Pull the EGR valve, it's two 8mm bolts and is located in front of the top oil filter housing. I created a thread about how to do it. If you see wetness in there, it's coolant and indicates an EGR cooler failure.
If you let the EGR cooler failure continue, it may cause problems with the oil cooler and other parts since the Engine Oil Temp (EOT) and Engine Coolant Temp (ECT) should remain within 15-25 degrees of each other.
2005 F350 turbo diesel Lariat 4x4 ext cab, short bed, SCT x2, MBRP turbo back, WeatherGuard box, the "beagle hauler".
1965 Factory Five Spyder GT, the 2nd one built out of 39 total. No top, no windows, no radio, no mufflers. Yeah, it's sweet.
Reason: typo EGT --> ECT (thanks for the catch)
