Engine build date - Diesel Forum - TheDieselStop.com
Old 09-09-2006, 11:36 AM   #1 (permalink)
Engine build date
I now have 246 miles on my 07' and still no problems. Where do you find the engine build date? I see a white tag on the left(drivers side) valve cover.
iewiew is offline
Old 09-09-2006, 02:33 PM   #2 (permalink)
Re: Engine build date
Your looking in the right area. Build date is on the FICM which is on the valve cover.
2003 F250 SC SB 6.0 PSD 4X4 Lariat toreador Red/Arizona Beige, torqshift, 20K miles, engine build date: 1/8/03, truck build date: 1/29/03, all flashes except buzz & inductive, Leer cap, Warn front receiver, Spray-in bedliner, A pilar EGT, Boost & Trans Temp Gauges, high idle mod, CB, 250W oil pan heater with Marinco plug, everything else stock. 4 injectors replaced @ 4500 miles;2 VGT solenoids replaced @ 4500 & 8400 miles; EGR,EBP & MAP replaced @ 12800 miles; 2 turbos replaced @ 13700 & 15400 miles.
red03f250 is offline
Old 09-09-2006, 04:56 PM   #3 (permalink)
Smiley1's Avatar
Now a good question would be:
Is there a link to the changes that have occurred at certain build dates? Pros and Cons to different build dates?
2004 F250 CC FX4 / 46g Transfer Flow / ARP Studs / Coolant Filter / CCV
2004 Surf Side 30' pull trailer
1999 Pontiac GTP modified
1968 Pontiac Firebird (restored)
Smiley1 is offline
