Death wobble still - Page 2 - Diesel Forum - TheDieselStop.com
Old 08-16-2009, 01:07 PM   #16 (permalink)
Hey,
I watched a episode on trucks about that one, you need to get a drop pitman arm if you havn't already done it. and somthing else. search trucks on the internet.
hope that helps
03 F150 XTR 5.4l
06 F350 King Ranch PSD
sean453 is offline
Old 08-16-2009, 06:02 PM   #17 (permalink)
All thats cool but
I have built alot of big trucks over the years and have run across this many times. Your drag link from your pitman arm must be on the same angle as your track bar ( the bar connecting the axle to the frame) this is imperitive!.
An you must have the caster angle:...........LH...................RH.......... ...... ......Total/Split
Camber 0.62 +/-0.75.... 0.62 +/- 0.75........0.0 +/- 0.75
Caster 3.8 +/- 1.2........3.8 +/- 1.2...........0.0 +/- 0.75
Toe .................................................. ..0.1 +/- 0.25
Big tires require more - caster than stock I have found 4 3/4- 5 degrees to be sufficient. Providing all your ball joints and front end components are in good working order.
2004 F-350 4x4 PSD dually, Edge Platinum, Down pipe and no meow, Coolant filter, 4 inch lift, EGR Cooler?, 315/75/R16's
1996 F-250 4x4 monobeam conversion, custom turbo mod, Superchips, Rosewood modified injectors, Can't find kitty cat, Muffy ran away, Banks turbo housing, 4.10's, 35/12.5/16.5 BFG's, 7 inch lift, Custom trans. mods, Triple clutch converter.
FK000@aol.com is offline
Old 08-16-2009, 06:14 PM   #18 (permalink)
oh yea
One more thing and its pretty simple remove your shocks and check the hydro dampening push in the shock and pull it down when you push it in there should be alot of resistance if not change em.
Old 08-17-2009, 07:43 PM   #19 (permalink)
thanks for the input, pretty knowledgeable friend coming over to help me check the things you described.
2006 BLACK FORD F-350 CREW CAB LONG BED, 8inch Bds lift, 38/15.50 toyo mts on weld cheyenne 8s. 4inch magnaflow exhaust
1996 Mustang Gt, (Not Stock)
2003 Yamaha Raptor
crewstang is offline
Old 09-13-2009, 12:32 PM   #20 (permalink)
Found my trac bar to be loose, tightned up and no death wobble now. Still a little bit of vibration around 50mph in a curve, but nothing else. Probably needs tightend up a lil more. plus a F.E.A.
2005 F250 XL, Powerstroke, 6 Speed Manual, 4X4, Quadzilla Xzillaraider module (30,60,120hp),T.A.G. (Turbo Air Guide), Tinted Windows, Pioneer Stereo System, Upgraded to 06 grille, headlights, Superlift 4inch Suspension Lift. Line-X Bedliner, Front/Rear bumper/Brush Guard line-x coated, Smoked Clearance Lenses, Chrome Door/Tailgate Handle Covers, BFG A/T 35's on 17x9 Pacer's.
bbrrcrw is offline
Old 09-13-2009, 05:36 PM   #21 (permalink)
My 05 had the wobble. The dealer tried its best to fix it but I ended up trading . My buddy has an 05 with 100,000 miles on it & has never had this problem. This tells me its fixable. Replacing the tires seemed to help more than anything. Do you have a buddy that would let you use his front tires for a test?
2006 2500 4x4 deisel auto
banyon is offline
