Diesel Additive - Diesel Forum - TheDieselStop.com
Old 11-02-2007, 08:20 PM   #1 (permalink)
Diesel Additive
I went to a dealer in the Orlando FL area and asked for a bottle of fuel additive.
I was told that they didn't stock it anymore because it cannot be used in the 6.4 engine.
Has anyone else heard of this?
sickofford is offline
Old 11-02-2007, 08:52 PM   #2 (permalink)
Re: Diesel Additive
If you are talking about the Ford/Motorcraft additive the dealer is wrong. The additives were refomulated and can be used in both the 6.0L and 6.4L. Check out the link below...
http://www.fcsdchemicalsandlubricants.co...ance%20Product s
'04 F-250 Harley-Davidson 6.0L CC SB
PowerStrokeHD is offline
Old 11-02-2007, 09:35 PM   #3 (permalink)
downsmi's Avatar
Re: Diesel Additive
That's a good topic. I live in Northern Ohio and was once told that in the winter months diesel around here has more sulfer in it. Should I add some type of gas treatment like redline or motorcraft to each fueling?
2005 CC Dually LB 6.0 PSD,
Stock
142k, FX4, IH HCFM, Fumoto, 5W40 Syn
downsmi is offline
Old 11-02-2007, 09:48 PM   #4 (permalink)
Re: Diesel Additive
I don't know how or why it would have more Sulfur in it, but I do use an additive for its anti-gel properties and water removal ability. I happen to use Stanadyne Performance Formula, which was recommended by Ford until they started marketing their own.
2003 KR F-250 4X4 CC SWB, 6.0, 5 Speed Auto, 3.73 Axle, no Limited slip. Rhino bedliner, Unicover bed cover.
Built on February 19, '03
#2 93 F-150 XLT, 5 Liter, Auto, 4X4, X Cab. 251,000 miles. Uses no oil between changes.
montanafan is offline
Old 11-02-2007, 10:20 PM   #5 (permalink)
downsmi's Avatar
Re: Diesel Additive
Do you add it every fueling
Stock
downsmi is offline
Old 11-03-2007, 09:51 AM   #6 (permalink)
Re: Diesel Additive
I do. I carry a couple of "lab" 8 oz plastic bottles with me. I try to add it at about 4 oz. per 20 gallons. I don't even know if it does anything, but I have never had any gelling or water issues. Beings how I add it almost all the time, I don't know how to tell if there is any difference without it. It may be snake oil, but it makes ME feel good, and as far as I am concerned, that's what it's all about.
Supposedly, it works all kinds of miracles with Cetane, lubricity, and a host of other things. I buy it at a local distributor that buys it in 50 gallon barrels, then re-fills my original Stanadyne jug. It runs a LOT cheaper that way. Stanadyne's web site has a way to look up your local authorized dealers.
Old 11-03-2007, 04:13 PM   #7 (permalink)
My Photos: (6)
Re: Diesel Additive
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: sickofford</div><div class="ubbcode-body">I went to a dealer in the Orlando FL area and asked for a bottle of fuel additive.
Has anyone else heard of this? </div></div>
I would find a new dealer because they are blowing smoke where the sun doesn't shine. I buy mine from http://www.powerstrokeshop.com and it says it is for all diesel and ULSD compliant.
05 F250 SD XLT Reg cab 4x4 Arizona Beige 6.0L PSD, AT, Advanced Security Group, ESOF, Fog Lights, Stabilizer Package, Tow Command System, Upfitter Switches, Aluminum Wheels, Cab Steps & Super Liner bedliner,Fumoto Valve, Air Lift Air Springs & Smart Air.
stewcon is offline
Old 11-03-2007, 05:02 PM   #8 (permalink)
Re: Diesel Additive
I don't think it's snake oil at all. I'll go through periods (when I have some actual extra money) and use either Stanadyne or the Diesel Power from wallyworld.
My engine is definitely quieter using both of the products, but I actually get a little mileage improvement with the Stanadyne. I like it because it seems to quiet down and just run smoother overall.
'03 250 CC SRW SWB, 4x4, XLT, 6.0 T/S, MBRP Turboback, Custom SCT, DiPricol Pyrometer, Adj Pedals, Reverse Sensors, ARE Z-Series Top, Sprayed bedliner, Remote Start/Keyless Entry, Edge Mini-spring pack, Bilsteins, 285's, Sirius Radio, Dark Highland Green
HBO1 is offline
Old 11-04-2007, 05:52 AM   #9 (permalink)
Re: Diesel Additive
I used Stanadyne Performance formula for a year or so, but I switched to Power Service DK after that because it's a little cheaper and easier to find where I'm at. Can't really tell much difference between them, performance wise, but the dang Power Service bottle always spills down the side when pouring. Getting tired of that so I think I'm going to try Ford's product. Anybody know how much cetane boost Ford's stuff provides?
