Old 07-10-2009, 10:49 AM   #1 (permalink)
engine codes
My truck threw a cel with two codes PO401 , PO404 and the next time i tried to start it it ran @high idle and then turned real ruff and died ! now it won t even start.Any Ideas besides my wifes = buy a cummins/duramax! thanks Dave
twister01 is offline
Old 07-14-2009, 09:20 AM   #2 (permalink)
Send a message via Yahoo to southarkems@sbcglobal.net
check the crank shaft or cam shaft sensor
southarkems@sbcglobal.net is offline
Old 07-14-2009, 12:07 PM   #3 (permalink)
I believe those are EGR Codes - check the EGR valve
2006 F350 Dually 6.0L Tommy Gate Lo0oking for heated seats !
rcgreg is offline
Old 07-14-2009, 04:26 PM   #4 (permalink)
Don't no if this helps but I have codes P0401 which is EGR insuff. flow and P0402 which is excessive flow.
onyx is offline
Old 07-14-2009, 05:31 PM   #5 (permalink)
those are egr codes, you probably have a stuck valve. You can try cleaning it, but it is a 50/50 shot that it will cure your issues. If you still have issues after cleaning, you will need to replace valve. Pull valve out and inspect. It is probably stuck open.
djshum is offline
Old 07-14-2009, 05:55 PM   #6 (permalink)
I just took my valve out tonight and it looked ok, wasn't stuck open. I cleaned it and it did nothing. Does this mean the next thing is a new one?
onyx is offline
Old 07-14-2009, 06:22 PM   #7 (permalink)
Most likely will need a new valve. That is my best guess, based on codes you've given and not actually diagnosing it.
djshum is offline
Old 07-14-2009, 08:23 PM   #8 (permalink)
My posts were for original poster, with my last post thinking onyx was original poster. Onyx....I have seen intake temp sensor cause insuff. flow codes due to carbon deposits on sensor. The carbon insulates the thermister and the voltage doesn't change as quickly as it should setting code. It is located on LH side of intake near front. Remove it and clean it, may be all that is needed.
djshum is offline
