dually rear axle - Diesel Forum - TheDieselStop.com
Old 11-15-2008, 04:33 PM   #1 (permalink)
damageinc85's Avatar
Question dually rear axle
Ive got an '03 4wd crew cab dually and had a problem ordering wheel bearings and seals.I ordered them for a Dana 80 off Rockauto.com,it said they were for the drw trucks.Prob is I recieved the parts and compared them to what was in the rear hub and they absolutely dwarf whats in there.I was wondering what rear axle they actually have?Luckily I compared the parts b4 I tore it all apart.It has the ID tag on the lower left of the diff cover just like the manual says the Dana axle should have.Any help greatly appreciated
damageinc85 is offline
Old 11-15-2008, 05:56 PM   #2 (permalink)
Dieselpower497's Avatar
Bearings
I had a similar problem with my truck. I couldnt figure out what the correct bearing part number was. I ended up having to revisit the dealer until i found a bearing that would work. I cant find the paperwork associated with this, but i remember the axle part number being a Dana R135 or something odd like that. I haope that helps a little.
2001 F-350 DRW crew cab. 7.3L 6 spd. Chipped by total diesel performance. gauges by Autometer. Exhaust by MBRP.
Dieselpower497 is offline
Old 11-15-2008, 06:44 PM   #3 (permalink)
lubbockguy1979's Avatar
Send a message via Yahoo to lubbockguy1979
i thought that the rear axle on the f350 was a dana70. i may be wrong but that would explain the difference in girth of parts
2006 f250 4x4
crewcab short bed
lariat 6.0psd
auto, electric tcase
soon to have isspro
fire/air/trans/fuel
stock suspension and
pretty much everything
else
lubbockguy1979 is offline
Old 11-16-2008, 10:18 AM   #4 (permalink)
99 up F350 duallies have Dana 80 but it is unique and has larger bearings at hubs than Dana 80 Dodge and GM applications.
If Rock Auto has a universal Dana 80 parts guide then it will not be correct for Fords.
2006 F450 CC Hauler bed 4x2 6.0 L Pstroke/Torqshift, Lariat, 4.30 r/a.
2006 F350 Lariat CC Dually 4X2, 6.0 TQShift 4.10 LS, STOCK.
36 foot double tandem axle flatbed trailer.
36 foot Sooner 6 horse large dressing/ mid tack.
15 horses with good balance from being hauled behind a P'stroke.
jimmy is offline
Old 11-16-2008, 10:24 AM   #5 (permalink)
Rooster's Avatar
99-04 should be a danna 80 with a 170mm center.......05 up has 200mm centers. Found this out when doing my rear axle bearing service as well as getting info on my future 19.5rims
2002 F-350, 4x4 *Banks Monster Exhaust * SC-MicroTuner * Racor Pre-Pump Fuel Filter * Tymar * GatorHyde Spray-in Bed Liner * Custom -AN 6 Fuel Supply Upgrade with Regulator * Fuel Filter Housing Re-plumbed w/ Aeorquip's Teflon -AN 4 hoses & fittings * MagHytek Front & Rear Diff Covers * Royal Purple Full Synthetic Fluids in Tranny, Diffs, Transfer Case*
*Authorized GatorHyde Bedliner Dealer * ExtremeAire Magnum Air Compressor System w/ 14 Gallons of 150psi air
community.webshots.com/user/rooster444
My Axle Tear Down
My Axle Rebuild
Rooster is offline
Old 11-16-2008, 11:28 AM   #6 (permalink)
write the axle code down off the door sticker or the tag number on the rear diff or the vin number and goto the dealer, i have never had a problem getting bearings at work.
Ford certified diesel tech
96 PSD reg cab 4x4 auto 4.10 LS rear xlt. 4" superlift 35" BGF Muds on 16.5 mickey thompsons, dual stabilizers, 3" glass cowl hood, custom american patriot headlinner, Beans stage I's, TS Performance 6 pos. chip, SD HPOP, BB in fuel regulator, custom intake, 3" downpipe, 4" straight pipe exhaust and 5" tip. All aluminum radiator, 6.0 trans cooler. Banks pyro, trans temp and boost gauges on the pillar. TransGo shift kit, billet converter. 10" rear drup bumper, custom droped hitch receiver billet grille, custom front bumper with fog lights and billet grille, diamond cut headlights, clear corners and markers. Viair compressor, one gal. tank and dual air horns.
90 mustang 347 race car.
05 f250 red supercab 6.0, suncoast auto trans, 4x4, long bed fx4, grey interior. atc 275cc injectors, turbonetics ceramic coated 70mm turbo, head studs, aeromotive fuel system, sct with innovative tunes, dual 5" stacks.
fordboyyfm is offline
Old 11-16-2008, 12:29 PM   #7 (permalink)
Thanks guys,that explains the prob very well.
