Draining fuel tank - Diesel Forum - TheDieselStop.com
Old 10-01-2005, 10:52 PM   #1 (permalink)
Draining fuel tank
Been having problems with water in fuel. 04 250 4wd ExtCab about 27000 miles. Have changed filters several times and used the drain on the HCFM. Am thinking about completely draining the tank and dumping a few gallons of fresh fuel through it. Any suggestions on the best and easiest way to completly drain the tank.
Thanks John
70custom is offline
Old 10-01-2005, 10:59 PM   #2 (permalink)
My Photos: (21)
Re: Draining fuel tank
Hold up on that draining... there's known issues with the WIF sensor on the HFCM. Drain the water seperator into a plixglass bottle and let it sit for awhile. If there's that much water, you should be able to see it seperate out.
While you're waiting read the WIF Won't go Away TSB
O
6.0 PSD TSB's
02/03 built F350 6L, DRW, 05 Grille , 4" DPPI Exhaust, UltraLites on the A Pillar and Overhead Console, Firestone Bags & Compressor, Hadley Bully Airhorns , 50 Gallon Transfer Flow, Racho 9000's, Leveled 2.5/0, In-Dash PC , XM Commander.
Photos
ozhoo is offline
Old 10-02-2005, 12:05 PM   #3 (permalink)
O
Would this be a warranty issue?
70custom is offline
Old 10-02-2005, 12:30 PM   #4 (permalink)
You bet!
'04 F-250 4X4 6.0 Rhino Liner, Grill Guard, 8,000lb Warn Winch, Nerf Bars, Superhide Seat Covers, and Dash mat.Sky Jacker leveling kit, and 1" blocks under rear springs. Banks, turbo-back ex.Coolant filter.
GrandSlam is offline
