Diesel fuel in degas bottle - what next? - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 08-28-2010, 01:29 PM Thread Starter
Just picked up my 06 6.0 F350 DRW from the dealership after replacing the egr cooler and oil cooler. 150,000 miles. The tech advisor stated that he smelled diesel fuel in the degas bottle and said it could be injector cups or a crack in the cylinder head(s). I've driven about 400 miles and I now see a thin layer of fuel in the degas bottle. The truck runs perfect and fuel economy is about 17 on hwy. I need the truck to pull my 3 car hauler this week - going 600 miles empty and coming back with 3 vehicles. Should I make other plans or can I still use the truck. I plan to have the work done in about a month but need to know if I can/should work the truck without causing issues or complications. Thanks for any input/advice!
stonework is offline
post #2 of 11 (permalink) Old 08-28-2010, 01:42 PM
buckshot 2005's Avatar
I would say no.........how much is your trailer full i it going to weigh
F250 CC SB FX4
diesel site coolant filter, Scangauge 2,Rotella ELC coolant,4" MBRP with 5"Single Stack, updated fuel (Blue fuel spring)3c3z-9T517-Ag
STC Fitting, High Pressure oil Stand Pipes,Nitto Trail Grapplers MT, Daystar 2-1/2 leveling kit
buckshot 2005 is offline
post #3 of 11 (permalink) Old 08-28-2010, 01:58 PM Thread Starter
depending on the cars on trailer, I would say about 18k. I will avoid trucks or suvs given the situation. going out of state to buy inventory for my business. lower price and better selection.
post #4 of 11 (permalink) Old 08-28-2010, 02:11 PM
teamroper60's Avatar
I would not drive it if I were you. I don't think fuel is going to do your cooling system any good..
#43
President and Webmaster
teamroper60 is offline
post #5 of 11 (permalink) Old 08-28-2010, 04:50 PM
+2 i with teamroper i would not pull that heavy of a trailer. something else go out it could be worse.
F250 CC SB FX4
post #6 of 11 (permalink) Old 08-28-2010, 04:53 PM Thread Starter
Is this a common situation? What caused the head to crack or cracks to develop in the injector cup(s)? Do you think this happened with egr cooler and overheating?
post #7 of 11 (permalink) Old 08-28-2010, 05:37 PM
Yes, ether your EGT(EXHAUST GAS TEMP) got high or water temp.Did it get hot on you?Well these trucks are know for blowing head gasket the head bolts stretch under high EGT or very high boost on long hard pulls.And yes if your EGR cooler was bad and the truck got hot that most likely was you problem.
F250 CC SB FX4
post #8 of 11 (permalink) Old 08-29-2010, 09:39 PM Thread Starter
Any recommendations on who I should use to do this work - the dealer was out of town 300 miles away where the egr blew. I spoke with Powerstroke Speciaties and I am leaning that way but they are over 5 hours away. My local Ford dealer / service rep seems too busy to discuss the process other than "tearing truck down and letting me know". I don't handle $4,500 estimates too well with my truck in pieces and no other alternative but to let them fix it. Any more repair suggestions are appreciated!!
post #9 of 11 (permalink) Old 08-29-2010, 10:38 PM
m-chan68's Avatar
Fuel contamination into the cooling system means the head(s) are cracked, plain and simple. If you are out of warranty, there's no point "going in" to "find out what needs replaced". I say this with 100% certainty because in order for injector cups to be the cause, would also require the seal on the same injector with the faulty cup to have failed simultaneously, the chances of which are slim to none. If you choose not to have the dealership do the work, at the very least, make sure the shop doing the work is very experienced with having these engines apart. You would be well advised to deal with this sooner than later. $4500 is still way cheaper than buying a new truck.
Ford Diesel/Senior/Master Tech
....who works at a dealership that now employs SOME half decent looking female employees since they overhauled most of the administrative staff
....and STILL hates working on E-Series with 6.0LFord Diesel/Senior/Master Tech
m-chan68 is offline
post #10 of 11 (permalink) Old 08-30-2010, 08:01 AM Thread Starter
Do you think I am looking at more than $4500. Do I have to buy new heads or are there reconditioned heads available at lower price? I'm assuming I should replace both since the truck did get really hot when the egr cooler went out.
post #11 of 11 (permalink) Old 08-30-2010, 09:07 AM
Feedback Score: 2 reviews
I would think the price is going to be a little higher but you should be able to get a set of reconditioned heads if it got really hot or you could just get this The Black Mamba 03-07 6.0L BLACK MAMBA POWERSTROKE CRATE MOTOR 425HP products, buy 03-07 6.0L BLACK MAMBA POWERSTROKE CRATE MOTOR 425HP products from alibaba.com just a thought.
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS with Expandable pyro
AutoMeter Fuel Pressure Gauge 0-100
Sinister Fuel Pressure Adapter
Updated Fuel Reg. Kit 3C3Z-9T517-AG
WOT 58lbs Idle 62-64lbs Just Right
HFCM Water Separator Drain Plug Upgrade
Ford Cetane boost every fillup
Amsoil By-Pass(Amsoil 5w40)
Fumoto Oil Drain Valve
Dieselsite Coolant Filtration System
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
Pulling a 14,000 lb Alpenlite 5er
Roll-N-Lock bed cover
97 F350 4x4 PSD CC LB (sold it)
1700 Super Chip
PacBrake&ATS converter lockup
3" dp-4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A pillar EGT,Boost,Trans
2 Stroker is offline
