Do '05s get the romps? - Diesel Forum - TheDieselStop.com
Old 08-03-2005, 05:38 PM   #1 (permalink)
Sometimes my truck will develop a rough idle while I'm sitting at a red light or in my driveway. It actually shakes the truck a little bit and it changes the sound. Is this "romping" or could it be something else? Maybe an EGR valve issue? I'm changing my fuel filters today to see if it helps. Thanks.
2005 Dark Copper F250 King Ranch FX4 PSD, Short Box, Donahoe Racing 2.5" kit, Toyo Open Country 325/65-18s, XM Commander, Ranch Hand Summit Series Front end replacement and back bumper, AFE Stage 2 Intake, Edge Platinum,
CaboWabo1 is offline
Old 08-03-2005, 06:15 PM   #2 (permalink)
Re: Do '05s get the romps?
Ford doesn't like longhorn fans. That's why your truck is running like that [img]/ubbthreads/images/graemlins/biggrin.gif[/img]. Anyway, I honestly haven't heard of an '05 w/a lot of romping issues as compared to the '03's and '04's. If I was a betting man, I would say it is either your EBP sensor, EGR, or both. Best of luck.
2007.5 Chevy 2500 HD (Dark Blue) - LMM Duramax & Allison - C/C S/B 4x4 Z71 - Sirius Sat Radio & iPod (thanks PIE Interface) - Oil Guard Bypass Filtration - 2 Micron Caterpillar Fuel Filtration - EGR Blocker Plate - PCV Reroute - MBRP 4" Turbo Back - EFI Live
Never argue with an idiot. They will bring you down to their level and beat you with experience.
Arkapigdiesel is offline
Old 08-03-2005, 06:30 PM   #3 (permalink)
I've never seen an 05 romp.
2008 F550 6.4 w/ pickup bed
kehale is offline
Old 08-03-2005, 10:02 PM   #4 (permalink)
My 05 does occasionally on a warm start. It is almost imperceptable, but having owned an 03 I know what the romps are.
RYANLEWIS is offline
Old 08-03-2005, 10:40 PM   #5 (permalink)
Make sure your oil is not overfull, run it, wait 20min. and check it on good level ground... Too much oil will make em romp, or very used oil that no longer has any of the anti foam stuff left.
j.schall
2005 f250 PSD 4x4,CC,LB Magnaflow 4" turbo back exhaust.
moovet is offline
Old 08-04-2005, 12:07 PM   #6 (permalink)
my 04/05 did, my 05 never has runs idles much better althought louder.
www.fuelly.com/driver/rpres62/f250-super-duty
2011 Ford SD250 6.7 Lariat interior group 20"s chrome package, White/beige Black Leather, 3.55's, ARE Topper, Bed Rug, EDGE CTS Gauges
99 SD250 sc swb 4x4 psd auto 3.73ls,lariat, oxford white, leather, loaded, boss v plow 130,000 miles
Dick is offline
Old 08-04-2005, 12:20 PM   #7 (permalink)
I believe the 05's have a completely different designed HPOP, which I believe is the source of the romps... even all the way back to the 7.3's.
--Chad
Cincy, OH
<font color="blue">- 2008 F250, 6.4, 4x4, XLT, SC, LWB, DK Shadow Grey, Rapid Heat, Autopage 2-way Remote Start/Turbo Timer</font>
Glow_Plug is offline
Old 06-02-2006, 10:38 PM   #8 (permalink)
Lightningfast01's Avatar
My 05 is surging at part throttle acceleration and cruising speeds. The idle is irratic and pulls the truck forward occassionaly. I unplugged the EGR and it still does it but no black smoke now.
2005 F250 FX4 SuperCab SWB in DSG
Buckstop rear bumper American steel!
Daystar baja bar with PIAA Racing 80's
Quad pillar Air, trans temp, pyro, boost
Magnaflow 15954, ATS studs
Transfer Flow 46gal midship tank
Firestone Airbags 2400 kit ViAir 250C compressor
Eaton TruTrac, Rancho 9000's, Skyjacker 1.5" rings
ViAir 380C@200psi, 5gal tank, Siege Anvil train horns say move *****!
Lightningfast01 is offline
