Draining or FLushing Power Steering FLuid.... HOW ? - Diesel Forum - TheDieselStop.com
Old 08-19-2009, 05:34 PM   #1 (permalink)
What would be the best way to flush or drian the power steering fluid in the system ?
06 Lariet FX4 6.0 Disel Fully Loaded Captins chairs Long Bed CREW Cab
tytrophen is offline
Old 08-20-2009, 08:52 PM   #2 (permalink)
I don't think there is any kind of flushing that can be done. When I did mine I used a turkey baster to suck out as much fluid as I could and then refilled it with new fluid. I don't know how much was left in the system but figured it was better than nothing.
2003 CC SRW SB Auto 3.73
Mods:
REAR Air Locker
Kenwood DNX 7140
ISSPRO A Pillar Gauges
Femoto Valve
Edge Insight CTS
dieselhappy is offline
Old 08-28-2009, 10:34 PM   #3 (permalink)
Remove th top line from the power steering cooler. Let it drain. Place a line on the cooler end and direct it to a container. Start the engine and add fluid to the res. Pump the brake pedal and then add more fluid. Do this 2 or 3 times. You will have all clean fluid.
Rich
RPFAN3460 is offline
Old 08-29-2009, 11:15 AM   #4 (permalink)
69cj's Avatar
I also added a Magnefine inline filter to mine. What a diff. it has made to keeping the fluid clean. I also used Mercon V syn. fluid.
69cj is offline
Old 08-29-2009, 12:12 PM   #5 (permalink)
Strokin' 6.0's Avatar
What is the recommended fluid for the power steering?
Fred
2004 F-350 CC DRW LB FX4 4x4
Oxford White/Arizona Beige
King Ranch
Herrin Hauler bed
4.10 Trac-Lok
Reman'd 6.0L @43,956 miles
Reman'd Turbo @54,814 miles
Strokin' 6.0 is offline
Old 08-29-2009, 09:11 PM   #6 (permalink)
Ranger_713's Avatar
Book specs regular MD-3, but Mercon V or SP is a good step up (synthetic).
Values are typical and may vary by 10% depending upon current altitude, accessory operation, engine load, operating time, temperature, and vehicle speed.
Ranger_713 is offline
Old 08-30-2009, 04:11 AM   #7 (permalink)
redline synthetic is excellent!
Judgeguns is offline
