Well I know this engine either has a DPFE sensor, or an Exhaust Back Pressure sensor. I came to this conclusion because, if you look on the drivers side exhaust manifold, there's a tube that goes up to the thermostat on the engine, and then there's a sensor on that tube. This leads me to believe one of the two options i said a few lines ago is present. I guess I'll just have to wait and see. I'm asking this because I know on the 04-07 6.0L there is a DPFE sensor because a friend of mine had a CEL for the sensor. Now I've heard that the early (03.5 to 04) "Cali" trucks have some of the items that the upgraded 6.0L engines came out with later. I will let you all know what I come up with in the next few days when my delete kit gets here.
i hav a 2004 f350 with a late 2003 6.0 i deleted EGR and got no CE light
Most 04 wont throw CE light... Some do some dont. 05s do, mine did lol. Use a programer to clear it. Or what I did was kept the delete in zip tied the egr vlv down and plugged the sensor in again. That works to clear it.
'05 F250
Banks Turbo back Exhaust
Bilstien Shocks
EGR delete
SCT tuner 3015
Edge CS Insight
Blue Spring Upgrade
Alternator
High Idle Mod
STC Upgrade
Pipe Stand Upgrade
water pump
Idler pulleys
Head Gaskets
Head Studs
On the '03 to early '04 6.0 the trucks did not get a check engine light if the eye valve was pulled out or unplugged. '05 and up trucks were programmed so that they would throw a CEL if the the egr system was tampered with. HOWEVER, the catch is any truck built for sale in California was programmed so if the egr cooler was taken out, there would be a CEL.
I left my EGR valve in, but removed the cooler and received a CEL. I ended up getting an SCT iTSX and turned the EGR off. No more CEL, and no more possibility of the cooler leaking coolant.
2004 F250 XLT Crew Cab 6.0L Powerstroke
-Sinister EGR Delete
-Straight Pipe
-On-Board Air
-EGT, Boost, Fuel Pressure Gauges
-Scan-Gauge 2 monitoring EOT, ECT, Trans Temp, Intake Temp
-Idle-Up Mod
-GP FICM
-1000W Power-in-Cab
-Emergency Lighting
-Aftermaket Cab-Clearance Lights
-Blizzard 8'6" Plow
-New Passanger Side Injectors
-updated 6.4 Fuel Pump
-Blue Spring Mod
-Additional Leaf in Front
FUTURE:
-Headstuds & Gaskets
-New Drivers Side Injectors
-Water/Meth Injection
Can you be more specific about how you zip tied it closed? Did you reinstall the valve in the intake? Or is it hanging outside?
2006 F250 Lariat Supercrew, ESOF 4x4, 18" tires, FX 4, HD Alt., block heater, Integrated Trailer Brake Controller, Upfitters, power rear window, cab lights - delivered 10/25/05
Ford Remote Start; High idle mod; Timbren load levelers, Scangauge II, Blue Spring upgrade, Quick Start 200 amp large frame alternator replacement, 2 batteries; GPCM replace October 2011; 2 EGR valves; EGR Cooler replaced 12/30/11; Performance Machine & Mfg. coolant filter added 1/2/12; Rotella T6 5W40 oil; turned rotors and replaced brake pads for 1st time 1/7/12 101K miles; GPCM, both subharnesses and all 8 glowplugs replaced 1/5/13 at 118,000 miles; 2 Ford batteries replaced under battery warranty.
He means...his delete kit had a plate that covered over the egr hole in the intake. So he just zip tied the valve to something on top of the engine and plugged it back in. When i did my delete i just left the valve in place and plugged in. You still have to use a programmer to stop the CEL light on 05 and newer trucks and some 04s... All years need to have the valve plugged in. For some reason if you unplug it and leave it unplugged it effects how the cooling fan operates.
I have my 06 deleted, I left the valve in because it doesn't really matter, the valve just operqates as normal but no exhaust gasses are coming in... I have a SCT and the tune deletes the other egr codes...
Yeah. The block off plate is installed. But the eft vlv sits on top. Zip tied right there. It gets air flow just for the natural air around it. It thinks it's installed and not lol. I have a tuner and will get the innovative diesel tunes soon but it was a lot of money to do it all at once. Been there also a year no cel. Life caught up and and to make a delay. But still no cel. I check for codes very month or so still none. Also if it is just unplugged the computer sees it as an open in the circuit which throws the cel. Pull it out, plug it in and find a nice spot for it to sit and snug it down. Good to go. Poor man fix
'05 F250
Bilstien Shocks
EGR delete
SCT tuner 3015
Edge CS Insight
Blue Spring Upgrade
Alternator
High Idle Mod
STC Upgrade
Pipe Stand Upgrade
water pump
Idler pulleys
Head Gaskets
Head Studs
