Diesel Additive - Page 2 - Diesel Forum - TheDieselStop.com
Old 11-15-2007, 02:07 PM   #16 (permalink)
Re: Diesel Additive
Just ordered a gal of OPTI LUBE Summer. They gave me free qt of the XPD to use this winter on a few long trips I plan. Does not get cold enough here in TN for winter blend. The company recommends using 1oz per 10gal for a better lube but would be just fine with 1oz to 20g. Still should be cost effective. I have been using the cheaper PowerService product from Walmart. I wanted a product that would help with the water removal problem I have.
2005 RED F350 6.0 Cab/Cha, 6spd stick,4x4,supercab,4:11LS, DRW, Alum Flat bed, Trailer Brake Control, Nice options, almost all stock, Prodigy Brake controller-backup for the Ford stock unit, Post turbo Temp ISSPO, IEQUUS Water Temp and Oil Press Gauges, Dieselsite water filter, DS-DAHL Fuel Filter, Del May 19, Build dte 2/28/05, pics http://imageevent.com/vmaxept
psdendurance is offline
Old 11-17-2007, 01:26 AM   #17 (permalink)
Re: Diesel Additive
We use Stanadyne in our shop trucks every time we fill up. The bosses 2000 F-350 7.3 has 355,000 miles on it, still has the original injectors, and starts and runs fine. No smoke, or problems in the winter either. I did a little experiment with it on a little 2 cylinder air cooled Ruggerini (Italian made) diesel in a portable pressure washer. It has a 2 gallon fuel tank on it and the cust dropped it off with a crank no start condition. I found the fuel tank to have about a gallon of water and crap in it, and the filter (which had a steel mesh around it) was rusted solid. I cleaned the tank out and installed a new filter, put in 1 gallon of fresh diesel, set the valves and was able to get it running. After about 1 and 1/2 hours or so it was still not running too well, (heavy white fuel smoke, and the front cylinder was not firing all the time). To make a long story short I added enough Stanadyne to treat 15 gallons, and within 20 seconds the engine was running like new. Starts and runs fine now, no smoke at all. I don't normally play mechanic in a bottle, and as usual the customer didn't want to spend any money but I do know it freed the pumps and injectors on that engine. Personally I have always used Powerservice on my own truck.
JR
2003 F-350 SD. 6.0L Powerstroke, Torqueshift, AEM Bruteforce intake / dryflow synthetic filter, MBRP 4" turbo back exhaust w/powertube, TS Performance 5X Downloader (usually at 100hp)
jrrepair1 is offline
Old 11-28-2007, 01:51 AM   #18 (permalink)
Re: Diesel Additive
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Snowgoose</div><div class="ubbcode-body">I've posted this before and important that you all see this lubricity test of several additives. Those that are popular don't test so well.
Diesel additives lubricity test </div></div>
This is very good information, thanks for posting. It is interesting that the best additive according to this test is a little biodiesel, yet Ford does not recommend biodiesel in any of their products. Bummer.
2004 X Ltd 4x4 (10/03 build date) 150k miles.
ARP head bolts / Black onyx head gaskets
EGR & cooler delete, MBRP 4" turbo back.
2000 VW Golf TDI. 300k miles and going strong.
2005 Mustang Convertible. Wife's car.
1965 Mustang GT Convertible. My play car.
Don65Stang is offline
Old 11-28-2007, 11:25 AM   #19 (permalink)
Texrob1's Avatar
Send a message via Yahoo to Texrob1
Re: Diesel Additive
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Don65Stang</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Snowgoose</div><div class="ubbcode-body">I've posted this before and important that you all see this lubricity test of several additives. Those that are popular don't test so well.
This is very good information, thanks for posting. It is interesting that the best additive according to this test is a little biodiesel, yet Ford does not recommend biodiesel in any of their products. Bummer. </div></div>As far as the 6.0L goes, Ford allows you to run B5 & still Keep your warranty intact.
2005 F250 XLT wedgewood blue 4x4 C/C SWB,6.0L PSD, Auto.(Member of 05 STC Failure Club ) 2006 Expedition Eddie Bauer,5.4L (Wife's) NRA Life Member. TSRA Life member.
Texrob1 is offline
Old 11-28-2007, 08:13 PM   #20 (permalink)
Re: Diesel Additive
Diesel Kleen and 2 cycle oil. Best of two worlds. I would of never banked on 2 cycle oil. Better running, Cleaner EGR valve, less soot in tail pipe. Truck loves it. 15k so far on test. 32k
on the clock.
06 Black Lariat Loaded /Auto/CC/SB/ChromePkg/TowCom/ Ordered 5/06/ BGF 325/60/20 on Jesse James 20"/ Harley Emblems.
BLEnt is offline
Old 11-29-2007, 07:58 PM   #21 (permalink)
smurf764's Avatar
Re: Diesel Additive
Has anyone used SeaFoam? A couple guys at work were swearing by it. I read the can and it says its okay for diesels.....
Regards,
Gary
http://www.f150online.com/galleries/....cfm?gnum=2261
2003 F250 6.0L/5 speed Lariat CC SB FX4 (Born 11-19-02)
2001 E150 Conversion 4.6 Triton V8 Class IV hitch
2004 Springdale 286 RLDS
smurf764 is offline
Old 11-30-2007, 02:21 PM   #22 (permalink)
Re: Diesel Additive
been using both the ford anti gel and cetane booster since I bought the truck. Since I use it religously since I bought the truck back in FEB. I can't tell you what its like without it.
but like montanafan says above , it makes me feel like I am giving my fuel system the best chance it can have to keep feeding the diesel better fuel that won't gell in the cold.
go figure.
softtail
2005 f350 Lariat 4x4 dually, loaded, stock intake., 4 inch exhaust, turn over B&W gooseneck hitch,5th wheel B&W conversion attachment.
40 ft. KC toyhauler,
harley 98 softtailcustom
chopped, 18 degree rake useing Ame kit. [img]/ubbthreads/images/graemlins/cool.gif[/img]
Softtail is offline
Old 11-30-2007, 08:10 PM   #23 (permalink)
Re: Diesel Additive
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: smurf764</div><div class="ubbcode-body">Has anyone used SeaFoam? A couple guys at work were swearing by it. I read the can and it says its okay for diesels..... </div></div>
According the the MSDS for Sea Foam, it has 10-20% IPA, which I believe is isopropyl alcohol. I believe it's bad to put alcohol in these trucks. (someone correct me if I'm wrong)
2004 F-250 Lariat CC, Short Bed, 4x4, 6.0L, TorqShift, FX4, Metallic Green/Arizona Beige, Medium Parchment Leather, Fumoto, B&W Turnover, A.R.E. LSX Tonneau, Built 4/01/04
MoeB is offline
Old 11-30-2007, 08:57 PM   #24 (permalink)
Texrob1's Avatar
Re: Diesel Additive
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: MoeB</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: smurf764</div><div class="ubbcode-body">Has anyone used SeaFoam? A couple guys at work were swearing by it. I read the can and it says its okay for diesels..... </div></div>
According the the MSDS for Sea Foam, it has 10-20% IPA, which I believe is isopropyl alcohol. I believe it's bad to put alcohol in these trucks. (someone correct me if I'm wrong) </div></div>You are correct, IPA is isopropyl alcohol,I wouldn't put anything with alcohol in mine.
Texrob1 is offline
Old 12-01-2007, 11:46 PM   #25 (permalink)
smurf764's Avatar
Re: Diesel Additive
It made me think of the old snake oil ads; it cures anything.
Guess PT Barnum would love me
Regards,
Gary
smurf764 is offline
