DIESEL TREATMENT - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 12-10-2012, 05:31 PM Thread Starter
DIESEL TREATMENT
Has anyone use Howes diesel treatment just got my truck back from dealer 4 new injectors,and fuel pump was told to add with next couple fill ups what does everyone use i never added anything 116000mi
LILPHIL1 is offline
post #2 of 11 (permalink) Old 12-10-2012, 06:42 PM
Start with these: ARCHOIL products OR Rev-x additives. What we use in the 6.0's.Pretty much adopted by us who run this engine as tried and true. I also run Diesel -Kleen as well. There are others as well/ Stanadyne and Opti-Lube. May I ask what filters you run,what oil/weight? What year truck?...b
03 F-250 CC LB XLT 3:73 rear/ almost stock/ early build/ 78,000 miles...03 F-250 ext cab Lariat Fx4 SB 3:73's /stock/187,000 all original injectors...FICM by Ed @FICM.COM / ScanGuage 2 monitoring the vitals...
03powerstrokeuser is offline
post #3 of 11 (permalink) Old 12-10-2012, 06:44 PM
jeffws's Avatar
Im using Archoil in the oil and the fuel.....
05 F 250 CC PSD FX4
BPD EGR Cooler
DC Power 185 amp
Dieselsite Coolant Filter
Edge Insight CTS w/ Fuel Pressure, EGT and Turbo Timer
Blue Spring Upgrade
HFCM Water Separator Drain Plug Upgrade
High Idle Mod
Mag-Hytec 6 Quart Diff Cover
Bilstein Shocks & Dual Stabilizer
285 75 17 Toyo's
Airlift Air Bags
jeffws is offline
post #4 of 11 (permalink) Old 12-10-2012, 09:22 PM
cyclone3565's Avatar
I have had great luck with Hot Shots Secret. I do monitor my fuel pressure (blue spring installed) and get around 70psi. I am running all original injectors with Rotella T6
Martin - Fort Worth, Texas
2008 f-250 Lariat
- 5.4 Gasoline - Absolutely Love It
2003 F-250 FX-4
--Sold my last diesel
cyclone3565 is offline
post #5 of 11 (permalink) Old 12-13-2012, 08:03 PM Thread Starter
2006 CREWCAB dually all stock change oil every 5500miles 15-40 shell and fuels 10000 with ford filters change anti 55000 i never added anything into the fuel tank living in NEPA
LILPHIL1 is offline
post #6 of 11 (permalink) Old 12-13-2012, 08:30 PM
Great info. If you migrate to syn oil, the 6.0's love it. Also do a fuel additive as mentioned earlier for lubricity, you should go many more miles...b
post #7 of 11 (permalink) Old 12-13-2012, 10:25 PM
Feedback Score: 2 reviews
As stated you should switch to a 5w40 better at startup and your injector will like you for it. I use the Ford stuff works for me.
Cetane Booster and Performance Improver (ULSD Compliant)
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS with Expandable pyro
AutoMeter Fuel Pressure Gauge 0-100
Sinister Fuel Pressure Adapter
Updated Fuel Reg. Kit 3C3Z-9T517-AG
WOT 58lbs Idle 62-64lbs Just Right
Ford Cetane boost every fillup
Amsoil By-Pass(Amsoil 5w40)
Fumoto Oil Drain Valve
Dieselsite Coolant Filtration System
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
Pulling a 14,000 lb Alpenlite 5er
Roll-N-Lock bed cover
97 F350 4x4 PSD CC LB (sold it)
1700 Super Chip
PacBrake&ATS converter lockup
3" dp-4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A pillar EGT,Boost,Trans
2 Stroker is offline
post #8 of 11 (permalink) Old 12-14-2012, 07:54 AM
Here is a link to a study that shows the what and the why for fuel additives: Lubricity Additive Study Results - Diesel Place : Chevrolet and GMC Diesel Truck Forums
The key point to get is here: "The U.S. standard for diesel fuel says a commercially available diesel fuel should produce a wear scar of no greater than 520 microns. The Engine Manufacturers Association had requested a standard of a wear scar no greater than 460 microns, typical of the pre-ULSD fuels. Most experts agree that a 520 micron standard is adequate, but also that the lower the wear scar the better."
The scar test number for the fuel is what can hurt the injectors. It is said to be what is really hurting the high pressure fuel pumps in the new diesel engines from a lot of manufacturers - Bosch says the pump needs 460 scar fuel, while US suppliers are pumping 520 scar fuel, and the pumps are failing. When they fail, they take out the engine putting aluminium shards through the entire fuel system. I don't have any info on what the 520 scar fuel does specifically to our injectors and the 6.0 does not have a high pressure fuel pump to worry about.
