Engine Quits at Highway Speed - Diesel Forum - TheDieselStop.com
Old 09-06-2009, 10:01 PM   #1 (permalink)
Driving my 05 PS at 65 mph pulling loaded horse trailer and engine quits. Coasted to shoulder and engine wouldn't start. Turns over fine but won't start. 120,000 miles. Truck towed to dealer. Of course, holiday weekend.
Truck is stock, no mods. Any ideas?
BrunswickRoad is offline
Old 09-06-2009, 10:44 PM   #2 (permalink)
may be the FICM, my truck died as i turned into my driveway and wouldnt start. The motor would turn good but wouldnt start. Good luck
cmf250 is offline
Old 09-06-2009, 11:42 PM   #3 (permalink)
Wow, this is almost what happened to me today. I'm at 130K miles, except an '04. My mechanic is going to hook it up tomorrow and run some diags. I'll be sure and post the results.
Best to ya,
BB
bulletbob is offline
Old 09-07-2009, 10:37 AM   #4 (permalink)
Thanks for the feedback. This truck was awesome until the factory 100K warranty ran out. Since then, EGR valve and cooler, oil cooler replaced. Accelerator module and computer replaced and now this. Will let you know what the dealer says tomorrow.
Old 09-07-2009, 06:23 PM   #5 (permalink)
dikkstarr's Avatar
What are these? And which computer? Mines acting up and wonder if my PCM is going bad. Has your speedo ever bounced around or read 0 while driving?
The 6.0l motor has surpassed Hot Chicks as the greatest Money reducing Agent known to Mankind.
2004 F-250 Lariat late build 4X4 CC/LB auto,fully loaded with sunroof, power slider and backup sensors , White with 12" ICON lift, 6 superduty valved bilsteins, flip steering, 38" MTZs on 20x12 chrome Fuel Hostage wheels, stock gears, superlift truspeed, fumoto, high idle mod, large case high amp alternator, floating traction bars, airraid intake with elbow, 4" turbo back, studded, powerslots with hawk pads, billet grill, 55 watt HIDs 6000k heads and fogs, clear corners, 7" Eclipse AVN6620BT NAV w/ back up camera, massive JL stereo 300/4 and 500/1, 2 12s behind back seat, amp research steps, sirius, '08 diff cover, redhead steering box,, coolant filter kit, hush panels and door seal mod, quad pod with boost, EGT, water temp, and fuel pressure gauges
dikkstarr is offline
Old 09-07-2009, 08:33 PM   #6 (permalink)
Mine did the same thing on me when I was 450 mile from home and just turned 121,000 miles. It never kicked a code until I tried to start it back up (turned over fine just wouldn't start). Finally, it decided to start and I was able to make it home. I hooked my scanner to it and it came back with Injector Control Pressure Regulator (IPR) Circuit/Open.
deimos is offline
Old 09-08-2009, 11:56 AM   #7 (permalink)
No, the speedometer never jumped around. The dealer called this am and said they suspected a bad high oil pressure fitting and the pressure was low during attempted start. Requires turbo removal and approx $800 labor charges plus parts. Will let you know if this is the problem.
Old 09-10-2009, 11:36 AM   #8 (permalink)
Back on the road again! Dealer tested the oil pressure and found only 40 psi. This is what shut the engine down. Replaced a leaking connection at back of pump and replaced the IPR valve due to missing screen. $400 worth of parts and $800 worth of labor as turbo assembly had to be removed. Ouch!
Thanks for suggestions!
