Drone go away please help - Diesel Forum - TheDieselStop.com
Old 05-07-2005, 08:14 PM   #1 (permalink)
My 05 with 922 miles is starting to get the drone at 1500 rpm's . I've read where some have install a piece of ss flex pipe in front of the muffler. Has anybody found what the cause or how to fix it. I don't want to go to the dealer without any info so they look at me like I'm crazy and tell me nothing wrong with my truck.If aftermarket exhaust fixes it why don't Ford pay for it. This has to go away its driving me nuts at 55mph I got to speed so I don't hear it. Help [img]/ubbthreads/images/graemlins/eek.gif[/img]
O5 F-250 SuperDuty CC SWR 4x4 Lariat
8' box 6.0 PSD Tow Comand new 04/05
2001 40' Alfa Toyhouse
Pulls better stock than my 01 with a programmer
New engine at 42k . Hope my luck with this 6.0 is changed .
firesoutmatt is offline
Old 05-08-2005, 12:40 AM   #2 (permalink)
tjw
Re: Drone go away please help
firesoutmatt,
check out www.intellidog.com/dieselmann/home.html
under powerstroke bulletins. About one third thru the bulletin you should see a mention of your problem. Print it off, take it to your dealer with all the numbers, codes,... and tell those boys to get her fixed.
Good luck,
TJW.
tjw is offline
Old 05-08-2005, 02:31 AM   #3 (permalink)
For a 2005? They all have the updated turbo brackets.
2003 6.0 Bought back
2006 6.0 Replacement truck Problem list.
Too extensive to list.
Days in shop so far 71 and counting as they still have it.
34K miles.
After spending a month in the shop and having it back only 2 weeks, it's back in the shop. Ford Customer service refused to send me a DSB Package. Told me the info is in the back of manual. Well truck is in shop and I don't have the info can you give it to me? No, it's in the manual.
creeper is offline
Old 05-08-2005, 09:33 AM   #4 (permalink)
Put a turbo back aftermarket exhaust on it and be done with it.... [img]/ubbthreads/images/graemlins/smokin.gif[/img]
1996 PSD XLT Crew Cab Short Bed 4x4
Edge Evolution
Diamond Eye Exhaust
Tymar Intake
"The Short Bus"
MightyWhitey is offline
Old 05-08-2005, 10:39 AM   #5 (permalink)
ford_doctor's Avatar
Because that is not Ford's fix although they know it helps because an aftermarket exhaust re-tunes the system. I believe the problem started when a change was made to the turbo pedestal and the mentioned TSB addresses the issue. Sometimes you can affect a drone by simply loosening all of the exhaust clamps enough to allow them to move, drive the truck and get the system hot and then shut it down. After it cools, re tighten all clamps and fasteners from front to back. That method of "neutralizing" the system does not always work however, but it's worth a try.
Ford Master Diesel Technician
Diesel Technician Society
ford_doctor is offline
Old 05-08-2005, 11:01 AM   #6 (permalink)
Yep, after my Magnaflow turbo back was put on the drone was gone [img]/ubbthreads/images/graemlins/smokin.gif[/img].
2007.5 Chevy 2500 HD (Dark Blue) - LMM Duramax & Allison - C/C S/B 4x4 Z71 - Sirius Sat Radio & iPod (thanks PIE Interface) - Oil Guard Bypass Filtration - 2 Micron Caterpillar Fuel Filtration - EGR Blocker Plate - PCV Reroute - MBRP 4" Turbo Back - EFI Live
Never argue with an idiot. They will bring you down to their level and beat you with experience.
Arkapigdiesel is offline
Old 05-08-2005, 01:16 PM   #7 (permalink)
Turbo back or cat back?
34K miles.
creeper is offline
Old 05-08-2005, 05:10 PM   #8 (permalink)
It does not always fix it. I work on quite a few of these with different brands of exhaust kits. turbo back. most early 04 and 03s are still there. get the updated pedestal.
99.5 Green F250 Crew Cab short bed. Solid Chrome front bumper, chrome hooks, Chrome flame grill, 2005 Headlights and Emblems, K&N cone air filter, wicked wheel, 5" exhaust 6 1/2 tailpipe,Edge Evolution programmer, Pioneer in dash touch screen dvd player, Directed 200 amp to 4 pioneer 4ways Directed 600 amp to 3 10" JL audio subs, 6" superlift all riding on 4 Chrome 10x20 Helo Maxx 8S and toyo open country A/T 37/13.5/20 looks and runs like new.
jetski86 is offline
Old 05-08-2005, 06:20 PM   #9 (permalink)
I should have the updated one being its an 05 right?This truck been doing this in its first 1k miles.I will check the #'s on the pedestal tommorrow and make sure its the updated one. Then its off to the dealer and see what happens there.Who knows maybe they can fix it.If not I quess its a turbo back system.Its going to be hard to tell the better half why I need to put money into a new truck that cost $40,000.00. I wonder why I would have to do that but the truck is alot better than my 01 [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Old 05-09-2005, 01:11 AM   #10 (permalink)
I got the updated pedestal, it made the drone worse. Go figure.
34K miles.
creeper is offline