Anyone using RBP High Performance Additive? If so, how do you like it?
2004 F-250 Lariat CC, Short Bed, 4x4, 6.0L, TorqShift, FX4, Metallic Green/Arizona Beige, Medium Parchment Leather, Fumoto, B&W Turnover, A.R.E. LSX Tonneau, Built 4/01/04
MoeB is offline
Old 11-04-2007, 03:22 PM   #10 (permalink)
Re: Diesel Additive
Stanadyne all the time...(and a little Marvel Mystery Oil)
2005 F-350 LARIAT 6.0 PSD SRW AUTO FX4 (removed) CC SB White, International emblems, Tow Command, Upfitters, Line-X, ScanGauge, Pioneer Appradio, Banks Technicooler and intake w/Zoodad, Dieselsite coolant filter (w/RMI-25), braided 4x4 lines, Mag-Hytec trans pan & diff covers, Fumoto oil valve (Motorcraft 15W-40), Knurled HFCM drain plug, Britebox, EZ-Down tailgate, BedStep, MBRP 5" cat-back (6" tip), Putnam class V hitch with 1upUSA bike rack, TransferFlow 30 gal toolbox tank + 46 gal midship tank = 76 gals total with Stanadyne Performance additive and FPPF cetane improver... the rest is all stock you nig-nogs. 64k miles, 1600+ hours.
Waiting for "BigTurbo" to help me install: Dieselsite Trans filter kit.
ljr869 is offline
Old 11-04-2007, 09:34 PM   #11 (permalink)
Re: Diesel Additive
I've posted this before and important that you all see this lubricity test of several additives. Those that are popular don't test so well.
Diesel additives lubricity test
2006, F-350, 6.0, 4x4, Lariat, Crew Cab, Long Bed
Leer model 180 bed cap
MagnaFlow 4" turbo back muffler & exhaust system
Firestone #2400 Ride-Rite rear air bags
Isspro four gauge pillar set
HID Bi-Xenon headlights
Accufab intake elbow
DFuser coolant filter
Bilsteins all around
HFCM drain plug
Up-idle switch
Fumoto valve
Zoodad
johnfjensen is offline
Old 11-04-2007, 10:54 PM   #12 (permalink)
Re: Diesel Additive
They are partially correct.
Here's a little tidbit of info for you about Motorcraft diesel additives....
There are 3 flavors: (used to be only 2, Red or Blue caps)
PM-17-A ((Red cap) Cetane booster and performance improver for 6.9 7.3 & 6.0 engines (soon to be discontinued)
PM-22-A (Red cap) ULSD compliant Cetane booster and performance improver for 6.4L PSD (backward compatible as well, and will replace the 17-A in the near future)
PM-18-A (Blue cap) Anti Gel and Performance Improver (cold weather additive) ULSD compliant and compatible with all Ford diesels 6.9 - 6.4
LittleBigRig is offline
Old 11-08-2007, 10:49 PM   #13 (permalink)
downsmi's Avatar
Re: Diesel Additive
Thanks for posting that snowgoose. So what are your thoughts? Are you running Opti-Lube?
Stock
downsmi is offline
Old 11-09-2007, 08:25 PM   #14 (permalink)
Re: Diesel Additive
MikeDually
Here's what I posted on another thread:
I was so impressed I added Opti-Lube to my line and web site. I already carry PRI-D (it was not part of the test).
I just made a 2200 mi trip to Oregon and back and best tank mileage was 17.6 (worst was 16.3) using the Opti-Lube Summer blend and PRI-D. We were pushing it and running when possible 85-95 mph. Next trip I will try the XPD blend (the second best in the test).
I have two customers who have stopped using the other additives and are using PRI-D and Opti-Lube at each fill-up. Both of these guys were mixing Diesel Kleen, Stanadyn, Red Line and Marvel Oil and using their concoction at each fill-up.
By the way, the Opti-Lube XPD sale ended 0ct 15.
HFCM drain plug
Up-idle switch
Fumoto valve
Zoodad
Old 11-09-2007, 10:41 PM   #15 (permalink)
Re: Diesel Additive
I run opti-lube summer formula, it's cheap and only takes a few ounces per tank. I was impressed enough w/ the study that I bought the summer, winter and XPD formulas. So far so good.
2006 KingRanch F250 4x4, SCT XCAL3 w/ innovative tunes, Elite Diesel up-pipe and complete EGR Del.., LEER topper, coolant filter, CompuSTAR remote start, Pinnacle turbo-back exhaust, Amsoil or Syn Rotella, Opti-lube fuel additive, Zodad mod, ARP studs, Coolant Circulation lines on the heads, Autometer gauges, EGT, Trans and Boost
mylesdixon is offline