For my fellow Canadians - the Canada standard for fuel lubricity is 460 scar, and we are just now going to mandated 2% biodiesel. We just don't have the fuel issues that US owners do, but if we travel in the US, we need to stock up on and use a fuel additive to be safe. Also - whatever fuel additive you choose should NOT contain alcohol. Alcohol does a good job of absorbing water from fuel and sending in through the fuel system, and we all know that water in fuel is bad - the fuel filters cannot filter out the water-absorbed alcohol and it gets into the injectors. There are other additives that get rid of water and don't allow it to be passed through the water separator in the fuel filter system.
Brian
MC5C is offline
post #9 of 11 (permalink) Old 12-15-2012, 11:29 AM
05_HARLEY_F250's Avatar
I ran Howe's after I first bought my truck it stayed in freezing environment, now, pay attention to this part. I do not blame Howe's it could have all been just coincidence but I had multiple injector failures which eventually lead to head trauma and wall scarification. The dealership making the repairs told me to discontinue the use of cleaners and fuel additives. But ever since I started using the stuff in the gray bottle at Walmart i think it's called diesel Kleen by power service in every tankful I have had alot less problems and the truck runs good and smooth unless I fillip and let it sit parked for about two weeks
Sent from my iPhone using AutoGuide.com App
Replaced or Updated: Radiator, thermostat, heater valve, degas cap, Stock Head gaskets, oil cooler, Harley Davidson windshield. ARP studs, STC, stand pipes, dummy plugs, Motorcraft max batteries, turbo oil supply & drain, Blue spring, Fuel/water separator drain plug, interior light LED conversion, Recon smoke LED tail lights, third brake light & mirror lights & added Big rig ice running board and Fire & ice tailgate strip. Other mods: Garrett powermax turbo with riff raff SP billet wheel & boots, Metal CAC tube w/cool it thermo tec aluminized coating, Harpoon, tailgate assist, Drilled/slotted rotors w/ceramic pads, Goodyear Wrangler Duratrac 275/65R20 & Gatorback belt, IPR Generation 2 EGR & up pipe delete. MBRP 5" turbo back SS straight, IPR coolant filter, Rotella ELC conversion Fumoto; oil drain, block drain x's 2, CCV drain. Electronics: PHP Gryphon/Eco, Atlas 40,80,Herc, Edge CTS insight w/EGT, Upfitter switch, high idle mod, JVC KW-NT700, Viper 5904 2-way.
05_HARLEY_F250 is offline
post #10 of 11 (permalink) Old 12-15-2012, 04:37 PM
Steve Campbell's Avatar
Wondering who makes the Ford Additive?
2012 F250 Lariat 6.7 Golden Bronze 4X4, MBRP Filter Back Duals, Alpine INE-Z928HD, Focal Amp and Speakers and a ton of Dyno Mat, RetraxPro, Clifford Alarm Recon smoked marker/clearance lights, HID Headlights, Rigid D2 Driving Lights (in fog location), Bilstein 5160 shocks,Hellwig Big Wig Sway Bar, Pro Comp 2 Inch Nitro Leveling Kit, Fuel 22" Maverick Wheels , Nitto 325/50R22 Terra Grappler, Westin Bull Bar
Protected by H&K
USP and friends
2006 Hummer H2
(traded for
diesel hope never to go back to the dark side (gas)
2005 F250SD SB 4X4 6.0 Harley Edition (traded)
2003 7.3 F350 DRW 4X4 (traded)
2001 7.3 F250 4X4 (traded)
Steve Campbell is offline
post #11 of 11 (permalink) Old 12-16-2012, 02:06 PM
deliberate's Avatar
Lowest bidder?
- Don
2010
F350 SRW 6.4L 3.55 CrewCab FX4 SB KingRanch - built Jan 2010 - bought new Dec 2010
"You can set my truck on fire, roll it down the hill, and I still wouldn't trade it for a Coupe d'Ville."
Rant: Do you know what you actually pumped into your tank on last fill-up? (cetane level, fuel quality, water, etc)
Notice: Anything that I or anyone else writes about my vehicle on this, or any other, website pertaining to modifications or alterations, is only for discussion purposes and/or to gain acceptance from my peers, and may not actually represent anything existing on my truck, and thus, can not and should not be held against me in any issues, i.e. warranty claims, whatsoever that may arise for any cause.
deliberate is offline
