Error code help P0404 and P1335 - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 04-17-2008, 11:37 PM Thread Starter
I have a 2007 F250 with the 6.0 that has given me a few troubles. Initially my fan clutch locked up at about 10,000 miles. Next I had an oil leak, which required a bed plate seal replacement at about 15,000 miles. Last weekend pulling my trailer I noticed my engine light come on. The truck ran well and I did not notice anything unusual. I received error codes P0404 and P1335, the truck has less than 16,000 miles. I would like to know if this might be something I might be able to take care of myself, before I take it back to the dealer for warranty work. Appreciate the help......
bmkte is offline
post #2 of 13 (permalink) Old 04-17-2008, 11:58 PM
dieselmankane's Avatar
Here are the code definitions:
DTC P0404 Exhaust Gas Recirculation (EGR) Open Position
P1335 has something to do with the crankshaft position sensor.
My guess is your going to have to clean/replace your egr valve, not sure about the crankshaft code though, maybe the sensor is bad.
2003 F250 Super duty 6.0 PSD, was great in the beginning, but started to have major issues:
Traded, Oct 2 2008 for...
New truck: 2008 F250 Superduty Lariat 6.4 PSD Job 3, black, with ALL the goodies, very impressed so far...
[SIGPIC][/SIGPIC]
dieselmankane is offline
post #3 of 13 (permalink) Old 04-18-2008, 12:57 AM
P1335
EGR Position Sensor Minimum Stop Performance.
Fault sets when the EGRP closed position exceeds the maximum limit at initial key on.
P0404
Faulty EGR sensor, valve, or PCM integrity of EGR Position circuit
Mark
bismic is offline
post #4 of 13 (permalink) Old 04-18-2008, 06:40 PM Thread Starter
thanks
Thanks for the helpful information guys. I will probably take the truck back the dealer for the warranty work.
bmkte is offline
post #5 of 13 (permalink) Old 04-19-2008, 01:43 AM
Stuck open EGR valve causing P1335 and P0404. They will put an EGR valve in it and hopefully you will get a certified stock one or get lucky and get a good one.
Gofaster23 is offline
post #6 of 13 (permalink) Old 04-19-2008, 03:51 AM
gofaster .........
What is a "certified stock EGR valve"? Also, are many of these valves bad right out of the box? I am at 30,000 miles and just changed my EGR valve out as a preventative measure. No signs of problems - just nothing better to do I guess. I had seen posts of folks w/ clogged valves and intake manifolds at low mileages so I was curious. Mine turned out to be pretty bad - glad it is cleaned up (for now).
I have updated all the computer strategies, installed a ccv filter, see no oil consumption, use good fuel and a fuel additive, I will idle less next winter. My mpg has been 18 since the computer flashes - so it has been running great. What else can be done to keep this system clean?? Clearly the ultimate solution is to eliminate it, but until I get my SCT, I will approach it from the more conventional side................
Mark
bismic is offline
post #7 of 13 (permalink) Old 04-19-2008, 04:45 AM
Banned
There have been some.......... "concerns" with the current crop of EGR valves. Not sure what the problem is but I feel confident saying that it is a supplier problem.
Where a bigger concern exists.... In my world, I cannot replace an EGR valve without a definite, measurable reason for doing so.... If I am sure the EGR is my problem and replacing the EGR doesn't cure it... I can feel confident in installing another EGR. If, however, a DIYer installs a faulty valve and doesn't or can't perform the required tests.. this could lead to a lot of unnecessary experimental parts costs....
GrampyJim is offline
post #8 of 13 (permalink) Old 04-19-2008, 10:12 AM
Is there a way for a DIY to get "certified stock"?
Mark
bismic is offline
post #9 of 13 (permalink) Old 04-20-2008, 01:22 AM
I would not replace your EGR valve as "maintaince", if there aren't any problems, dont replace it. There is a bad batch of EGR valves floating around, probably for about a month now. It's not a Ford problem but a Delphi (makes the valve) and Navistar problem. I had to replace the EGR valve four times on an ambulance because they would fail testing while hot. After contacting Ford I was contacted by Navistar and was shipped a certified stock, known good EGR valve. I don't think there is any way for a DIY'er to get a certified stock EGR valve. The problem vehicle has to be at a Ford dealer, being worked on by Ford technicians, and the vehicle itself has to be an emergency (Fire, EMS, Police) type vehicle that has to be on the road.
post #10 of 13 (permalink) Old 04-20-2008, 01:31 AM
Thanks .................... too late for this DIY-er , but thanks! Just hope I got lucky!
Mark
bismic is offline
post #11 of 13 (permalink) Old 04-24-2008, 06:37 PM
deereman39's Avatar
My Photos: (15)
bismic does your cel go off,I have the same problem but mine will go out after a day or so of not towing and will never come on untill i tow again and i have to be in the hills where it is pulling hard and maxing the boost.
Thanks Ed
Remember if you stop to Think,Don't Forget to Start Again.
2005 F-250,XLT,Extended cab Super Duty 2X4
Born-11/03
Metalic Silver
American made in Jefferson County KY.
299.8" WB Styleside.
5 speed Torqshift Auto Trans [373 Gears]
6.0 L V8 ENG.
Refinements Are
ARP Studs [one at a time]
Blue spring mod
CCV Mod
EGR Cooler["GONE"]
Fog Light Mod
Grease Zerk in Drive Line Slip joint
Harpoon Mod
HFMC Valve [#6E7Z-9C082-A]
Injector Spools [Cleaned for Stiction]
Updated Stand Pipes & Dummy Plugs
Zoodad Mod
XDP Coolant Filter
STC Fitting
BOOB MAN= Brother Hood Of Oil Burners
Other Toys
2005 Cardinal 31ft 5th Wheel
deereman39 is offline
post #12 of 13 (permalink) Old 04-24-2008, 06:47 PM
I never had a CEL go off. I really had no performance issues at all. I was just curious as to what the EGR system would look like and when I removed the valve, I saw that it was heading towards a mess that would more than likely cause my EGR valve to stick and eventually be in the wrong position.
Because of this, I am very glad I routed my ccv through a filter.
Mark
bismic is offline
post #13 of 13 (permalink) Old 04-24-2008, 07:07 PM
Tack weld the valve shut and ignore the ck eng light...
Early '99 F-250 Isspro Guages, shift kit, digital lockup valve, torqshift cooler, Diablo 4 bank, straight factory exhaust...aFe stage II, F.A.S.S. 150/180, homemade regulated return... FS2500 and Motorcraft full synthetic 5W40
'01 Excursion Isspro Guages, shift kit, lup valve, torqshift cooler, Diablo 4 bank, 4"stainless (mostly), aFe stage II w/pg-7 and a sock, Mickey Thompson 325/50/20 on Weld Cheyenne 8's.
shaggy_tech is offline
