Dual batteries and alternator - Diesel Forum - TheDieselStop.com
post #1 of 21 (permalink) Old 04-08-2009, 10:02 PM Thread Starter
I have a 2006 F350 6.o diesel...the last two days I've had to boost it.
I don't drive it much and from what I've read, guys are saying to have a charger on the batteries......Did Ford drop the ball on this one?????
Is the alternator not large enough for the dual batteries????
I can't believe that the alternator would not keep the batteries charged
even if you only drove 25 miles a day.
What battery drain is on the batteries while the motor is idle??
Rob
2006 F350 Dually Diesel
Crew Cab King Ranch
2006 F350 King Ranch Dually 6.0 Diesel
skidrow is offline
post #2 of 21 (permalink) Old 04-09-2009, 09:01 AM
I have the dual battery setup also, had to replace mine about 4 months ago. From my understanding it also has dual alternators to charge those batteries. A senior member will hopefully confirm that. One was bad out of the two, but would not start. All my truck does is pull, not a daily driver and they don't seem to like to sit idle.
CUoffroad is offline
post #3 of 21 (permalink) Old 04-09-2009, 10:12 AM
One alternator, it is pretty common that if one battery is bad it will work against the good battery and won't charge properly.
1990 Chevy 350 ShortBox
2002 Cadillac Escalade 22" Dale Jr Wheels
2003 Ford Excursion Limited 6.0 Powerstroke
2008 F-350 Lariat King Ranch 6.4 Powerstroke
2006 Kubota RTV Diesel
2007 Can-Am Renegade 800
2008 Can-Am Outlander 800
2006 Jayco Jay-Flight 29FBS
2008 Kubota ZDR-331 Mower
drwindmill is offline
post #4 of 21 (permalink) Old 04-09-2009, 02:40 PM
The single alternator should be able to maintain charge in both batteries if the batteries aren't bad.
If you have the original batteries in the truck still, you can look at the little "eye" between the battery posts. If the batteries are good you should see green or red if they are heading south. I just replaced mine last week with Duralast Golds from Autozone. $100 apiece, but with 3 year full replacement warranty and 8 year prorated warranty, they are worth it in my opinion. I plan on keeping my truck long term.
2005 F-350 Crew Cab,6.0L,Auto,4x4,King Ranch,White and Arizona Beige,Edge Evolution, MBRP 4" exhaust, 2.5" Donahoe Racing leveling kit,LT305/70-18 Dick Cepek Mud Countrys,Pro Flaps,Husky Liners,Draw Tite gooseneck hitch.
Sold: 2000 F-250,4x4,SC,XLT,Island Blue,Auto, Autometer Z-series Pyro, Tranny, and Boost gauges,
AFE Magnum Intake with Pro-Guard 7,TS 4-position (stock-50-75-140) Flip Chip,DPPI 4" exhaust w/ 3.5" downpipe,Sonnax/Tricumulator springs mod, TruCool Max,Edge 3" leveling kit w/4" blocks,16.5x9.75 Weld Typhoons,35x12.50x16.5 BFG A/T, Westin chrome nerf bars,Pro Flaps,B & W Turnover Ball,Husky Liners.
pwrstroker00 is offline
post #5 of 21 (permalink) Old 04-09-2009, 05:08 PM
lubbockguy1979's Avatar
Send a message via Yahoo to lubbockguy1979
Bad batteries will kill the altenator by over working it.... Test the batteries if one is bad replace both and save your self some time. The single altenator is plenty and can be built for more output.. The dual set up is expensive to repair vs. Single altenator
2006 f250 4x4
crewcab short bed
lariat 6.0psd
auto, electric tcase
soon to have isspro
fire/air/trans/fuel
stock suspension and
pretty much everything
else
lubbockguy1979 is offline
post #6 of 21 (permalink) Old 04-09-2009, 06:45 PM
Rob
Crew Cab King Ranch
No, Ford didn't drop the ball. I have a truck with a single alternator, and I got more than 6 years out of my batteries. A diesel needs the two batteries to provide enough amperage to turn the high compression engine over.
The major cause of battery failure is neglect. Batteries are not "maintenance free" if you want them to last a long time. The alternator is there to run the electrical components of the vehicle after its been started, and to recharge the batteries IF left on long enough at a decent rpm. You need to check the fluid on a regular basis, and make sure it's over the plates. Also, check the specific gravity of each cell. If it get low, use only distilled water to up the level.
The biggest killer is rapid start stops with little drive time. the next biggest is letting them set for long periods of time w/out charging. Batteries will blled off charge, and if just left to sit, will loose all charge & not recover.
If you are not using the truck at least 1/2 an hour at a time at least once a week, put a battery tender on it to keep the batteries fully charged.
As mentioned, batteries are a set, and need to be replaced as a set. A bad batter will pull the other down, and stress the alternator. Its a whole system. Take your truck into someone you trust, and have them run a load text on the batteries. then check the alternator. The little eye thing is only in one cell, and may or may not reflect the health of the whole battery.
