Old 05-09-2005, 09:14 PM   #1 (permalink)
svt_racer84's Avatar
EBP Sensor Info
Hi Everyone,
When towing the 5th wheel I would get the "turbo fart, chugging/jerking, turbo gauge fluctuating rapidly" problem and am taking it to the dealer in a couple days. I talked to the shop forman and he told me that I will get a new EBP Sensor, something regarding EGR, and maybe a reflash. He told me they got a new flash a few days ago that works on all 6L from 03 to 05. Anyways I would like to know if anyone has gotten the new EBP sensor and if it fixed the "jerking and turbo fluctuating". Also does anyone know what the new flash that came out does? I am worried that if they flash it my mileage will go down. Thanks for the info.
2009 GMC SIERRA 2500HD CREW CAB 153" WB 4X4 SLT 6.6L D.MAX, AUTO, STEEL GRAY, LOADED
08 F-350 K.Ranch SRW 156" 6.4L Blue/Beige (SOLD)
07 F-350 Lariat CC SRW 156" wb 6L Auto White/Beige (SOLD)
05 F-350 Lariat CC SRW 172" wb 6L Auto Beige (SOLD)
03 F-350 King Ranch DRW 172" wb 6L Auto White/Beige (SOLD)
03 Dodge Ram 2500 QC 5.9L Auto Red (SOLD)
03 Dodge Ram 2500 QC Hemi Auto Gold (SOLD)
02 F-350 Lariat CC DRW 172" wb 7.3L Auto Charcol (SOLD)
00 F-350 Lariat CC DRW 172" wb 7.3L Auto Amber (SOLD)
svt_racer84 is offline
Old 05-09-2005, 09:22 PM   #2 (permalink)
Re: EBP Sensor Info
Most likely turbo vanes stuck.
djshum is offline
Old 05-10-2005, 02:29 AM   #3 (permalink)
1SickHarley's Avatar
My Photos: (15)
Re: EBP Sensor Info
I just had everything you said done to mine. And it runs beautifully. I do think however that the new reflash did slow it down a smidge but the driveability is wonderful. Mine used to dump a bunch of blue smoke at idle and jerk an jump and now it's a Caddy on 38's.
NEW TRUCK.... 2007 Jeep Grand Cherokee SRT8 Black, Magnaflow Exhaust, Volant Cold Air Intake, and a nice system....
GO GATORS!!! 2007 National Champs Baby!! Ummm... Football AND Basketball
04 Harley Edition Solid Black, 8" Fabtech shocks and hangers and ladder bars, Superlift Springs, 38x15.50x20 Toyo Open Country M/T's, Weld 20x12 Cheyanne 8 rims, Fabtech Ladder Bars, AFE Intake, straight exhaust, SCT with Extreme Street from Eric at Innovative, Full SunCoast setup, SPEARCO INTERCOOLER(Thanks BBunting), Mag Hytec Tranny Pan, GReddy Turbo Timer,Alpine IVAD300 Flip out DVD player, Alpine 5 channel amp, JL 6x8 Seperates, JL Audio 12W7 Sub., JL Audio 500.1 amp., ISSPRO triple guages, sunroof, diff covers powder coated comp. orange, 03 Turbo, and oh yeah... 2005 Harley Edition Headlights.
My truck pics... http://community.webshots.com/user/1SickHarley
1SickHarley is offline
Old 05-11-2005, 08:17 AM   #4 (permalink)
Re: EBP Sensor Info
I just had mine reflashed with the latest for a "Romping/Bucking and jerking issue. It made the engine quiter and seems to be giving me better mileage. However, it has not solved my romp issue. I am at about wits end with the romping. It gets down right dangerous, I feel like I might run someone over if I'm not paying attention. I think if these techs would actually take the time to diagnose the problem instead of just doing a reflash everytime the 6.0 farts we all might get somewhere! [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
2004 Excursion 4x4 Limited 6.0L PSD (stock engine)
Helwig Rear Anti-Sway, Timbren Load Boosters, ISSPRO A-Pilar mounted guages - Pyro/Trans/Boost
Prodigy Brake Controller
Hauling: 35' Forest River Sierra Camper w/ Hensley Arrow Hitch (simply amazing hitch)
gawent is offline
Old 05-11-2005, 09:02 AM   #5 (permalink)
YODA's Avatar
My Photos: (14)
Re: EBP Sensor Info
gawent - what oil weight are you running. If it is the 15-40 switch to the 10-30 and see what happens. This really helped mine, especially on cold mornings.
Now to the issue here I found this on the dieselmans site
2003-05 Various Running Problems, Check Engine Light; New EBP Sensor:
Trucks built before 1-17-05 that exhibit buck/jerk, hesitation, lack of power, stalling, stumble, black smoke, surging, rolling idle, changes in engine sound at idle or when driving at a steady speed, or with the trouble codes P2263 or P0299, may have an exhaust backpressure sensor signal that is incorrect or erratic. A revised EBP sensor is available if this is found to be the case. Part number 4C3Z-9J460-A. Broadcast Message 3815.
Normal EBP signal reading should reflect atmospheric pressure with the key on/ engine off. Typically, this is 14.7 PSI/0.88-0.9 volts at sea level, decreasing one PSI/0.10 volt for every 2000 feet of elevation. It should be within 0.5 PSI of BARO and MAP sensor pressure signals.
also this
2004 F-Series and Excursion Built After 9-30-03, Various Driveability Concerns:
Trucks that exhibit surge at idle, changes in engine sound at idle (EGR cycling), low power/smoke/rough idle on cold start that corrects when engine warms up, surge when selecting resume on the cruise control, flutter noise from engine just before transmission kickdown, buck/surge on manual transmission, should be reprogrammed with the latest calibration. This program includes a reduced EGR valve on-time during extended idle. The WDS must have release version 36.10 or higher, or 37.10 or higher, but not version 37.0 to have the correct calibration update. Broadcast Message 4118.
here is the direct link - good reading
http://www.intellidog.com/dieselmann/60bulletin.htm
Hope this helps
[img]/ubbthreads/images/graemlins/laugh.gif[/img] 2004 / 04 F350 CC PSD 4x4 Chestnut Brown King Ranch, Quad Captains, DUALLY [img]/ubbthreads/images/graemlins/laugh.gif[/img], long bed, auto, 4:10LS
Goodies added.
Retrax bed cover [img]/ubbthreads/images/graemlins/laugh.gif[/img]
Bed Rug bed liner
KC backup lights
C-Better mirrors
Prodigy Controller
Reese bed rails, bolt on frame install kit
Viair 550C air compressor and 2.5 gal tank
Grover 34 and 36 inch air horns
Pro Flap mud flaps
Autometer cobalt gauges with under cubby pod
Galaxy 95T CB, Wilson 5000 roof mount antenna
DPPI Cat Back Dual Exhaust [img]/ubbthreads/images/graemlins/laugh.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img]
YODA is offline
