Dual battery charging - Diesel Forum - TheDieselStop.com
post #1 of 43 (permalink) Old 11-07-2011, 11:43 AM Thread Starter
When charging batteries can you hook a charger (different chargers) up to both batteries at the same time or will that conflict with the electronics?
If I am understanding correctly the drivers side battery is the starting battery and the passenger side battery is the accessory battery or something similar.
When do they actually or do they ever throw juice together?
03 Excursion 6.0 4x4
05 FX4 F250 6.0 CCSB Lariat
outlawdiesel is offline
post #2 of 43 (permalink) Old 11-07-2011, 11:56 AM
bobsherrie's Avatar
The batteries are hooked up in parallel so both provide power to start the engine and run the accessories.
I have used two chargers, one on each battery, without any issues. To avoid conflict between the chargers I disconnect one of the batteries' ground cables but others may say that it is not necessary.
'06 F350 Lariat SRW X-cab,4X4,Torqshift 5-speed Auto,w/23000lb GCVWR and many other options, Vandal Alert Cyclops, Pressure Pro TPMS, Extang Tuff TonnoIII, Duraflap mud flaps and Roadwing mud flap system, towing a Hitchhiker 33' Discover America 5'er and a Lund boat. Stock and doing fine. Coolant filter, Fuel regulator upgrade.
bobsherrie is offline
post #3 of 43 (permalink) Old 11-07-2011, 12:05 PM Thread Starter
Didn't know that both of them started the engine, I thought they were separated some kind of way.
So if you're dead in the water with no starting juice then both batteries are going to be drained...
I have heard somewhere though that for starting purposes I needed to hook up the charger (or jumper cables) to the drivers side battery. Guess it doesn't make any difference at all?
Is there a maximum amperage you would throw through a charger for immediate starting? (I just purchased a larger charger this morning with a 200 amp starting mode on it)
Newer batteries check good, alternator check good, but something has drained it a couple times over the last few weeks and I am thinking it has something to do with the viper alarm/remote starter
post #4 of 43 (permalink) Old 11-07-2011, 12:07 PM
Feedback Score: 2 reviews
One thing to remember if you are having battery problems get new batteries because weak or bad ones will kill the FICM at a cost of about $1100 from Ford or $300 to have yours repaired should be a min of 850CCA
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS with Expandable pyro
AutoMeter Fuel Pressure Gauge 0-100
Sinister Fuel Pressure Adapter
Updated Fuel Reg. Kit 3C3Z-9T517-AG
WOT 58lbs Idle 62-64lbs Just Right
HFCM Water Separator Drain Plug Upgrade
Ford Cetane boost every fillup
Amsoil By-Pass(Amsoil 5w40)
Fumoto Oil Drain Valve
Dieselsite Coolant Filtration System
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
Pulling a 14,000 lb Alpenlite 5er
Roll-N-Lock bed cover
97 F350 4x4 PSD CC LB (sold it)
1700 Super Chip
PacBrake&ATS converter lockup
3" dp-4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A pillar EGT,Boost,Trans
2 Stroker is offline
post #5 of 43 (permalink) Old 11-07-2011, 12:28 PM Thread Starter
2 stroker
Thanks for that info. I have two "newer" 1000 cca batteries installed. About 1 1/2 years old now. Just went and got them checked to make sure and showing good.
post #6 of 43 (permalink) Old 11-07-2011, 12:38 PM
I have a Battery Tender Plus hard wired into the passerenger side battery so when it sets for over a week i plug it in because when you start you need 48 volts for the injectors to run and if you are low on volts you will kill the injectors also so batteries need to be at a full charge with the cold weather coming and they like a 5w40 Syn oil.
2 stroker
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
1700 Super Chip
3" dp-4" exhaust
Tymar Intake
post #7 of 43 (permalink) Old 11-07-2011, 12:59 PM
if you want to use two chargers, then disconnect one of the batteries' negative cable. You don't want two chargers in the same circuit at the same time.
