Old 07-22-2009, 06:38 PM   #1 (permalink)
EGR Cooler??
Could someone please wxplain to me what happens when the egr cooler is going bad. My 04 has loss of power. If I put the throttle to the floor it revs but doesn't get up and go. When it shifts into overdrive it seems sluggish and kind of bucks back and forth like a gasoline with no power. Computer shows 2 egr codes but I put a new one in and it did nothing. Any help is appreciated!!
onyx is offline
Old 07-22-2009, 06:49 PM   #2 (permalink)
Supporting Member
PowerstrokeConverters's Avatar
My Photos: (23)
Send a message via MSN to PowerstrokeConverters Send a message via Skype™ to PowerstrokeConverters
you most likely have the dreaded stuck turbo vanes issue, probably need to take that apart to clean it up also the restrictive oil drain tube can be replaced to a upgraded one from Ford part #PN 6C3Z-9T515-A
If you can find a turbo from a 2007 that would be perfect.
Also a new EGR cooler part # PN 4C3Z-9P456-AF
2000 F-350 7.3 PS ,4R100 Lariat Dually
http://i829.photobucket.com/albums/z...DSC02732-1.jpg
4x2 LB 3.73 gears, 115k miles(better than new)
6" Fabtech lift w/ duall steering stabilizers
22.5 polished Freightliner wheels
Triple Clutch Triple Bearings Billet Low stall Converter.
Wicked Wheel
Full Turbo back 4'' exhaust,
Triple Autometer Phantom gauges on pillar,
Now using SCT 100hp Performance tune.
Wastegate disconnected for now...
2005 front clip.
Train horns.
Zoodad mod.
CFM-plus
CCV rerouted
S&B CAI
IC pipe ceramic coated w/ foil delete
Inlet heater deleted.
3 tv's + Backup Camera,DVD,Nav.,Satelite Music.
Jason smooth topper.
Here but not installed: 4'' Ported Housing,ATS 1.00 a/r, non-ebv pedestal and outlet,turbo master actuator,203 thermo.,billet thermo. inlet.,TRU Cool tranny cooler (no time )
Pictures:http://photobucket.com/2000_F350
PowerstrokeConverters is offline
Old 07-22-2009, 06:50 PM   #3 (permalink)
Supporting Member
My Photos: (23)
DieselPower magazine July 09 issue.
Wicked Wheel
2005 front clip.
Train horns.
Zoodad mod.
CFM-plus
CCV rerouted
S&B CAI
Old 07-22-2009, 06:52 PM   #4 (permalink)
Supporting Member
My Photos: (23)
Tool to remove EGR valve Ford part# 303-760
Wicked Wheel
2005 front clip.
Train horns.
Zoodad mod.
CFM-plus
CCV rerouted
S&B CAI
Old 07-22-2009, 07:50 PM   #5 (permalink)
Thank You! I'm gonna look up that magazine issue. Is this a job that a non mechanic can do? Is it expensive to bring it in?
onyx is offline
Old 07-22-2009, 08:19 PM   #6 (permalink)
Supporting Member
My Photos: (23)
Not sure, I have a 7.3
The egr valve should be pretty easy w/ the right tool, might as well get the tool you will need it often.
Wicked Wheel
2005 front clip.
Train horns.
Zoodad mod.
CFM-plus
CCV rerouted
S&B CAI
