Does this sound like a sticking solenoid? - Diesel Forum - TheDieselStop.com
Old 11-18-2006, 03:48 PM   #1 (permalink)
I just started with a problem, when I put the truck in reverse there is a 2-3 second delay before I feel anything happen. When it goes into gear there is a slight thump then a brief pause then another thump, then reverse as normal. On the road, the truck drives like normal.
Slowing down for a stop light feels weird like something is still pushing the truck, I get another two thumps as I come to a complete stop, then the truck is normal. Drive away from the stoplight and the truck is fine.
This just started and happens only when slowing down to make a stop or going into reverse.
I had the reverse planetary recall done a while ago and at the same time the shift solenoids were changed, does this sound like a sticking solenoid or something bigger?
2004 F-250 6.0 auto
nummit is offline
Old 11-18-2006, 08:48 PM   #2 (permalink)
Re: Does this sound like a sticking solenoid?
Yes it does sound alot like a shift solenoid. Just curious, but was there a metal making issue when the reverse planetary assy was replaced on recall? I remember a few that have had issues because the system was not completely cleaned after the reverse planetary failed or was on the verge of failure.
2004 F-350 Lariat, Supercab 4X4 FX4, DRW
Dark Toreador Red/Silver, 6.0L, Torqueshift Auto, ESOF, 4.10 LS, Camper Package, Dual Alternators. Build Date 6-8-04, Eng 5-28-04, Lance 9.5 Ft Camper.
Past 2002 F-350 Lariat, Supercab 4X4, Toreador
Red, 7.3L, Auto, DRW, Fully Loaded.
Past 94.5 F-250 Lariat, Supercab 4X4, 5 spd 7.3L PSD.
DRJ48 is offline
Old 11-19-2006, 07:38 AM   #3 (permalink)
Not sure on the metal bits. I had no issues before the recall was done, so I thought it was just a preventative fix.
2004 F-250 6.0 auto
nummit is offline
Old 11-19-2006, 10:38 AM   #4 (permalink)
If there was no problem with the reverse planetary at recall, why did they replace the shift solenoids? Did they install a second inline filter when they did the recall, which they were supposed to if there was any issues? I would pull the external filter and check it for contamination.
DRJ48 is offline
Old 11-19-2006, 12:07 PM   #5 (permalink)
I honestly have no idea why they were changed. I called to get an update and they told me it was back together but when they went for a test drive they said they found a bad solenoid. Since I had driven the truck to them and had no prior issues I found it to be odd, but did not push the issue.
As for the second inline filter, nope! I followed the lines to the external filter and found no added filter.
2004 F-250 6.0 auto
nummit is offline
Old 11-20-2006, 08:01 PM   #6 (permalink)
Anyone else have an opinion?
2004 F-250 6.0 auto
nummit is offline
Old 11-20-2006, 10:52 PM   #7 (permalink)
Nummit, This seems to be a two way conversation? [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/smile.gif[/img]
I would still suggest pulling the external filter to find out whether you have a mechanical breakdown and contamination problem or just an electrical problem. You may have to take it in to be checked. Hopefully its still under warrenty.
DRJ48 is offline
Old 11-21-2006, 08:04 PM   #8 (permalink)
Yep, I still have warranty. I will be calling the dealer after the holiday.
Thanks for your input
2004 F-250 6.0 auto
nummit is offline
