Death Valley - Last Weekend - Diesel Forum - TheDieselStop.com
Old 07-22-2005, 06:00 PM   #1 (permalink)
Was in Death Valley last weekend. Temps were in the high 120s and were 120 degrees F at 7:30 at night. Truck, as seen below, ran perfectly with no overheating problems even though the air conditioner was on high all the time. The temp gauge did not even move.
Was not towing that weekend, but was carrying a couple hundred pounds of junk I usually carry around. Only mods on truck are EGT gauge, 4 inch exhaust and Mag-hytec diff cover, along with the 35 inch Toyo Mud Terrains.
My 05 is as trustworthy as my 01. Truck has 12,000 miles on it now. Ron
06 F350 SC LB 4X4 FX4 Lariet 6.0 Torqshift, True Blue Clearcoat, tow command system. Toyo Mud-Terrain tires size 35/12.50//18 on stock wheels, Mag-Hytec rear differential cover, Bilstein shocks, and Alpine 9833 head unit, Kenwood Excellon speakers, and an Alpine V12 4 channel amp with 80 watts per channel RMS.
ronk54 is offline
Old 07-22-2005, 10:23 PM   #2 (permalink)
Re: Death Valley - Last Weekend
I was on 395 west of there last weekend also. Forecast was for 128 one day(don't remember which day). If I remember right the N. America high temp was 135 in Death Valley. I only go down there in the winter!
Towns on the CA side were setting records for most days in a row over 100.
It was only in the high 80s around te Mono Craters.
Phill
2005 F-350 Supercab, 6.0, Auto
2003 30U Nash
Phill Vanderschaegen is offline
Old 07-22-2005, 10:41 PM   #3 (permalink)
I tell ya, when these trucks run properly they simply rock.
About a month ago I went to the Hill Country (central TX) to visit some vineyards. After buying a few cases of some good stuff we decided to stop in Llano for some good BBQ. That meant leaving 4 cases of good wine in the hot truck.
Not to worry. Combine a 6.0L with an AIC and you have perfectly chilled wine.
A friend of mine asked, "Won't your truck overheat when you let it run like that!?" [Me] "Nah, not unless you set it on fire." [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
CMOS
2004 Ranger SCAB
Shopping for 99-2002 7.3 CREW
CMOS is offline
Old 07-23-2005, 12:13 AM   #4 (permalink)
dfb
I don't know if the newer trucks are the same., But my 02 had "IDIOT GUAGES!"... They always stayed in the middle... Temp, Oil and Volts....When loaded and climbing a hill the Temp guage should rise slightly, when warmed up the oil pressure should fall at idle...However, on my 02 They did not move!!! [img]/ubbthreads/images/graemlins/shrug.gif[/img]
dfb is offline
Old 07-23-2005, 01:13 AM   #5 (permalink)
Yep. Stock guages are junk. [img]/ubbthreads/images/graemlins/vomit.gif[/img] [img]/ubbthreads/images/graemlins/vomit.gif[/img]
June 2004 F350 6.0L, 4 Door Supercab XLT SRwd Short Bed, Automatic, Deluxe Aluminum wheels, Class V Trailer hitch receiver, 3.73 standard rear end. Line-X bed liner, 5th wheel hitch, Brakesmart trailer brake control and powerlock starter interlock.
Larryect is offline
Old 07-24-2005, 07:22 AM   #6 (permalink)
Was in Death Valley last weekend...Temps were in the high 120s...Temp gauge did not even move...
Ford and other manufacturers have added a dampening feature to all their gauges. This keeps them from moving very much. In the case of the temp gauge, you will notice that it rises to exactly the same place and stays there all the time. This is not a very useful gauge, but deceives the public into thinking exactly as you believe. I believe the purpose of this is to keep the public from complaining about a moving temperature gauge.
I installed a VDO coolant temp gauge that actually indicates the temp of the coolant. And let me tell you, that gauge moves a lot. It is not uncommon to see 220 to 240 degrees under hot and heavy load conditions.
The manufacturers have done many a disservice by installing this kind of a gauge. I think it would be better and far more useful to install a functional temp gauge and add an explanation in the ownwers manual on how to read to a functional temp gauge.
George Hilton. '01 PSD 6 spd, Hensley Arrow, Airstream. Life is good.
georgehilton is offline
Old 07-24-2005, 08:36 AM   #7 (permalink)
You said it george!!!They won't do it tho cause it makes sense.Plus think how cheap that gauge is for ford to purchase.Anything that inaccurate has got to be cheap.
2005 f250 cc Lb 2wd PSD
rocky7184 is offline
Old 07-24-2005, 09:04 AM   #8 (permalink)
Agreed.
