Engine Block Heater Cord - Diesel Forum - TheDieselStop.com
post #1 of 16 (permalink) Old 08-14-2010, 12:26 AM Thread Starter
WhiteDiesel07's Avatar
I currently have a '07 6.0 w/o the engine block heater cord. I have read that the engine block heater is actually installed from the factory on the truck however without the cord. I am currently looking to purchase the cord so I can keep the truck warm for the few weeks a year that it actually gets cold up here in the GA/NC mountains. I have looked around a little bit and found different cords and I am in favor of one for $75 since it is identical to the ones that come on the truck from the factory. Anyone with some experience with this issue on a good deal without sacrificing quality would be of great help. Thanks.
2007 F250 PSD Crew Cab Lariat Banks Cold Air Intake Tuff Country Leveling Kit Line X Black Ranch Hand Grill Guard White Knight Reverse Lights Black UWS Deepbox Tint MBRP 4" Cat Back 20" Rims on 285 Black Wall BFGs
WhiteDiesel07 is offline
post #2 of 16 (permalink) Old 08-14-2010, 08:07 AM
rock_doctor's Avatar
Yes the heater itself is already in the engine, passenger side above the starter. If you search around and you will find detailed instructions of how to install the cord. $75 is many times too much money... It is the same cord used for the Dodge Cummins as well as Detroit Diesel and so on. So if you have a truck shop, farm store or heavy equipment shop near by they will have the cord in stock. I got mine from a Volvo/White truck dealer for $16 plus get two packages of 3/8 loom from walmart and a roll of electrical tape. Put it together (wire into loom and tape whole length) and install the wire according to this web page (the orange plug is the block heater end of the cord and the thing below it is the starter which is on the passenger side of the truck). http://www.forddoctorsdts.com/articl...icle-05-20.php You can also get the cord off ebay.
If you have the 6.4 (which you don't but this is for anybody who may find this post via search) you will do the same but zip tie it to the battery cable coming from the starter up to the front of the truck, then to the trans oil cooler lines then through the space in the bumper for the tow hook. Total install time 15min tops and total cost about $20.
rock_doctor is offline
post #3 of 16 (permalink) Old 08-14-2010, 11:36 AM Thread Starter
Much appreciated..
post #4 of 16 (permalink) Old 08-14-2010, 02:56 PM
No problem but you probably don't need it. Most don't use it until it gets into the 20s and i don't use mine unless it is going to be very low 20s into the teens. You do want to get yourself a heavy duty (12ga) extension cord and a 15amp appliance timer. The heater does not need to run more then 3 hrs so set the timer to go on 3hrs before you leave. I usually do 3hr for the teens, 2hr for the mid 20s and don't run it in the 30s. Now if global warming really kicks in and you see steady temps in sub zeros then i would let it run longer if not all of the time. It will not hurt anything but your electric bill to run it all of the time.
post #5 of 16 (permalink) Old 08-14-2010, 03:10 PM
TonkaThunder's Avatar
My Photos: (6)
The ZeroStart part number is 3600008 its a 6 foot cord. I switched my 7.3 to 5w40 synthetic to make the cold weather starts easier and I love it so far!
03 F-350 DRW Lariat 7.3,4x4 6-Speed, 4.10Gears , 4 inch ProComp lift, BFG AT LT315/75R16, 3 in. spacer between duals.
GT38R 1.0 Housing
Banks Monster Exhaust, w/Turbo Elbow, AFE Stage 2 Cold Air Kit, South Bend Stg 2 Clutch & Cyro'ed Flywheel
Full Force Stage 1 Singles & TS 6-Position
Auto Meter Boost and Pyro Gauges
8,200lbs---Cat Scale---Thats me and and 38 Gallons of Diesel
3 Road Race Fox Body Mustangs( I have a disease! :])
34 Ft Kaufman Solid Deck 2-Car Hauler
TonkaThunder is offline
post #6 of 16 (permalink) Old 10-16-2010, 01:20 PM
After some research of various part#'s and prices etc. I decided on this:Block heater kit 2003-2010 Ford Powerstroke 6.0L Diesel: eBay Motors (item 180574085884 end time Nov-12-10 06:57:13 PST)
Kats is the OEM manufacturer and this was the cheapest way I found to get the cord. I didn't want the O'rielly or any other all purpose cord as I really like the sealing of the OEM cord with the retaining nut.
It's still pricey for just the cord but much cheaper than my dealer (102.00) or even the International parts dept (75.00) plus I have an extra element.
Just my $.02
big white duty is offline
post #7 of 16 (permalink) Old 10-16-2010, 01:50 PM
Kats # 28216(78064) is the replacement cord, doesn't have the cover cap on the plug end like OEM, but does have the screw down nut. $20
OR Kats #30513(79781) complete block heater with Cord $50.
Local Carquest or anyone who deals Kats heater can get them
06 F-250 x/c 4X4 sb 17" alloy wheels. Tri-fold tonneau cover, weathertech vent visor,Ford floormats and splash guards. HarleyD headlights, Duplicolor bedliner coated bumpers, 08 rear bumper and taillights, herculiner rocker panels, XM radio, bosch wipers, Recon smoked cab lights, Edge Insight w/EGT probe, winter front.
06/10 ARP studs, turbo back silverline, new head gaskets, new oil cooler, upgraded turbo drain, fuel pressure reg upgrade, coolant filter, high idle mod, harpoon mod, pre-pump spin on fuel filter,ELC coolant, 6.4 banjo bolts, CCV reroute.
