EGR Opens @ What RPMs? - Diesel Forum - TheDieselStop.com
Old 09-06-2006, 04:08 PM   #1 (permalink)
1. Just curious if anyone knows when the EGR valve is recirculating the exhaust i.e. what rpms
and
2. Is it tied to fuel delivery or just rpms? i.e. if you're totally off the throttle, say going down a hill, is it opening and closing based on throttle position or staying in a position based on indicted motor rpms?
Thanks in advance.
05 F-350, PSD, 4x4, Crew Cab,6-Speed
2" Front Level Kit, Pro Comp ES9000 Shocks
Firestone Model 2400 Airbags (horrid engineering)
Tow 30' Toyhauler
*-Friends don't let Friends run Crap-lisle Trailer Tires
Rich807 is offline
Old 09-06-2006, 04:15 PM   #2 (permalink)
Re: EGR Opens @ What RPMs?
Maybe throttle position too? I know when going down hill or coasting if I come up off the pedal the truck gets bone quiet.
04 F-250 6.0 FX4 XLT CrewCab. ESOF. White over Silver. Alum wheels. 3.73. PC78Elite CB w/Wilson 1000. Fumoto quick drain oil valve. Access Cover bed cover. Carry's around two of the greatest little boys in the world!
Engine Born on 12/22/03
Truck Born on 01/04
Truck Purchased 11/4/04
TimsDiesel is offline
Old 09-06-2006, 04:47 PM   #3 (permalink)
There probably several parameters that determine when and how much the EGR valve is opened. One that is very important is that the Manifold pressure has to be less than the exhaust back pressure. I see no reason for the EGR to open under deceleration if it's stated purpose is to dilute and cool the combustion process to reduce NOx.
Tim,
When you are coasting, the fuel is shut off so all your 6.0 is doing is pumping air.
2003 F250 XLT Sport Ext Cab ESOF FX4 6.0L TorqShift, Sonic Blue/Black Leather.
BrakeSmart Trailer Brake controller.
Leer Cab high Browning Edition Cap.
2004 SunnyBrook Solanta 28' TT small slide 7800#
35 Years in the trenches!
Retired Machinist & Manufacturing Engineer for fuel control systems for very large Diesel Engines. Locomotives to Super Tankers.
Designed and trouble shot manufacturing processes for stuff from Design Engineers. Sometimes had to wrestle for design changes.
Designed and built tools and equipment to machine, assemble, disassemble, repair and test.
Wisdom comes with age, but sometimes age comes alone.
"Nothing is FOOLPROOF because fools are too ingenious"-Mark Twain
johnmart is offline
Old 09-06-2006, 05:44 PM   #4 (permalink)
Cool, that makes sense. Thanks.
Truck Born on 01/04
Old 09-07-2006, 06:42 AM   #5 (permalink)
Tim,
I've driven around with the Ford WDS in cab computer hooked up and with this you can actually see EGR opening and how much open. At full throttle it's either closed or mostly closed, at idle is is mostly open and often fully open. RPM, throttle position, EBP, all factor in.
In real world information useful to you, the less time spent at idle the less the EGR is open and the less there is to get the infamous EGR build up......so don't idle much, keep it at full power [img]/ubbthreads/images/graemlins/grin.gif[/img] and your truck will run better.
Additionally I have tinkered with the TS and Quadzilla go fast boxes and I notice that the box alters timing and fuel mixture so the EGR gets confused and tries to compensate with much sooner and much higher EGR openings. This I'm sure of.
SCT claims they can alter EGR openings and timing in the lesser amount but this will "fubar" EPA emissions......if that sort of thing bothers you.
Back to reality. A stuck open EGR will "fubar" everything, emissions, MPG, power, longevity etc.
Too much junk/toys to mention, ever changing due to too getting bored too quickly. I need a 10 step program!
Want to call? I'm in the book. Want to argue....First explain the square root of negative one....lol
roofeditor is offline
Old 09-07-2006, 11:18 AM   #6 (permalink)
Good post.
Tow 30' Toyhauler
Rich807 is offline
Old 09-09-2006, 01:40 PM   #7 (permalink)
Btravelen's Avatar
I have seen a list of flash updates for the 6.0L and one included a new EGR strategy of limiting the EGR being open at idle. I have also seen discussion of this in the forums, but now I can't seem to find it.
I don't believe it's correct to say that at idle the EGR is open and stays open. The computer limits the the amount of 'open' the EGR is at idle. Maybe a tech with knowlege of this will chime in.
'05 Excursion 6.0L with Air Lifts and Bilsteins, high idle mod., only 'tuner' is in the radio, towing an '00 HR Alumascape 31SKS with a Hensley.
Btravelen is offline
Old 09-09-2006, 02:42 PM   #8 (permalink)
teamroper60's Avatar
Depending on which flash a person has, it is possible for the EGR to be open at idle. Ford tried that as a way to quiet the idle. They have since changed their minds on that, due to clogging.............. (imagine that!! LOL)
pics
#43
SLAPS President and Webmaster
teamroper60 is offline
Old 09-09-2006, 07:38 PM   #9 (permalink)
Same here on both counts. Still hoping either a knowledgable tech or speed shop person will chime in on when this thing is actually open and closed.
Tow 30' Toyhauler
Rich807 is offline