Idahoser is offline
post #8 of 43 (permalink) Old 11-07-2011, 01:05 PM Thread Starter
edit post
post #9 of 43 (permalink) Old 11-07-2011, 01:07 PM Thread Starter
2 stroker
Also great info stroker, from what I had been told in the past I didn't think you needed both batteries...but from what you are saying I want to make sure both batteries are charged instead of just the drivers side battery before starting.
What about jumping off from another vehicle, obviously you have no choice than to use one battery or the other...
That is exactly what I am looking for, thank you
post #10 of 43 (permalink) Old 11-07-2011, 01:48 PM
broome101's Avatar
Jump off just like normal battery, if using a battery charger only one is required and it will feed the other battery, if you use two remove postive cable that is how they are hooked together in parallel , cable runs over top your radiator in a sleeve.
2013 KR, F350,6.2L,4x4,CC, LB
broome101 is offline
post #11 of 43 (permalink) Old 11-07-2011, 02:34 PM
Not a good idea to use two chargers
I've had some experience with battery chargers and it's good to have a little bit of background information when using/charging.
Most of today's battery chargers sense the battery's condition and will adjust their output accordingly. Almost all of them are not designed to "see" another source while charging and what will likely happen is you'll end up confusing the sensing circuitry and they'll go into "maintenance mode" rather than a charging mode.
Without boring everyone to death with the details - use a good quality battery charger whether it be for simple trickle charging of fully charged healthy batteries or a larger charge rate/charger for batteries that have been drained and need a good bit of refreshing.
Keep in mind that our lead acid batteries (and all batteries of any existing design with the exception of self limiting designs) experience damage when either discharged too quickly beyond design limitations or are overly discharged at any rate. Our starting system flows a huge amount of current during the starting operation. All of that current flow generates a large amount of heat in the starter and also in the batteries themselves.
As far as batteries go - this should be in another post - having two large capacity lead acid batteries does add some complications. Make absolutely sure your connections are all very clean and all cabling is in near perfect condition. If you have any question as to whether both batteries are healthy take them somewhere to have them load tested.
I make a point to advise people to always replace them as pairs because the weakest battery will always drag down the good one to equalize the system.
Just one more 2004 6.0L owner
Edge Insight display
bulletproofdiesel oil transfer block
bulletproofdiesel oil cooler
dieselsite coolant filter
mlwest is offline
post #12 of 43 (permalink) Old 11-07-2011, 02:46 PM Thread Starter
This brings up another question:
I had them load tested and they check out good, but the person who tests them (two different people at different times) agreed that one starts the engine and the other is for accessories which I am now finding is incorrect.
Even though both checked out good, in order to do a proper load test shouldn't they be checked without being hooked up in parallel together?
If one was bad, could they get a false reading from the other battery being hooked to it?
post #13 of 43 (permalink) Old 11-07-2011, 03:02 PM
I've not verified the statement that they are wired in parallel but I do believe it's the case. I know there are those that frequent this site that do have the schematics to verify.
IMHO anyone telling you that one is used for starting and another for accessories without having at least seen the schematic which enables that behavior is just blowing smoke.
I do know it is not uncommon in the gasoline world to add a second battery that is isolated from starting but I don't believe that's the case for 6.0L owners.
I do know that they MUST be disconnected to do a proper load test using a large carbon pile load tester. In theory you could test both but the tester would have to be huge in order to create a large enough load to make the batteries work hard in parallel.
mlwest is offline
post #14 of 43 (permalink) Old 11-07-2011, 03:03 PM
Each one needs to be load test by itself.
2 stroker
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
1700 Super Chip
3" dp-4" exhaust
Tymar Intake
post #15 of 43 (permalink) Old 11-07-2011, 03:20 PM
kwcat's Avatar
Send a message via MSN to kwcat Send a message via Yahoo to kwcat
The Ford diesels are parallel and the batteries need to be disconnected and tested one at a time.
1991 F250 IDI E4OD
1995 F350 POWERSTROKE E4OD 4x4
kwcat is offline