Truck weight empty fueled up, 4440 Front, 3040 rear, 7480 gross. Hex VXCF4,
SCT w/customs tunes from Vivian at Quick Tricks and Matt @ gearhead
worldwide73 is offline
post #8 of 16 (permalink) Old 10-17-2010, 01:34 AM
claw444's Avatar
i live in pa. my truck never gets plugged in. i doubt you will need to plug your truck in. it is your truck and your electric bill so of course your choice. i would put the plug on the truck while its warm out just in case you ever decide to use it or realy need it.
i use full syn 5w40 rotella. no issues in cold starts or snow storms and snow blowing over truck all night then starting.
2002 F-250: CREW CAB: SHORT BED: 4X4
IESEL: 6SPD MANUAL: ALUMINUM AIR INTAKE: 4" BANKS DOWN PIPE: CUSTOM MADE 5" DUAL EXHAUST IN FRONT OF REAR WHEELS: TS PERFORMANCE 6POSITION 140HP: AUTOMETER GAUGES ON PILLAR AND ON INSTRUMENT CLUSTER: DUAL FRONT SHOCKS: DUAL STEERING STABILIZER: KYB MONOTUBE SHOCKS AND STEERING STABILIZER: LIFTED 2INCHES: TOYO OPEN COUNTRY AT TIRES LT285/75/17 LOAD RANGE E: 17" AMERICAN RACING WHEELS: CUSTOM MADE WHEEL SPACERS: WARN HUBS: POWER SLOT FRONT BRAKE ROTORS: HAWK SD BRAKE PADS UP FRONT: SMOKED CAB LIGHTS: SMOKED TAIL LIGHTS: POLK AUDIO 10" SUBS IN HOMEMADE BOXES: SONY HEAD UNIT AND SPEAKERS: KENWOOD AMP
claw444 is offline
post #9 of 16 (permalink) Old 10-17-2010, 09:28 AM
04 stroker's Avatar
I dont know about a 6.0 but I just put a block heater cord on my 2010 6.4 last weekend. I bought the part from the International truck dealer for about 19/20 dollars inc. tax and then followed the directions that rock doctor posted. Although he did not use any heat tape on his install and I wraped my wire loom in it. I most likely did not need it as the way he suggests running the wire looks like it is well protected its just something I wanted to do for a little better piece of mind.(I dont even know if the o.e.m .part has it on ?) I got the cool tape at the auto parts store it is suppose do be good for 1500 degrees. The install is very simple as rock doctor states but you do need to make sure you plug it in with a cord that can safley handle the elec. draw and I have also heard of people hooking through timers to come on about 3 hrs. before you plan to start the truck this is a great idea but make sure the timer you use is rated for the current draw as well. You should not have any problem doing this yourself, beleve me if I can do this anybody can.
04 stroker is offline
post #10 of 16 (permalink) Old 10-17-2010, 09:37 PM
KLo
Not sure what the lows get to in the GA/NC mountains. My guess is not much below 32 F, if even that low. You really won't need a heater.
Claw444, is correct. A good synthetic will get you good cold starting. Especially a 5W-40 oil. Our 15W-40 even remains fluid down to -44 F. (that's 44 degrees below zero).
If I can help anyone with a wholesale price quote, let me know how I can help.
Kirk Olson
AMSOIL Direct Jobber & Forum Site Rep
(303) 404-2145
(303) 588-6125 - Cell
KLo is offline
post #11 of 16 (permalink) Old 10-17-2010, 10:03 PM
buckshot 2005's Avatar
I lived just south of ATL,GA we saw temps low to mid 20's.Hec this year in jan and feb. we saw high 20's in the panhandle of Florida i guess global warming
F250 CC SB FX4
diesel site coolant filter, Scangauge 2,Rotella ELC coolant,4" MBRP with 5"Single Stack, updated fuel (Blue fuel spring)3c3z-9T517-Ag
STC Fitting, High Pressure oil Stand Pipes,Nitto Trail Grapplers MT, Daystar 2-1/2 leveling kit
buckshot 2005 is offline
post #12 of 16 (permalink) Old 12-07-2010, 12:56 PM
Who has the actual CASE part number? None of my local dealers can find it without a tractor number or actual CASE part number.
F350CCFX4 is offline
post #13 of 16 (permalink) Old 12-07-2010, 04:24 PM
paintingman's Avatar
here just the cord for $17.
Ford Powerstroke Diesel Block Heater Cord 6.0 6.4 New - eBay (item 150528948149 end time Dec-08-10 21:09:05 PST)
_________________________
2004 F250 6.0 PSD every day work truck
Jotto desk / laptop / printer for giving estimates
3000 watt inverter keeps drill batteries charged
4" tubo back MBRP cool duals
CFM+ intake elbow / Airaid cold air intake
SCT X3 from innovative diesel
Coolant Filter / Amsoil by-pass system
ATS Intercooler
Fluidampr / 200 amp alternator
ARP head bolts / Black onyx head gaskets
185cc Injectors 70hp+ / stock turbo
stage 1 fuel lines / cross over with fixed orifice
58 volt FIMC mod from swamps diesel
Airdog 2 with in tank fuel module upgrade Mag-Hytec Diff. and trans. covers
Aluminum degas tank
paintingman is offline
post #14 of 16 (permalink) Old 12-07-2010, 05:32 PM
MikeL46's Avatar
My Photos: (14)
My 6.0 has had no trouble starting in the teens, even with dino oil. With synthetic, I doubt it would be a problem unless the temps were in single digits.
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
115615 miles. 16.65 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
MikeL46 is offline
post #15 of 16 (permalink) Old 12-21-2010, 05:34 PM
ff0326's Avatar
I have done sub zero's with out being plugged in. It romps for a few seconds and then levels out to a nice idle.
2012 F-250 6.7 4x4 SB Crew Cab,Lariet, Auto. trans. PSD, Running 35/12.5/20's. 60 gal.in-bed Fuel/Tool box combo.
ff0326 is offline
