E350 6.0 Diesel power tuning - Diesel Forum - TheDieselStop.com
post #1 of 14 (permalink) Old 12-21-2010, 10:46 PM Thread Starter
HOWLINMADMIKE's Avatar
I have a 6.0 liter diesel in an E350 Van and I was wondering if anyone make any kind of programing to boost the power. I know it is derated in horsepower from the F series programming. I want to boost horsepower to at least match the F series. Superchip, Bully Dog both say they have nothing for the E series. So is there anyone out there that can reflash or chip the E series.
HMMike
HOWLINMADMIKE is offline
post #2 of 14 (permalink) Old 12-22-2010, 08:55 AM
Band_Member's Avatar
My Photos: (64)
E series is just the body style, no? it still has an 6.0. in it (btw, it helps to put your vehicle info in your signature so others know exactly what you have).
I know one thing about working on 6.0's in vans an its a beyotch because a friend had one. Unless your willing to pay to have the whole body pulled and re-do the factory head bolts with ARP head studs and replace head gaskets (of course), I'd forget about programming it.
And if you go that far you might as well do a complete egr delete, coolant flush and filter, not to mention you're probably wanna get some pillar mounted gauges EGT, Tranny temp if your pulling anything heavy, Boost and an electronic gauge like the Edge Insight, ScanGauge2, etc.....
That programmer doesn't just cost you $500. That's just the tip of the iceberg my friend. when you're all done you might as well add another "0" to the end of that number.
All the best to ya.
2005 F250 XLT SC, LB
6.0 Torqueshift 3.73LS 4x4 T/C
Trk Bld: 02/05/05 KY
Eng Bld: 02/03/05 Indianapolis
2825 Hrs +/-, 101K Miles - No Major Probs other than brakes
DC Power 185 Alternator
ZOODAD, SEIC,
Atlas 40 FICM @ 90K
4" Banks Turbo-Back Duals
3.5" Ready Lift
Bilstein 5100's
315 - 70R17 Duratrac's
Centramatics
Bodiak Front Receiver
SG2
Coolant Filter
HFCM Plug Upgrade
FP Gauge
Zerex Red ELC
Band_Member is offline
post #3 of 14 (permalink) Old 12-22-2010, 09:24 PM Thread Starter
Thanks Band Member I appreciate all of the help.
HMMike
____________________________________________
2006 E350 Van
6.0 liter Diesel
4x4 Conversion
6" Lift
35" Tires
Owner built:
Full length aluminum roof rack
Front winch bumper
Brush Guard
Rear Bumper
Slider Step combination
Custom front dual shock kit
1970 Boss 302 Mustang
2005 22' Thunderjet Alexis Classic
post #4 of 14 (permalink) Old 12-22-2010, 10:00 PM
caissiel's Avatar
I have the Hyperteck Max Energy Series programer on my F250.
Just checked the site and they do have a programer for the 2005 E350.
The Hypertech are guaranteed to not program to hurt your truck and they will increase the HP up to 114HP.
If your van is derated it will increase the power above that rating.
I am very satisfied with the service of my programer and never regrete using it for the last 3 years.
2005 Ford SD F250, 6.0L Diesel, Extended Cab, 4 x 4, 6 Speed, 2 Alternators, 2008 Mirrors, 10,000GVW, Max Energy by Hypertech, ScangaugeII for available 60 XGauges and MPG. 20MPG and 12.6 MPG Towing a 15500Lbs 38ft RV 5th Wheel.
caissiel is offline
post #5 of 14 (permalink) Old 12-23-2010, 09:52 AM
Be careful. Ford de-tuned the E-Series for a reason....heat. More power, more fuel, more heat. Based on what I've read, my van tends to run hotter in the summer than the pickups and regularly hits 215 or more just cruising down the highway cycling the engine fan often. This appears to be normal behavior for my van and if you've ever peaked under the hood or behind the dog box you'll see why heat is an issue. The only reason I'd consider one is for economy, not power, but so far I'm satisfied with what I have.
Good Luck!
Oogs
2004 6.0 E350 Quigley 4x4 w/ Sportsmobile Conversion.
285/75R16 BFG AT/KO. 3.73 Gears.
Dieselsite Coolant Filter.
