call a couple of the others in town and if I don't like what I hear, I'll change the filter myself and just do a drain and re-fill.
I'm sure as hell not going to try to coax them into doing it right, just to pay for a filter that will end up in someone's tool box and get regular ATF in my trans.
I would like to have it flushed to get all the fluid and don't mind paying for it, but more importantly, I just want it done right.
Hopefully, I'll have better luck at one of the others.
jrc702 is offline
Old 02-07-2007, 01:30 AM   #11 (permalink)
F350Lariat's Avatar
A flush definitely will not clean the filter. The external filter on the transmission is similiar to a tightly wound roll of toilet paper with a cardboard center tube.
Be wary, I could not locate a single quick change or transmission shop that carried Mercon SP fluid. They had to purchase it directly from the dealer (Motorcraft SP) and mark it up.
I changed mine in 20 minutes (drain, filter, and refill) in 20 minutes. 10 minutes was waiting for the small trickle to stop. It took 8 quarts and costs $68 with a extra quart (9th) of fluid leftover.
2004 Ford F350 Crew Cab
4WD Lariat 6.0L PSD Torqshift SRW
Med Wedgewood Blue / Arizona Beige
Tuff Country 1.5" Leveling Kit ... Hardcover Tonneau
Pro-Flap Mud Guards ... Toyo M55 LT285/75R16 Range E
GOS Racing Headlight Harness with Silverstar bulbs
Factory Ordered and Delivered: Feb 7, 2004.
<movieshow2003 at yahoo.com>
F350Lariat is offline
Old 02-07-2007, 06:23 AM   #12 (permalink)
I'm not ready for the first transmision fluid change yet with only 15,000 miles but I do my own maintenance. Never done the transmission before. Is there a how to list anywhere. From what I read on this site it doesn't sound to difficult, am I wrong.
06' F250 XLT FX4 6.0, CC short bed, Fumoto valve, uplifter switches, Tow Command, stock.
pwrstroke34 is offline
Old 02-07-2007, 08:33 AM   #13 (permalink)
A drain and refill is not a equavalent to a true "flush" --take the time and spend the money to get it done right --or do it yourself --the procedure for the do it yourself has been posted before! At thirty K intervals a tranny flush only amounts to one half cent per mile in operating costs--
Stock -- 2004 F350, Oxford White, 4WD, Torqshift Auto, Short Bed, Crewcab,6.0 PSD, Dual Alts., TT Mirrors, Lariat,Parchment Int.,Kenwood Stero w/ XM Satellite Radio, Custom full length running boards, Handy Tool/Fuel, Ultimat, Banks Gauges & A-Pillar, ,Fumoto Valve with Nipple [Ham (KC7QJZ), ---- pullin a 30' Starwood 5er at 10.5K (and often with a 2.5K tandem trailer with GYRO or ATV's ,OR ,a 2006 Jeep Rubicon Unlimited.
Mike Schallmann is offline
Old 02-07-2007, 06:37 PM   #14 (permalink)
lutzgater's Avatar
Wow, those are some good prices on a flush. In the Tampabay area, the cheapest 'Dealer' price for a flush only, was $175. Add the external filter and you are north of $210.
Man, $120, something is wrong with that picture.
Thanks in advance,
Bruce
2004 F250 6.0L SuperDuty 2WD Crew Cab Long Bed
lutzgater is offline
Old 02-07-2007, 09:22 PM   #15 (permalink)
F350Lariat's Avatar
I acknowledge that a drain and refill is not equivalent to a true flush, but the scheduled maintenance does not require a flush only a drain and refill. A drain and refill meets the requirement for scheduled service per the owner's manual. Your option satisfies the individual perception that more must be better. I do not necessarily disagree with that argument since I use synthetic oil, certainly not required but I convinced myself that it performs better.
If a flush is desired then go for it, but my calculated price for a flush and external filter if I do it myself is a little over $130 dollars. The number is my costs and does not include labor. As I stated in a similiar post, I would seriously question what type of fluid is being put in the tranny for a $130 flush. My guess, speculation and not fact, is that the fluid being used is Mercon, Mercon V, or some offbrand equivalent. The prices for Mercon SP have not dropped low enough for a company to make a profit at $130 with a full flush.