OMC
OMCUSNR is offline
post #7 of 21 (permalink) Old 04-09-2009, 07:36 PM Thread Starter
Thanks for all the info...will get a load test done on the batteries and the
alternator...
skidrow is offline
post #8 of 21 (permalink) Old 04-11-2009, 02:56 AM Thread Starter
dual batteries and alternator
Well, I tested both batteris with thetruck off...They both
showed 12.7 volts...I turned on the trucdk and the voltage on the batteries
dropped to approx 11.9 volts then slowly increased (took approx 1 minute)
to 14.2 vots on both batteries.....I'm thinking that both my batteries
are OK and so is the charrging system...THe batteries have just been frundown with short trips and not enough time to charge them.
Does this sound correct??
skidrow is offline
post #9 of 21 (permalink) Old 04-11-2009, 08:32 AM
Sounds like the altenator might be trying to go to me... Mine would charge for a while then not... The stator had a short and it took out the batteries which were stock from 04.
2006 f250 4x4
crewcab short bed
lariat 6.0psd
soon to have isspro
fire/air/trans/fuel
else
post #10 of 21 (permalink) Old 04-11-2009, 12:18 PM
Here's the deal. You need to check the batteries independent of one another. unhook them from each other. Then check them one at a time. if both read the same and maintain the same reading for several minutes (around 12 volts) they are at least not shorted. doesn't tell you much about their load capabilities though. You can buy a cheap load tester most any where that sells auto parts. Don't rely on the volt meter on the load tester though unless you buy a good one. I prefer to use a separate volt meter that I know is accurate and reliable. If your alternator is putting out 13.5 or better volts at idle when hooked to the batteries it is most likely OK. The low initial reading may be because the glow-plugs were still activated. On the 6.0 the glow-plugs continue to operate for a minute or so after the wait to start light goes out and the engine is running. If the engine is cold, give the glow-plugs time to cycle off before taking a final reading. The voltage will read below 12 volts even with a good alternator if the glow-plugs are on. On the 7.3s the excess vibration usually guaranteed that one of the batteries would short out internally in less than three years. I have an '05 6.0 that has the original batteries and still cranks over fine. Also, when the price of diesel got so high, it was lucky to get run once in three weeks and I never had a problem save the time I left the after market satellite radio on. If you can't find a load tester unhook one or the other and operate on one battery temporarily until you can determine that one or the other is faulty. It will do fine on one battery if the outside temps are not below 40 degrees or so. If replacement is necessary always replace both batteries with identical new batteries. One old and one new battery is a recipe for early failure.
'05 F350 Lariat DRW 4X4 6L Auto, stock.
Above replaced '91 F350 XLT Lariat DRW 2X4 7.3L 5 speed man.
jbdawson is offline
post #11 of 21 (permalink) Old 04-11-2009, 07:03 PM Thread Starter
batteries
Checked both batteries separately...
one read 12.8V and the other one read 12.7 V
The one "eye" is showing red while the other
battery eye is showing green...
I take it that one cell in the red battery is shot....
I'm then thinking that it would have to be replaced
and as well the other one???
The voltage does climb when the engine
is turned on after a minute..I guess that means that the
glow plugs are still lit......and alternator is charging?
skidrow is offline
post #12 of 21 (permalink) Old 04-12-2009, 02:07 PM
If your voltage gets at or above 13.5 at idle it's likely not the alternator. I'll bet if you load tested the one with the red eye it would drop like a ton of bricks compared to the other one. Given what you have learned so far and the fact that they are on the order of three years old, I'd vote for a set of new batteries. I figure I'm on borrowed time with my four year olds.
jbdawson is offline
post #13 of 21 (permalink) Old 04-12-2009, 04:54 PM
One thing to think about is sulfation and this will happen to any lead acid battery left setting for periods of time without being charged. sulfation interferes with the ability of the battery to accept hold and deliver a charge. if your car truck boat or rv will only get part time use a battery conditioner will keep the battery fully charged between uses without over charging and so no sulfation that will kill your pricey batteries years too soon. H
93 F-250 7.3 IDI E40D 4x4 Stock.
h_jorr is offline
post #14 of 21 (permalink) Old 04-20-2009, 02:19 PM Thread Starter
Thumbs up Load Test
Had the delaer do a Battery load test as well as an alternator output
test..
all checked out fine....I guess it was the fact that the truck had been sitting a while and wasn't charging the batteries..
Thanks to all of you guys for your input....
skidrow is offline
post #15 of 21 (permalink) Old 04-20-2009, 05:03 PM
Banned
If you're not driving it much and AFTER AFTER AFTER you make sure your batteries are good or replace them. Then look up Nationsalternator.com on the web. Their alternators are pricy but worth EVERY SINGLE PENNY. They put out as much at idle as the OEM batteies do at about 2k rpm.
trailerlugging is offline