Aluminess Front/Rear Bumpers.
125W Solar Panel.
Sportsmobile Trailer on 285/75R16 BFG AT/KO tires w/ dual deep cycle marine batteries, water pump, 10 gal water storage, air compressor, storage box & 15W Solar Panel.
SnowMan Mod / Door Seal Mod
"Blue Spring" Upgrade
ridintall is offline
post #6 of 14 (permalink) Old 12-23-2010, 03:20 PM
saline's Avatar
As Ridntall said, the E-series 6.0L is rated at what International designed the engine to run at HP wise. Ford bumped up the HP for the F-series by 85 hp.
04 E 350 Sportsmobile 4x4
6.0L PSD
315/75/16 Toyo Open Country MT's
Dynatrac 60 front/ Dana 70 Powr-loc rear, 4:10's
Atlas II x-fer case
Coolant filter
saline is offline
post #7 of 14 (permalink) Old 12-24-2010, 12:18 PM Thread Starter
Thanks guys I appreciate all of the help. If yo think of anything else please pass it on, I am new to the diesel power tuning
2006 E350 Van
6.0 liter Diesel
4x4 Conversion
6" Lift
35" Tires
Owner built:
Front winch bumper
Brush Guard
Rear Bumper
post #8 of 14 (permalink) Old 12-27-2010, 06:54 PM
Could you post some pics of your van for us?
I'm sure you could get a SCT for it just don't go for any crazy HP tunes
Gumby86 is offline
post #9 of 14 (permalink) Old 12-28-2010, 12:25 PM Thread Starter
Yes I will but right now the only pics I have are of it in 2 wheel drive. As soon as the 4 wheel drive is in I will take a pic and post it.
Thanks for all of the tuning help
HMMike
2006 E350 Van
6.0 liter Diesel
4x4 Conversion
6" Lift
35" Tires
Owner built:
Front winch bumper
Brush Guard
Rear Bumper
post #10 of 14 (permalink) Old 06-14-2012, 10:05 PM
van power
i have a 2005 e-350 6.0 with a diablosport predator on the 60hp adjustment. no increase in mileage using it. i am running a 4.10 gear and i'm getting 15.5-15.8 mpg with amsoil 5w-30 deisel oil and converted to a sportmobile oil filter system, filter and bypass. this is my work van and i run about 30,000 miles per year. i know this is about a year and a half late on responding but i thought i would share. i am thinking about trying a fitch catalyst in the future
doodhere is offline
post #11 of 14 (permalink) Old 06-15-2012, 03:44 PM Thread Starter
Ok guys, here is the rig. Better late then never. After being laid-off and a bout with cancer, here it is to this point.
ID:	14496   Click image for larger version
2006 E350 Van
6.0 liter Diesel
4x4 Conversion
6" Lift
35" Tires
Owner built:
Front winch bumper
Brush Guard
Rear Bumper
post #12 of 14 (permalink) Old 06-17-2012, 04:39 PM
nitrogen's Avatar
nice looking van. if you're confident enough to tackle a conversion like that, working on the engine is well within your skills. as far as excess heat, yes the vans are derated because they just don't have the room to put as heavy duty a cooling system, as what the trucks get. water injection could help hold the heat down. as far as head gaskets go many people have run hot tunes on stock bolts, the thing that they have in common, is a tendency to let it warm up nice before putting the boots to it. or you could just do head studs one at a time, without pulling the motor.
nitrogen is offline
post #13 of 14 (permalink) Old 06-17-2012, 04:48 PM
TousleyParts's Avatar
Personally, I'd still do the whole head stud thing (or be at least prepared to do it) if you run a tuner. Our shop works on just as many stock E series 6.0s as F series 6.0s.
TousleyParts is offline
post #14 of 14 (permalink) Old 06-18-2012, 02:07 PM Thread Starter
Thank guys for the compliments, right now I am having the typical problem of the the sticky or stuck VG turbo. So is it easier to recondition the old turbo or is it easier to replace the turbo?
Thanks for the help
HMMike
2006 E350 Van
6.0 liter Diesel
4x4 Conversion
6" Lift
35" Tires
Owner built:
Front winch bumper
Brush Guard
Rear Bumper
