Engine Miss, Bad MPG, Random Power - Diesel Forum - TheDieselStop.com
Old 11-12-2009, 01:05 PM   #1 (permalink)
Well looks like luck has finally caught up to me. This has been a great truck for the past 2 years but now I've got an issue. I have a 2003 6.0L...it's recently developed a bad miss, loss of power, poor fuel economy, and hesitation. It starts funny sometimes, but it's done that since I bought it back in Feb '07.
All of this is intermittent...sometimes it will run great, others it will run horribly. I'm guessing it might be an injector or fuel pump...but I'm not sure. I've thuoght about taking it to the dealership to have them scan it, but I figured I'd check here before I spend 3 arms and a leg just to have them diag it. Everything is stock, except the intake, exhaust, and I have a tuner. Any help would be great. Thanks!
-Ben
F250Ghost is offline
Old 11-12-2009, 02:11 PM   #2 (permalink)
-Ben
Have you tried removing the tuner and return the truck to "Stock" tune?
Have you tried Fuel/Water remover in a tank or 2 of fuel? Based on the randomness, sounds like water in the tank, I've had that happen before with a bad fill up and plauged me for a while till I used a few bottles of water remover..Been fine ever since..
05' F-350 6.0L Diesel Crew Cab Long bed sitting on Brentz Wheels Custom Billet Dually 22's, Kenwood Indash Nav, Sirrrus Sat, HD Radio, Nintendo game Cube, 2 - 7" Tv's in head rests, Dual MTX 10" Subs behind seat, Arp Studs, Innovative Diesel SCT tuned for Snow Performance Stage III Meth kit, Bully Dog 5" turbo back exhaust, AFE Stage II w/ProGuard 7 Cold Air Intake, Remote Start. 03 Turbo, dam the whistle is Insane! @ 38 PSI
http://www.youtube.com/watch?v=M2zEFb6bFLc - Video
8000K Bi-Xeon H.I.D Headlights, Recon Big Rig, White lighting tailgate light and 3rd LED Brake lights.
05Duallyon22s is offline
Old 11-12-2009, 02:41 PM   #3 (permalink)
I haven't yet. I plan on doing fuel filters/oil change this weekend. I used my buddies funnel last time I did oil...is it possible the funnel had something on it and contaminated the oil?
I was also being told that it could be a bad head gasket...but I'm not seeing any smoke or anything.
Old 11-12-2009, 06:21 PM   #4 (permalink)
First of all you need to check if there is any codes . If not, its a guessing game? To me it sounds like its electrical in nature may be a sensor going bad or a bad connection to the (ICP, or IPR.) sensor or a wire shorting out. Like I said its a guessing game.
2005 Silver F250 XLT 4X4 SC SB 6.0L PSD T-shift 3.73 (All stock) 150,000 miles
wbowman is offline
Old 11-12-2009, 07:50 PM   #5 (permalink)
69cj's Avatar
-Ben
I personally think the cheapest thing you can do is pay for a scan or you are just throwing parts at it.
2005 Lariet, 6.0, 3:73 1969 Mach 1, 428 CJ
1971 Triumph Trident(SOLD)
2007 Road King flhp
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline
Old 11-12-2009, 08:09 PM   #6 (permalink)
dikkstarr's Avatar
Mines acted this way before, and being an '03, its time to check all the grounds on the truck. I simply backed the grounding bolt in and out a few times and cleaned up the connectors til there was raw metal at all the grounding points. This seemed to help me, but also you might try the new fuel filters first.
The 6.0l motor has surpassed Hot Chicks as the greatest Money reducing Agent known to Mankind.
2004 F-250 Lariat late build 4X4 CC/LB auto,fully loaded with sunroof, power slider and backup sensors , White with 12" ICON lift, 6 superduty valved bilsteins, flip steering, 38" MTZs on 20x12 chrome Fuel Hostage wheels, stock gears, superlift truspeed, fumoto, high idle mod, large case high amp alternator, floating traction bars, airraid intake with elbow, 4" turbo back, studded, powerslots with hawk pads, billet grill, 55 watt HIDs 6000k heads and fogs, clear corners, 7" Eclipse AVN6620BT NAV w/ back up camera, massive JL stereo 300/4 and 500/1, 2 12s behind back seat, amp research steps, sirius, '08 diff cover, redhead steering box,, coolant filter kit, hush panels and door seal mod, quad pod with boost, EGT, water temp, and fuel pressure gauges
dikkstarr is offline
Old 11-13-2009, 05:57 PM   #7 (permalink)
Now it's worse...
Well I addressed the miss and loss of power today and took a Ford Tech's advice. I changed oil, oil filter, and fuel filters today. The result was...the truck missing MORE than it was before. I just don't get it. Guess I'm going to have to pay the $198 to have them hook it up to their little machine at the dealership.
