EGR Delete - Diesel Forum - TheDieselStop.com
Old 11-16-2012, 09:42 PM   #1 (permalink)
wedge45's Avatar
EGR Delete
Can someone fill me in on the benefits or drawbacks of making this modification..... I just had to replace injectors and now the FICM is bad, so i'm thinking Atlas 40 from FICM repair.com..... Any input on the EGR delete and how it's done would be greaat..... thanks Wedge
2006 f-350 Lariet, LB, 6" Fab-Tech, 35 toyo's on 18" MKW, Banks Turbo back Exhaust, AFE Cold Air intake, Atlas 40 by FICM repair
wedge45 is offline   Reply With Quote
Old 11-16-2012, 11:59 PM   #2 (permalink)
Iam4MSU's Avatar
Google youtube videos on EGR deletes for the 6.0L powerstroke. You can see how easy (hehehehe) it is. I just changed my EGR cooler with a sinister cooler but I also changed the oil cooler, added a coolant filter, cleaned polished and greased the turbo, newglow plug harness, boiled the intake manifold and cleaned the EGR valve. The FICM is at Ed's now to be repaired as it would not crank cold. You had to plug it in to crank it.
Sinister basic solutions kit.
2004 F250 Crew Cab King Ranch Lariat FX4 Saddle Leather 6.0 L FUMOTO Valve
AIRAID 4" straight No CAT No MUFF
Nitto Terra Grapplers All Terrain LT285/75R16 10 PR Everything else pretty much stock
NEW Ranchos installed 8/15/2010
WORK IN PROGRESS - R&R EGR COOLER, OIL COOLER, THERMOSTAT, TURBO BOLTS, GASKETS, ORINGS, and adding a COOLANT FILTER WITH NEW COOLANT AND FLUSH
Anyone Got Birds? Will Travel to Hunt!
We are all just Village Idiots,
Enamoured with our own shadow,
Oblivious to the setting sun!
Iam4MSU is offline   Reply With Quote
Old 11-17-2012, 03:12 PM   #3 (permalink)
Yea, i would not say it was easy... It wasn`t complicated but not easy. If you are in a state that does not emission test then imho it is a must do. Take the time to do the research. As far as what you should do just look at peoples post signatures. This will tell you what they thought was important.
Member # 23075 Reged: 07/18/02
2005 Excursion w/ 6.0L PSD - Edge Insight, RCD EGR delete, Turbo Drain/Blue Spring/Oil Cooler Updates, Dfuser Coolant Filter, 240amp alt, fumoto.
2008 FX4 F250 CCSB w/ 6.4L PSD - Edge Insight, H13 Bi-HIDs, custom coolant filter, fumoto.
rock_doctor is offline   Reply With Quote
