Engine stumble on acceleration
Good Morning,
I checked with search, but did not find a thread on this issue.
My wife's truck, a 2004, has developed a stumble/miss when accelerating at highway speeds. This was first noticed when towing a trailer, but it is also present unloaded. Upon moderate acceleration (throttle depressed about half way) the truck will buck slightly and the engine will stumble about every second or so until I either add more throttle or back off slightly. Upon heavier throttle, the engine pulls strongly, but it emits dark smoke. The truck drives well otherwise and there is no check engine light.
There's about 57k miles on it right now, and I've performed most of the routine maintenance myself. Fuel filters are replace every 15k miles, and a recent drain of the HFCM had only a small amount of sediment in it. I cleaned the EGR valve about 5k miles ago as preventative maintenance, before I noticed the problem.
I've had the oil analyzed at Blackstone Labs and wear looks good, but the truck has had an on-again, off-again problem with fuel dilution, ranging from under 1% to 4% over the life of the truck. It was suggested that the short commute that my wife has to work could be the reason for that, since the truck does not get warmed up well each day. When I check the oil after highway runs, fuel dilution is normal (0.5-1.0%). Still, I wonder if a leaky injector could result in both issues - the stumble and fuel dilution. I had the truck in to Ford regarding the fuel dilution, but they reported that there were no issues with the injectors at that time (about 20k miles ago).
Any thoughts before I take it in to the dealer? Many thanks.
Joshua
