Egr Cooler Symptoms - Diesel Forum - TheDieselStop.com
Old 06-27-2007, 02:47 AM   #1 (permalink)
Egr Cooler Symptoms
How could one tell if the EGR cooler is failing? I have a coolant/silicone type smell coming from my vents after a shutdown of 2 hours or more. The coolant level doesn't seem to be going down. It is a very noticeable odor. If the heater core goes, would you smell coolant through the vents? I can't physically see any leaks. I just had the EGR valve replaced, the smell seemed to go away but now its back everday. I know I asked this similiar question 2 weeks ago.
60000 miles on it.
K3 F350 6.0l 4x4, Crew cab, Lariat, shortbox, T.red, 285 BFG All Terrains, Sirius Radio, SS Grille, Silverstar fog and headlights, Boost and Fuel pressure gauges-Lunar Series Autometer. KYB MonoMax shocks 5w40 Delvac 1 14.7 mpg town.
Sushibar is offline
Old 06-27-2007, 04:05 AM   #2 (permalink)
Banned
Re: Egr Cooler Symptoms
There is a test procedure to check the EGR cooler.... Without this procedure, one can only guess....
Having said that, coolant loss can indicate an EGR cooler failure....but it can also indicate a lot of other things, too....
GrampyJim is offline
Old 06-27-2007, 08:47 AM   #3 (permalink)
My Photos: (38)
Take a look at the EGR cooler hose, located at the back of the oil cooler underneath the hot side CAC pipe connection to the turbo. If it is orange, take a real good look around each end and the block underneath for coolant residue.
When these EGR cooler hoses leak, they tend to only leak while the motor is cool or cooling down, and only when the pressure on the system is relatively low.
What sig?
GregH is offline
Old 06-27-2007, 11:17 AM   #4 (permalink)
the orange hose sounds interesting as I can only smell it when cool. I will check.
Thanks guys.
Jon.
Sushibar is offline
Old 07-08-2007, 04:45 PM   #5 (permalink)
sbuck's Avatar
Were is the egr cooler and the cac pipe
BOY DO I LOVE MY POWER STROKE Why didn't I buy a Cummins
10 EGR Valves
4 EGR Cleanings
1 EGR Cooler
2 Warped Heads
2 Blown Head Gaskets
2 Degas Bottles
1 Cracked turbo inlet pipe
2 Turbo cleaning
3 Exhaust back pressure sensors
1 PCM
1 EGR Valve wiring harness
new turbo
Entire Engine Wiring harness
2004 F350 Silver Crew Cab
Motor is bone stock
sbuck is offline