My next door neighbor seems to think it could be the fuel pump...the list keeps getting longer.
So lets look at the options...
1. Bad Injector
2. Blown Head Gasket
3. Fuel Pump
4. FICM
5. PCM
6. Transmission
7. EGR System
I just want this thing to run right...ARGGGG!!!
Old 11-13-2009, 07:16 PM   #8 (permalink)
mmterrill's Avatar
mines having similar issues too but seems like it gets better as it warms up. my mileage was 14 this last tank with no load. in the summer when i bought the truck i got 16.5 gettin on it but even then i noticed it ran funny. mines not throwing any codes either. im going to get a diesel fuel system cleaning done next sat. ive heard guys that had issues didnt have them anymore after the cleaning. its from Wynn and its a machine. ill let you guys know if it works.
mmterrill is offline
Old 11-13-2009, 07:51 PM   #9 (permalink)
Supporting Member
my03psd's Avatar
My truck gets better numbers in the summer as probably they all do.It's the nature of the beast, when warmer they burn better, plus winter blend fuel is probably at the pumps already.
3/28/03 F250 6.0L PSD ,TORQSHIFT,CC,SB,FX4,LARIAT
Charcoal Gray/Black,
Tint,RhinoLined,Sirius,Roll&Lock,Strobes,
SCT X3 Custom Tuned by Innovative,
MBRP Stainless 4" Turbo Back,
ISSPRO Pyro,Boost, & Trans Gauges
Prodigy Brake Controller,Remote Start and Turbo Cooldown,
High Idle Mod., PM-13A on the Oil Pan,
HFCM Plug Upgrade,DieselSite Coolant Filter,
Energy Suspension Bushings,& Stanadyne every tank
my03psd is offline
Old 11-14-2009, 12:47 PM   #10 (permalink)
1. Bad Injector
3. Fuel Pump
4. FICM
5. PCM
6. Transmission
7. EGR System
Sorry to hear..But your original post was like going to the Dr and saying "i have a pain in my body, what could it be?"
More troubleshooting needs to be done on your part to rule things out.
If you truly don't care about spending the $200 then go for it... If not.
Start by removing the tuner (you'll have to anyway in order to bring it to ford anyway, They just don't do a regular obd II scan). Try Injector cleaner/ water remover for diesels.
Check your antifreeze levels (no loss = good head gasket).
If the whole thing is down on power by a large margin, I'd rule out injector, because Missing one cyclinder, you probably wouldn't even notice...Which leads to fuel pump, bad fuel, bad sensor or ficm
Old 11-14-2009, 01:10 PM   #11 (permalink)
MikeL46's Avatar
My Photos: (14)
Don't overlook the reply about the grounds. I had it happen on my wife's van. It would miss and stumble on some bumps, and some left turns. After about 6 months, I fixed it by redoing the ground for the ECU.
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
96,258 miles. 16.63 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
176 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, another Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, 1 injector, Batteries not under warranty.
MikeL46 is offline
Old 11-14-2009, 03:54 PM   #12 (permalink)
VERDICT IS IN!
Well I just got back from having my truck scanned. Turns out my original hunch was correct.
The #6 injector is bad. FICM is good, (it was at 48), batteries good, no coolant in the EGR valve or any residue, etc. So it looks like I will be pricing a new injector...I really wanted to do them all whenver I had to replace one, but that's not financially practical right now with the holidays coming up. Anyone know where I can get a reasonably priced injector? Only need one...
Old 11-14-2009, 04:38 PM   #13 (permalink)
VERDICT IS IN!
Hrmm, was it stuck on? did they say?? I didn't think 1 injector if were not firing would be so noticeable...but maybe I'm thinking on the 7.3l's they weren't
Oh well thanks, I learn all the time something new..
Old 11-14-2009, 07:34 PM   #14 (permalink)
mmterrill's Avatar
was the injector not working at all or were they functioning fine at idle? hey guys tell me about the Wynns. someone has to have had it done. heres the website.
Maintenance // Diesel Fuel System Service
Old 11-15-2009, 10:40 AM   #15 (permalink)
It was working intermittently...it wasn't working more than it was. I guess it's noticeable on a 6.0L because the motor isn't making the power it was supposed to...and the other 7 injectors are having to make up for it. Also, it confuses the computer because the FICM is saying one thing, and the PCM is saying another, and the transmission got confused...which explains the erratic shift I had the other day.
But the truck is essentially running on 7 cylinders...the tech said something like 12.5% of the power of the motor comes from each injector...so with one out and the others compensating for it (or trying to) then I'm really losing 20 or 30 some percent engine power with this bad injector, along with mileage. Well I ordered a new injector, I'm expecting it to be here at least by Wednesday!
