engine won't turn over - Diesel Forum - TheDieselStop.com
Old 04-18-2005, 08:44 PM   #1 (permalink)
Unknown history on 2004 6.0 6 speed 4x4.Stolen and recovered from insurance co. Batteries charged, starter checked and good but engine will not turn over.135k miles. Any ideas why?
Insurance co said turned over slowly about 5 times then killed batteries. Help!
cagi is offline   Reply With Quote Quick reply to this message
Old 04-18-2005, 09:04 PM   #2 (permalink)
Re: engine won't turn over
Put ratchet and socket on dampner bolt and see if you can turn it over by hand. If you cant turn it over by hand...ya got problems.
djshum is offline   Reply With Quote Quick reply to this message
Old 04-18-2005, 09:10 PM   #3 (permalink)
My Photos: (21)
Has it got a factory alarm? That'll kill the starter circuit... eh, I found out the hard way. Also take a look at the starter relay to see if it's been swapped out with a cyclops.
O
6.0 PSD TSB's
02/03 built F350 6L, DRW, 05 Grille , 4" DPPI Exhaust, UltraLites on the A Pillar and Overhead Console, Firestone Bags & Compressor, Hadley Bully Airhorns , 50 Gallon Transfer Flow, Racho 9000's, Leveled 2.5/0, In-Dash PC , XM Commander.
Photos
ozhoo is offline   Reply With Quote Quick reply to this message
Old 04-18-2005, 09:16 PM   #4 (permalink)
rock_doctor's Avatar
Is it your truck? If so then force them to fix it, demand they use a power stroke certified mechanic. This is why you have insurance!
Is it a truck you are buying from the insurance company? If so get it for the cost of scrap i.e. subtract something for the cost of a new engine.
Since you say the starter is ok they need to pull the glow plugs (incase it is hydrolocked) and see if it spins, if it doesn't then it is effectively seized and something internal is broken. If it is hydrolocked then you need to know what the fluid is, if fuel then bad injector, if coolant then bad gasket, head or cracked block.
Good luck,
mark
rock_doctor is offline   Reply With Quote Quick reply to this message
Old 04-18-2005, 11:32 PM   #5 (permalink)
i disagree with u, if ur not able to turn it over id say there are some problems, these semis going down the road arnt that hard to bar over by hand when doing valve adjustments. they have more compression then our 6.0
air aid cold air, moto blue 4 inch exhaust w/ cat,3.5 inch cut out on exhaust, predetor, 6 inch lift
nickwagner is offline   Reply With Quote Quick reply to this message
Old 04-18-2005, 11:41 PM   #6 (permalink)
Didn't he just say "ya got problems".
Arent you contradicting yourself or is it just me? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2003 F-250 XLT, Crew Cab, SWB, 6.0 TorqShift, ESOF, Limited Slip, Silver,.
Truck Weight Wet, No Payload:
Steer: 4380 lb Drive: 2920 lb Gross: 7300 lb
TRUCK PICS!
Mods:
LINE-X, SteveracerMOD, Autometer Boost-Pyro; A-Pillar mount, MBRP 4" Turbo Back (What's A CAT?) Polished CAC tubes, Custom Heavy Duty Headlight Harness and Silverstar Bulbs, Heavy duty bumpers I built
RockPSD is offline   Reply With Quote Quick reply to this message
Old 04-18-2005, 11:45 PM   #7 (permalink)
Somedays I just can't win.
Old 04-19-2005, 10:44 AM   #8 (permalink)
Open mouth, insert foot. Next time read before you tell someone they are wrong. [img]/ubbthreads/images/graemlins/zombie.gif[/img]
Charlie_in_TX is offline   Reply With Quote Quick reply to this message
Wheel & Tire Center
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