I would HIGHLY recommend that everyone with a Power Stroke install, at a minimum, a dual gauge set: Pyrometer and Tranny temp.
CMOS
2004 Ranger SCAB
CMOS is offline
Old 07-24-2005, 04:31 PM   #9 (permalink)
Forget the gauge. The truck ran in 120-130 degree heat and did not overheat - period.
Also, my 05 temp gauge has moved slightly when towing a heavy load. I believe too much is being made of this temp gauge issue. Believe me you will know when your truck is overheating - it will lose some power and eventually puke coolant from pressure cap or overflow.
My truck ran in these temps 2 complete days perfectly - never skipped a beat once in the 2 days. Never puked a drop and EGTs in very safe range even when climbing extended grades in those temps.
ronk54 is offline
Old 07-25-2005, 11:39 AM   #10 (permalink)
Ford Temp guages aren't that bad. They won't tell you if it's going up or down a few degrees, but they tell you if you're too hot and tell you when you're warmed up. That's what's important.
On the other hand, the oil pressure guage on Fords is just an on off switch. If you have enough pressure, it shows in the normal range. If you don't, it says low. If the truck is running fine, a stock guage is enough. If you're having problems though, it's an easy insurance policy.
EGT - that's another story...
2005 F250 6.0L CC FX4 King Ranch Dk Copper Color Matched LineX and a Retrax cover
gecko2424 is offline
Old 07-25-2005, 11:55 AM   #11 (permalink)
My Photos: (5)
The problem is that the vast majority of owners are not TDS participants, not even really enthusiasts, and just want a transportation appliance. And if the temp gauge moves, or goes to a number they don't like (nevermind that it's a perfectly okay number), they'll bring in a perfectly fine truck with no real problems to be checked out for overheating. Which drives up warranty costs. Which are passed on to everyone who buys a new vehicle.
For the folks here, who are enthusiasts, yeah, it would be better to have a proper gauge. But we, tragically, are a very small minority of the total customer base. And catering to us would cost the OEMs far more than they'd make off us. Luckily, the aftermarket has what we need.
AutoJim
Former Cooling Guy
'99.5 F350 Lariat CC SRW 4x2, 7.3L 4R100
'99 Mustang Cobra, SCCA Solo2 E Street Prepared
'97 Dodge Neon, SCCA ITA/STU/EP Club Racing
Now I do subsea ROV tooling.
AutoJim is offline
Old 07-25-2005, 09:04 PM   #12 (permalink)
On my 95 Impala SS I did a mod to the temp gauge as it was an idiot gauge also. There was a resistor in line that when removed allowed the gauge to read real time. Any chance of it being that easy on these trucks?
04 Excursion E/B 4x4
05 F350 Lariat 4x4 CC Dually
Texcursion is offline
Old 07-26-2005, 12:28 AM   #13 (permalink)
If you are to the point of losing power, damage has already occurred. [img]/ubbthreads/images/graemlins/vomit.gif[/img] The whole point of an accurate temperature gauge is so the operator can take a “pro-active approach” [img]/ubbthreads/images/graemlins/warmsmile.gif[/img] and take the appropriate action. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
2008 F350 Lariat 4x4 CC V10- Work Truck
2007 F250SD XLT 4x4 CC 6.0L Auto- Work Truck
2005 F350SD Lariat 4x4 CC 6.0L 6SPD Dually Stock
2005 F350SD 6.0L M.I.A buy back
2004 F350SD XLT 4x4 CC 6.0L Auto- *Sold* POS
2002 F250SD XLT 4x4 SC 5.4L Auto- *Sold*
1991 F150 XLT 5.8L Auto *Sold*
bakersfield is offline
Old 07-26-2005, 12:38 AM   #14 (permalink)
Hun. By the time my gauge went hot, both heads were blown, puked out all the coolant, and permanent damage was done. I bet FMC is glad they saved $20 on a real temperature gauge, and spent $ 9,300 repairing the truck.
Old 07-26-2005, 02:09 AM   #15 (permalink)
I am surprised someone else (more knowledgeable) has not jumped in. My understanding is that the gauges are not defective or necessarily cheap. They are computer outputs, telling you what Ford thinks you need to know, and therefore not telling the whole story.
I, for one, would like to know when temperatures and such are gradually rising so I can take proactive measures.
I have the X-Monitor. I have seen my Trans temp read "normal" when the actual temperature input to the computer has moved from 100 - 170 degrees. I have not added a water temp gauge yet. But, I will.
The oil Pressure gauge is nothing more than an idiot light. If you have more than something like 7 lbs pressure it reads normal. Ford would be more honest if they just put in idiot lights instead of selling idiot lights that look like gauges.
Larryect is offline
