Old 10-20-2009, 12:29 AM   #1 (permalink)
4x4grey88's Avatar
EGR cooler vs Bad head gasket info
How can I tell if I have a bad EGR cooler vs and bad head gasket?
I was towing my Jeep to the desert. My truck over heated. When I added coolant everything seemed fine, so I continued towing. I towed my Jeep back home and still everything is fine. I turned off the truck to unload the Jeep and when I restarted the truck it billowed out white smoke.
I turned off the engine and left it to cool overnight. In the morning I checked inside the EGR and found a small bit of liquid. Reinstalled the EGR and started the engine. I puffed a small (muck less then the night before) amount of white smoke at idle and reduced when up to temp.
I am wondering if I have a bad head gasket or EGR cooler, or both.
I live in San Diego and am looking for a good reputable mechanic for repairing. Anyone have any ideas? I really don't want to go to the Ford unless I have to.
2003 F250 diesel 6.0L, crew cab, stock 145K
I have changed out the ICP, changed the oil, coolant, all filters and learning much more about the diesel world
4x4grey88 is offline
Old 10-20-2009, 01:54 AM   #2 (permalink)
Liquid in the EGR passages is a blown cooler. You cannot diagnose head gaskets without having the cooler repaired. If the EGR cooler is blown, the Oil cooler MUST be replaced and the cooling system thuroughly flushed.
Dad always said,"Knowledge is limited but stupidity knows no bounds."
YT90SC is offline
