I have a f-350 with the 6.0L. You can see the specs in my sig.
Generally I am pleased with it. But it has always been pretty doggie coming out of the hole.
Once the rpms are up, 2000 rpms or more, it is very responsive. You can feel and use the horses and torque. But when you are stopped at the light. Or, on a hill with a load. Granny's help is required.
Is it normal to have to use 2000 rpms or better to get it to run "like it should"?
'03 Excursion, 7.3L, 4X4, Auto tranny of course (they all did), 4" MBRP exhaust, TS performance chip, K&N FIPK w/ an Amsoil EA filter, Hellwig anti-sway bar, drilled/slotted front & rear rotors. Rancho XL shocks, Rancho steering damper, Airlift 5000, S&S Diversified headlight mod. This baby surprises a lot of, so called, performance cars.
'04 F 350, extended cab, 6.0L, FX4, manual tranny, 4" MBRP exhaust, Bully Dog Triple Dog downloader w/ Outlook moniter (Very disappointed in the Bully Dog), 2m-70cm Yaesu ft-8500, S&S Diversified headlight mod.
'11 Harley-Davidson Road King Classic 103 ci PowerPak w/ anti lock brakes & Smart Security system. It even has cruise control!!! Candy Dark Root Beer over Candy Light Root Beer Yaesu FTM-10R & a Comet CSB 790A
Mine has always lagged from a stop, but once the turbo spools up then it really gets going. I guess its normal and it does suck. If there is one think I could change about my truck's performance would be off the line throttle response. Will be interesiting to see what recommendations there are to fix it. btw my free flowing exhaust and CAI kit did little to help.
__________________ 07 F-350 xlt 6.0 PSD LB CC SRW 4x4, black on tan, A/T, 5" exhaust w/4" downpipe 67 F-250 Project truck, currently in a billion pieces 70 F-250 4x4 (highboy)
Past trucks: 04 F-250 xlt 6.0 PSD SB extcab 4x4, 6spd, all stock and 97 F-250HD xlt 7.3 PSD extcab LB 4x4, 5spd, Superchips tuner, 4" turbo back exaust, K&N CAI, 02 intercooler installed, Sold
Its normal. Its a turbo diesel, its makes power with boost. No boost, no power, there is no boost off idle so thats where the lag comes from. It will never be like a gas engine off idle, just adjust your driving to live with it.
I have a 6sp. manual and its definatly more noticable in the manual tranny trucks.
This is what I figured. I am just not use, even after having the truck for 5 years, to reving the engine up to 1800 or 2000 RPM to get the power.
I have noticed that my Excursion, with an automatic tranny, easily and regularly revs up to 200 rpms when I take off in it.
Thanks for the feedback.
The only way to reduce the lag off the line is to speed up how fast the turbo spools up.
Many aftermarket additions will help decrease spool up time: larger intake, large inter-cooler and boost tubes, aftermarket intercooler, cold air kit, and aftermarket exhaust. I'm sure that I'm missing others.....
2004 f250 CC 6.0 PSD, SCT X3 Custom Tuned from Innovative Diesel; Econ, Street, Extreme Street. Edge Insight Monitor, Zoodad Mod, High Idle Mod, Tough Country front leveling kit, 1" rear lift block, MBRP Turbo back off road exhaust kit......aka the Jet Engine!
Maybe im not reading this correctly, but is this something that just happened or
been happening since day one. How many miles?
From the factory.
It is just a feature of turbo lag that one notices because it has a manual tranny.
As I mentioned, the Ex w/ the auto goes to 2000 Rs when one puts his foot into it. But with a manual tranny I am more aware of the need to do so.
It is the difference between diesel w/ a turbo and a gas engine. My 96 Mustang Cobra does not need to Rs like the diesel w/ the turbo does. 2000 Rs in the mustang and you are in the next county in a breath.
Even my non turbo'd 83 6.9 diesel didn't need the 2000 Rs to go. Admittedly is was slow. But the thing would idle up a steep hill in 1st loaded to the top of the bed w/ broken concrete, tools and stuff on the concrete, lumber on the rack, and towing a compressor, without taking a second breath. I know because that is an actual example of what I did one time. And then there was granny below 1st in case you got a real load to deal with. All w/ only 175 horses.
W/ the turbo I just do not have the same power of the 83. And the turbo has 325 horses.
I suppose I am just expressing my disappointment that when I went from 175 HP to 325 HP I expected different performance than what I got.
For people that don't want to tune their trucks and or have a tuner that does not fuel off idle like a custom tune one solution would be to get a boost fooler. This will make the computer fuel early abd spool faster. It also will allow a little more on the top end. Not all tuners have a boost fooler built in. Most sct custom tunes tune out the factory table for fueling to make a snappier throttle. I'm not completely sure what all tuners have "built in" boost foolers in their tuning. The cost of the boost foolers are about $75-100 bucks. Might be a idea to look into. A few months back there was a discussion about boost foolers on one of the forums. Dave at bd was very helpful.
2006 f250 4x4
crewcab short bed
lariat 6.0psd
auto, electric tcase
soon to have isspro
fire/air/trans/fuel
stock suspension and
pretty much everything
else
