engine trouble - Diesel Forum - TheDieselStop.com
Old 08-23-2006, 11:37 PM   #1 (permalink)
engine trouble
i have a 2004 F-250 6.0L i have banks intercoolers and down pipes and so on but i crank my truck went down to the gas station to get a drink and im on my way back and all the sudden just lost all acceleration and when u try to press the gas it spudders has no power and blows out tones of black smoke. some guys told me to check my air intercooler tubes that go to the turbo to make sure no cracks or loose connections i checked them there were none so i had a buddy tow me home i double checked it then cranked and it drove fine but im affraid that there is still something wrong the turbo sounds like it is spolling fine help?????????????????????
04 F-250 Banks intercoolers,banks down pipes with elbow, hypertec chip, air rade intake, turbo back exhaust, 37inch toyos on 20z
fourwhln4ever is offline
Old 08-23-2006, 11:45 PM   #2 (permalink)
Re: engine trouble
Sounds like it's time clean that dirty EGR valve. Reason I say this that one time after cleaning mine I pinched an o-ring re-installing it. I too was headed to the store when it finally warmed up enough to operate. Man, you would not believe the black smoke and lack of power. Much worse lack of power than a blown IC pipe. Pulled it out, installed new high temp o-ring coated with a little Vaseline, re-installed and all has been fine since. I don't think all EGR valves are bad that Ford has changed, they are just so dirty they can't work properly. Can't hurt anything except lose about 5min. to clean it. That's where I would start.
'03 "TNT Ranch Edition" F350 CrewCab Lariat 4X4 DRW, 12V Cummins, P&P head with 60# valvesprings, PDR QuickSpool cam, built pump with 4K GSK, S366 Turbo, ZF6spd. with Valair Ceramic/Kevlar, manual hubs, 3.73's, 5.5" lift w/285 Dayton Timberlines, 2" DRW Spacers.
Bullrack is offline
Old 08-23-2006, 11:53 PM   #3 (permalink)
Re: engine trouble
hey man thanks alot o i know about that under power i couldnt make it threw my neighborhood the ***** wouldnt even make it up a hill and it smoked like crazy i tought the thing was on fire at first
Old 08-23-2006, 11:59 PM   #4 (permalink)
Re: engine trouble
some told me that i could have been a head gasket ?????????????????????????
Old 08-24-2006, 12:27 PM   #5 (permalink)
Re: engine trouble
Geese,
Please use some punctuation and capitalization. That post is almost impossible to read.
OMCUSNR is offline
Old 08-24-2006, 07:10 PM   #6 (permalink)
Re: engine trouble
hell im sorry i didnt know this was english class or anything, but it was the EGR vavle thanks for ur help
Old 08-25-2006, 06:07 AM   #7 (permalink)
Re: engine trouble
the egr is where is started with my 6.0. then the turbo, now 6 months later, i m getting the early signs again of the turbo failure mode. dead pedal, and trailing hitching type feeling. here i go again.
'12 gmc sierra slt cc, lb, duramax, carbon blk outside, blk leather inside.
'11 e350 super cargo,ingot silver, v10.
'09 mazda6i grand touring, black cherry,blk leather.
'77 450SL benz in the family since new.
'91 350sdl turbo diesel benz
'10 MAZDA 6i, DAUGHTERS RIDE
'90 560sel benz. what a pos.
hapaschold is offline
Old 08-25-2006, 07:47 AM   #8 (permalink)
FTG-05's Avatar
My Photos: (25)
Re: engine trouble
It wasn't an English lesson. It was a courtesy request. Make it easier to read, then more people will read it and will then be more inclined to respond. Pretty simple concept.
'06 F-350 SRW 6.0 PSD
FTG-05 is offline
Old 08-25-2006, 01:16 PM   #9 (permalink)
Re: engine trouble
I am having the exact same problem. Where is the EGR Valve, and how do I clean it?
2004 6.0L X 4x4. 4th row seat.
krdadlamb is offline
Old 08-25-2006, 09:05 PM   #10 (permalink)
Re: engine trouble
[img]/ubbthreads/images/graemlins/smokin.gif[/img]if the orings survive not getting damaged when you remove it then take some brakekleen & clean it. then apply a little oil to the orings. if the orings are damaged then go to your ford dealer & purchase some new ones. now if its so caked up w/ carbon just replace it. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
certified ford dealer 7.3L,6.0L & 6.4L diesel tech & foreman
dvtech is offline
Old 08-25-2006, 09:49 PM   #11 (permalink)
Re: engine trouble
i just took my to ford and they put a new one on EGR in
