Engine Miss, Bad MPG, Random Power - Page 2 - Diesel Forum - TheDieselStop.com
Old 11-15-2009, 11:35 AM   #16 (permalink)
MikeL46's Avatar
My Photos: (14)
I'm a little surprised that you lost noticeable fuel mileage.
When in Alaska I had one injector fail completely, and one intermittent. Way down on power, and running a little rough. But, for the 1200 miles it took to find a dealer with the parts and ability to help us the fuel economy was unchanged at 17-18 mpg.
And I could certainly tell when the 2nd injector quit working.
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
96,258 miles. 16.63 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
176 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, another Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, 1 injector, Batteries not under warranty.
MikeL46 is offline
Old 11-15-2009, 09:06 PM   #17 (permalink)
Originally Posted by F250Ghost View Post
It was working intermittently...it wasn't working more than it was. I guess it's noticeable on a 6.0L because the motor isn't making the power it was supposed to...and the other 7 injectors are having to make up for it. Also, it confuses the computer because the FICM is saying one thing, and the PCM is saying another, and the transmission got confused...which explains the erratic shift I had the other day.
But the truck is essentially running on 7 cylinders...the tech said something like 12.5% of the power of the motor comes from each injector...so with one out and the others compensating for it (or trying to) then I'm really losing 20 or 30 some percent engine power with this bad injector, along with mileage. Well I ordered a new injector, I'm expecting it to be here at least by Wednesday!
I don't think I buy that 30%...I seen people loose and injector, run a little rough and pull a 10k trailer....I'm pretty sure that was with a 6.0
I guess maybe it depends on if your truck is chipped and making a ton more power, you won't miss a few...
05' F-350 6.0L Diesel Crew Cab Long bed sitting on Brentz Wheels Custom Billet Dually 22's, Kenwood Indash Nav, Sirrrus Sat, HD Radio, Nintendo game Cube, 2 - 7" Tv's in head rests, Dual MTX 10" Subs behind seat, Arp Studs, Innovative Diesel SCT tuned for Snow Performance Stage III Meth kit, Bully Dog 5" turbo back exhaust, AFE Stage II w/ProGuard 7 Cold Air Intake, Remote Start. 03 Turbo, dam the whistle is Insane! @ 38 PSI
http://www.youtube.com/watch?v=M2zEFb6bFLc - Video
8000K Bi-Xeon H.I.D Headlights, Recon Big Rig, White lighting tailgate light and 3rd LED Brake lights.
05Duallyon22s is offline
Old 11-16-2009, 02:33 PM   #18 (permalink)
If one is gone - the others will not be far behind it. Get them all done at once else you will be paying for it over and over and over again.
2006 F350 Dually 6.0L Tommy Gate Lo0oking for heated seats !
rcgreg is offline
