Diesel "whistle turbo sound" - how do I add it? - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 10-02-2005, 11:43 AM Thread Starter
I was at a parking lot and heard a diesel with an after market whistle sound which sort of sounded like an amplified turbo spool-up sound. It sounded like it was added to the exhaust system. Thanks
bluerock5 is offline
post #2 of 11 (permalink) Old 10-02-2005, 12:15 PM
rock_doctor's Avatar
Re: Diesel "whistle turbo sound" - how do I add it?
The sound can be made louder by going with an aftermarket exhaust.
good luck,
mark
rock_doctor is offline
post #3 of 11 (permalink) Old 10-02-2005, 06:49 PM
edited to remove reference to an illegal act.
2012 F350 Dually Crew, 4x4, Lariat.
chancemows is offline
post #4 of 11 (permalink) Old 10-02-2005, 07:08 PM
Be careful there [img]/ubbthreads/images/graemlins/phoney.gif[/img]
DI4 pos,homemadeTymar,
Autometer boost & EGT,CCV bipass,DIY Xbrake,HXmod,PS2000,WalkerBTM,LUK clutch,
IH Jasper reman.w/forged rods,ATScomp.shroud W/W
05 F350,DRW,CC,FX4,Lariat,4:10 ears,4x4,
AutoMeter Cobalts,pyro/trans/boost
popup g/n hitch,CCV reroute,MotorGuard M30 bypass filter,MBRP tubo back,SCT,all update parts with EGR gone,Insight CTS
jombi1 is offline
post #5 of 11 (permalink) Old 10-02-2005, 08:21 PM
The very early '03's like mine had much more whistle by design of the number of vanes in the turbo. Plus the fact that these early one's had removeable silencer rings. Both of these factors along with a larger exhaust make for lots of whistle not acheivable by the later trucks. You can swap in an early turbo in your later trucks for that same whistle.
'03 "TNT Ranch Edition" F350 CrewCab Lariat 4X4 DRW, 12V Cummins, P&P head with 60# valvesprings, PDR QuickSpool cam, built pump with 4K GSK, S366 Turbo, ZF6spd. with Valair Ceramic/Kevlar, manual hubs, 3.73's, 5.5" lift w/285 Dayton Timberlines, 2" DRW Spacers.
Bullrack is offline
post #6 of 11 (permalink) Old 10-02-2005, 09:01 PM
FamilyRide's Avatar
You've been around since 2000 and you still don't have any info on your truck in your sig or profile? [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
I'm guessing you don't have a 6.0? Even with a 7.3 you'll hear the turbo.
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, bubba lights and newly added so called bullet proofing, including PMax turbo.
FamilyRide is offline
post #7 of 11 (permalink) Old 10-02-2005, 09:01 PM
My truck seemed to have gotten louder after I installed my Airaid Intake system. [img]/ubbthreads/images/graemlins/cool.gif[/img]
05 F-250 Lariat CC 4x4 Black and Silver
05pscc is offline
post #8 of 11 (permalink) Old 10-16-2005, 08:33 PM
where are the removable sielencer ring located???? [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
strokezilla is offline
post #9 of 11 (permalink) Old 10-17-2005, 01:21 AM
mc70's Avatar
[img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img]
2003 CC F250 Lariat FX4, Banks Big Hoss bundle, AFE intake, rhino lined, 285/75 Destination M/T's, 15k 5th wheel hitch...more in progress
2005 Wildcat 5'er
1999 Caravelle 232 Interceptor Sport Cabin
mc70 is offline
post #10 of 11 (permalink) Old 10-17-2005, 01:38 AM
hitecdan's Avatar
My Photos: (23)
In between the down pipe and cat their is a resonator chamber to dampen turbo noise. It looks like a little bulge in the exhaust tubing, just underneath the passenger side floor board. Take that thing off and you can piss off your neighbors for 3 or 4 blocks.
My html Version of the
Now with 2005 Updates
Born on date: Jan 20, 2003
Number of C94 injectors replaced: 1 (#4 Jan 30, 2015)
Number of times the EGR valve has been replaced/cleaned: 0 (updated: 9/17/2014)
hitecdan is offline
post #11 of 11 (permalink) Old 10-17-2005, 10:31 AM
Air intake a little difference in turbo sound; just barley audiable inside cab. Programmer and turbo back exhuast and deer scatter by the hundreds in every direction !
DD [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
dustydubbs is offline
