egr delete/ check engine light??? - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 09-23-2010, 09:36 PM Thread Starter
High Performance Kennels's Avatar
I have a 06 PSD and I just did an egr delete and head studs. But, the check engine light keeps comming on? I am assuming because of the fact that I deleted the egr. How can I get the light to turn off? It is driving me crazy! I don't care if the light never lights up anymore. Is there a wire I can cut or something!?!?!?
1994 F-350 IDI, Propane, Turbo Housing, Impeler, 4inch str8 pipe,4inch lift,35x12.50x16.5 BFG MT, Ranch Hand Bumpers Front and Rear.
High Performance Kennels is offline
post #2 of 10 (permalink) Old 09-23-2010, 09:55 PM
.. I just learned to deal with it. I assume you could take the dash apart and remove the bulb, might do that when I replace my stereo. Most 05+ trucks will throw a check engine light with a delete kit. I'm not going to pay $$$ for a programmer just to get the check engine light to shut off.
06 F-250 x/c 4X4 sb 17" alloy wheels. Tri-fold tonneau cover, weathertech vent visor,Ford floormats and splash guards. HarleyD headlights, Duplicolor bedliner coated bumpers, 08 rear bumper and taillights, herculiner rocker panels, XM radio, bosch wipers, Recon smoked cab lights, Edge Insight w/EGT probe, winter front.
06/10 ARP studs, turbo back silverline, new head gaskets, new oil cooler, upgraded turbo drain, fuel pressure reg upgrade, coolant filter, high idle mod, harpoon mod, pre-pump spin on fuel filter,ELC coolant, 6.4 banjo bolts, CCV reroute.
Truck weight empty fueled up, 4440 Front, 3040 rear, 7480 gross. Hex VXCF4,
SCT w/customs tunes from Vivian at Quick Tricks and Matt @ gearhead
worldwide73 is offline
post #3 of 10 (permalink) Old 09-24-2010, 12:00 AM
me too, wish I knew about the delete throwing CEL, my installer said the EX should not have but now I'm stuck with it as well. Not buying a controller!Go with the bullet proof I would have.
04 Excursion EB 6.0 195Kmiles
stargazing is offline
post #4 of 10 (permalink) Old 09-24-2010, 12:34 AM
cmirabile's Avatar
My Photos: (9)
why don't you just plug the egr in and leave it there?
not very aesthetically pleasing but the light will go away
2005 F-350 XLT PowerStroke Diesel FX4
SCT Xcalibrator2 with Tunes from Innovative Diesel
37 X 12.5 BFG Mud Terrains
5% 3M Tinting
Viper 791XV with Remote Start
152dB Kleinn 3-Trumpet Horn System
Dakota Digital Gauges
T409 MBRP Straight Pipe
AFE Stage II Intake
HARPOONED Fuel Tank
2003 10 Vane Turbocharger
Blacked Out Harley-Davidson Edition Headlamps
ARP Head Studs
AVIC-Z2 In-Dash Navigation System
205cc Elite Sticks
Coolant Filter
Elite Regulated Return Fuel System
FS2500 Oil Filter
HPOP STC Replaced
cmirabile is offline
post #5 of 10 (permalink) Old 09-24-2010, 12:42 AM
calabrese19's Avatar
I have not done this... But what about measuring resistance on the egr and placing a resistor inline to make the computer think its there
Tony
06 F350 Fx4 PSD
ARP HeadStuds - AEM BruteForce intake - MBRP 4" turboback-EGR delete - Ford blue fuel spring - 6.4 banjos - diy ccv
Viper 5900 remote start/alarm w/ one mile range - Pioneer D3 nav - 2500 watt power inverter - Harley headlights - Recon smoked cab lights - ebay 2.5" axle mounted leveling kit
DieselSite coolant filter- added at 39k
8ft WESTERN Pro-Plus w/ back drag blade
6000k slim ballast hi/lo H13 headlights and H10 fog HID kits from ddmtuning.com
to be done mods.. Innovative SCT X3, Edge Insight CTS w/ egt, oil bypass
88 mustang hatch- 347 stroker - for the strip
88 mustang vert- 4.6 DOHC gt-45 turbo - street car
calabrese19 is offline
post #6 of 10 (permalink) Old 09-24-2010, 06:26 AM
CAMPINGTOM's Avatar
The light won't go away on all trucks. Some 2005s and most 2006 and 2007s the light stays on. You need a tuner to turn it off. Also, some trucks go in to "EPA limp mode".
I got an SCT to disable the EGR function. I wasn't prepared to get a tuner either, but in the limp mode the engine has less power and only about 21 psi of boost. A tuner can make the truck quit looking for EGR and not produce extra hp. I got a no extra hp tune, a towing tune and mild street tune since I do not have studs (yet).
One more thing, a tech on another site found out that even with the tune, if you leave the EGR valve unplugged, the fan clutch will not engage 100%.
2005 F-250 6.0
4" Straight Pipe, CCV Reroute, Coolant Filter, Sinister EGR, Insight Monitor, SCT X3 (Tuned by Innovative)
Blue Spring, Atlas 40 FICM Tune
CAMPINGTOM is offline
post #7 of 10 (permalink) Old 09-24-2010, 09:38 AM
mine is plugged in and reinstalled in manifold, still a CEL!
post #8 of 10 (permalink) Old 09-24-2010, 10:00 AM
cmirabile's Avatar
My Photos: (9)
Why won't it work? The only reason the light comes on is because it does not recieve the valve position. The computer has no idea there is no manifold in the truck.
You cannot just put a resistor in the plug because the resistance varies with the valve position. The PCM sends a duty cycle to the valve and it opens to that position. The resistiance for that position is then measured to make sure it moved to the right position
5% 3M Tinting
AFE Stage II Intake
HARPOONED Fuel Tank
ARP Head Studs
205cc Elite Sticks
Coolant Filter
FS2500 Oil Filter
HPOP STC Replaced
post #9 of 10 (permalink) Old 09-24-2010, 02:15 PM
CAMPINGTOM's Avatar
I don't think that's true. The P0401 code is EGR insufficient flow. I THINK the computer needs to differences in IAT temp etc. If it doesn't, it throws the code.
I am by no means an expert in any of this, just stating me experience.
With the valve installed and not tuned, I get the code (and limp mode).
2005 F-250 6.0
post #10 of 10 (permalink) Old 09-25-2010, 11:23 AM
How do you know if your in limp mode?
