EGR cooler delete + new oil cooler= no boost - Diesel Forum - TheDieselStop.com
Old 11-05-2009, 01:53 PM   #1 (permalink)
Truck started fine, seemed to run OK. Took it out for a spin and no boost. The pipes coming and going from the turbo to the intercooler aren't warm as they normally are. I rechecked all sensor plugs are connected. What could be causing no boost, it worked fine before I started this project?
~2004 F-250 Quad cab long bed, 6.0L PSD,4x4 ~Torqshift Trans
~Arizona beige,tan interior
~Running boards w/custom Piranha LED lights
~ARE bedcap, Bedrug
~Foglight/high beam mod,BriteBox,HD light harness
~Zoodad mod, High idle mod
~Coolant filter, Oilguard bypass filter, Fumoto
~Isspro pyro,trans temp,boost in A-pillar
~Marinco Block Heater Receptacle
~Bodiak front hitch
~Mag-Hytec rear diff cover w/6qts syn fluid
~250 watt oilpan heater
~Scanguage
barnbridge is offline
Old 11-05-2009, 03:32 PM   #2 (permalink)
Fixed- I forgot to attach the turbo hose to the intercooler under the air filter. Doh!
~ARE bedcap, Bedrug
~Bodiak front hitch
~Scanguage
Old 11-05-2009, 08:20 PM   #3 (permalink)
hey about the *** delete was it hard about how many hours n any tips to watch out for when doing it im at the point of the delete soon thanks
turbodieselny is offline
Old 11-05-2009, 11:29 PM   #4 (permalink)
Nice At least you figured it out....
2005 F250 LARIAT CC 4X4 6.0L PARROT CK3200 bluetooth car kit, Shaker 500 system, nice set of train horns, twin viair compressors and 5gal tank, 5" MBRP turbo back, AFE stage II intake, SCT tuner.
1996 F350 AT, IDM and switched ICP mod
1995 F250 SC AT, IDM and switched ICP mod, 6" susp 2" body lifts.
1994.5 F250 SC 5spd 4x4 IDM and ICP mod
bondsman is offline
