Do I need to run ULSD in my 07? - Diesel Forum - TheDieselStop.com
Old 03-28-2007, 11:10 AM   #1 (permalink)
Hey everyone! Well, we picked up an 07 6.0 last week, and I was just wondering if I HAVE to run ULSD in it. I know that you do on the 08, but I was just wondering since it was the 6.0 I'm just asking, because I dont know what the local station uses because I havent had time to find out. Also Is there any advantage to using it, atleast untill everybody switches over.
Mike
04strokinSD is offline
Old 03-28-2007, 11:24 AM   #2 (permalink)
Re: Do I need to run ULSD in my 07?
No, you don't HAVE to run it. However, finding places that don't sell it is becoming much more difficult. I personally have been running it in my 05 for the last year at least. I have seen quite a few people on here say that they run additives to increase the cetane (sp?) rating. I haven’t run additives on a regular basis, but I have run it occasionally.
'05 F350 CC-SB-SRW-4X4 Auto
'07 40' Fifth Wheel @ 14K
Dieselrandy is offline
Old 03-28-2007, 12:44 PM   #3 (permalink)
Just like Res said, you don't have to use it, but Low Sulpher diesel is getting harder to find. In actuality, the cetane number in the new Ultra Low Sulpher diesel is HIGHER, but it has less lubricating properties than the old low sulpher diesel, hence more people using addatives!
2004 F-350 Lariat SRW <><
315 BFGs, Edge Platinum, ARP Studs, & B&W Goose
1998 Cherokee RockCrawler
NCfarmboy is offline
Old 04-03-2007, 12:34 AM   #4 (permalink)
I have been running USLD for the past year, with no additives and have noticed no difference--------JMHO------Supercrew632
2004 F250 Crewcab PSD FX4 Lariat--Oxford White--18" Stock wheels--Loaded--Grey leather--Bedliner--Chrome fender flares--3.73 rear end--6/21/04 build date--Custom Harley Flames just added!!
My other rides.....
2002 F150 XLT Supercrew, FX4 5.4l all stock
2001 F150 Lariat Supercrew 2wd 5,4l all stock
1995 Saturn SC1 SOHC 4 cyl.
1993 GMC Safari XT 4.3l 6 cyl.
1968 Chevy Camaro w/1989 Corvette 350 w 700r4 trans w/overdrive, Holley demon carb, mostly original.
2002 Wanderer Glidelite TT w/slideouts 26ft.
1974 Reinell Tri-hull openbow 165 horse OMC.
Cadillac Technician-A.S.E. Master and GM Master
Supercrew632 is offline
Old 04-03-2007, 01:00 AM   #5 (permalink)
mrkleen's Avatar
i dont put any additive in mine on a regular basis just some poewer service once in a while no probs here
2003 F-350 6.0 PSD crew cab dualie az beige 4x4 esof 93k xm radio, molded mud guards rhino liner high idle mod, LOUD exhaust ( hee hee )
2001 expedition 5.4 silver xlt leather ( wifes ride)
mrkleen is offline
Old 04-03-2007, 11:46 AM   #6 (permalink)
It's like the farmboy said, ULSD has a higher Cetane number than LSD did, something on the order of 3-5 points. Don't worry about the Cetane, but lubricity may be another issue. I use Stanadyne Performance Formula in every tankful. I know the feds require a certain amount of lubricity added to the fuel at the refinery, but I don't trust my original C-94s to the feds or to the refinery. I know that the refinery I just retired from does add the required lubricant to the fuel. I just don't know if it's enough. They think it is.
2003 KR F-250 4X4 CC SWB, 6.0, 5 Speed Auto, 3.73 Axle, no Limited slip. Rhino bedliner, Unicover bed cover.
Built on February 19, '03
#2 93 F-150 XLT, 5 Liter, Auto, 4X4, X Cab. 251,000 miles. Uses no oil between changes.
montanafan is offline
