Old 06-01-2008, 07:09 PM   #1 (permalink)
skirk55's Avatar
EGR Valve
I cleaned the EGR valve in my 2005 F350 6.0 and what a mess! It was almost plugged up. How often do I need to clean it? Will it run any better clean? Is it worth cleaning it?
skirk55 is offline
Old 06-01-2008, 07:58 PM   #2 (permalink)
I clean mine and the manifold as best I can once a year, which usually is about 20K. I can,t prove that it does any good or runs any better. But I feel its good preventitive maintenance. I have not had any problems with it since doing this. This reminds me that its about time to do it again.
2004 F-350 Lariat, Supercab 4X4 FX4, DRW
Dark Toreador Red/Silver, 6.0L, Torqueshift Auto, ESOF, 4.10 LS, Camper Package, Dual Alternators. Build Date 6-8-04, Eng 5-28-04, Lance 9.5 Ft Camper.
Past 2002 F-350 Lariat, Supercab 4X4, Toreador
Red, 7.3L, Auto, DRW, Fully Loaded.
Past 94.5 F-250 Lariat, Supercab 4X4, 5 spd 7.3L PSD.
DRJ48 is offline
Old 06-01-2008, 09:05 PM   #3 (permalink)
I agree - except my interval is 30k (just did it and it was filthy) - unless I find at 60k the ccv re-route has made a big difference.
Mark
'06 F250, CC SB ESOF FX4 Lariat 3.73LS, 275/65R20
DieselSite Coolant Filter; High Idle Mod
Zoodad/Air Fury grill; Accufab Elbow; Racor CCV filter
Fumoto valve; HFCM Plug; Harpooned fuel tank
JimmiJammers; Ravelco; Britebox; DashDAQ
Quadzilla recon XZT Fuel Pressure; BB mod
Synchromax in transfer case; Reflashed
Line-X, CPOhighway Prod. tool box; tracrac
Fox Weatherboots; Wet Okole Seat Covers
Stanadyne Perf. & B2 for lubricity
Updated EGR valve; PIE adapter; 24" wiper blades
bismic is offline
Old 06-01-2008, 09:45 PM   #4 (permalink)
I,d bet that cuts the filth in half. Not to mention the CAC boot problems it eliminates. I just havn,t found the time yet to do it myself. Its in the near future though.
DRJ48 is offline
Old 06-02-2008, 04:26 AM   #5 (permalink)
My ccv re-route is to a frame rail filter element and then back to the same turbo inlet tube. The hose run to the filter element is an initial vertical rise up and over the brake master cylinder and then a long constant vertical drop to the filter (no liquid legs in the hose run). The return line is a long constant vertical rise. This configuration is to maximize liquid disengagement from the vent lines and to eliminate backpressure from liquid legs caused by dips and rises on the same run of hose. It took awhile to saturate the filter element (maybe a month) but now I am constantly draining oil from the filter drain valve. I have gotten at least 1/2 cup of oil. I have had it installed for about 3 months.
So far I am very pleased.
Mark
bismic is offline
Old 06-02-2008, 07:25 PM   #6 (permalink)
Bismic, what did you use for a filter?
elee3 is offline
Old 06-02-2008, 08:22 PM   #7 (permalink)
RatherBNtheWoods's Avatar
I was going to ask the same Q
Our Raptor RV
2006 F350 CC LWB Dually XLT Oxford white manual 4x4 6.0 PSD 6 speed. 4.10 LS front and rear, Built May05. 4" turbo back, 100gal aux fuel tank. A real pig from a stop, but give me 10' and she'll lite'em up.
150K miles, 12 injectors, EGR cooler, Fuel pump, 8glow plugs, GPCM, FICM rebuilt FoMoCo longblock under 7/200 warranty.
RatherBNtheWoods is offline
Old 06-02-2008, 10:54 PM   #8 (permalink)
I odered mine from an individual ($85 plus shipping - probably a little high for what you get, but the total cost of the mod was $158.19):
email NCHornet (walknmiracle@triad.rr.com) on:
Ford Powerstroke Diesel Forum
He makes the filter out of PVC and with his own filter media.
This is a good thread on the mod (with pictures):
http://www.***************.com/forums/showthread.php?t=15797
Also - I have my own pictures and install instructions if you go this route.
You can also get a Racor Filter:
http://www.maesco.com/products/racor/r_ccv_intro/r_ccv_intro.html
This is what NCHornet says about his filter (and I have found it to be true so far):
Since the filter media inside the filter is new, it may take 10k miles before enough oil is accumulated to drain from the pet **** on the bottom of the filter. After that, you should drain it every oil change. The amount of oil will vary from truck-to-truck, but on average, you should see 1-3 tablespoons in 5k miles. If you ever have more than this, then check to make sure you still have the "high point" in the hose around the degas bottle or master cylinder. If you lose this high point, more oil will leave the crank case and the filter will fill up more quickly.
The filter media never needs to be changed.
Mark
bismic is offline
