Error Code P2285 2003 6.0L Diesel - Diesel Forum - TheDieselStop.com
post #1 of 14 (permalink) Old 06-02-2008, 05:04 PM Thread Starter
I have a 2003 F250, with the 6.0L diesel, that I have had problems with it running correctly in the past few weeks. The service engine light came on and I had the codes read and it read code # P2285 which read "injector control pressure sensor circuit low". What does this actually mean? It has been idling rough from time to time and it has actually died on me 3 times. I was coasting down a hill one time and it just quit. It never gives any sign that is going to die. It will fire right back up every time. The idle will also idle high around 1000 rpm sometimes also. The service engine light doesn't stay on all the time, sometimes it goes off and other times it is on. I had an injector replace about a year ago and I thought this was another going the same direction. I wanted the dealership to replace all 8 but they wouldn't do that. They have had problems with those injectors, so when the warranty is up it is my problem. Should the dealer repladce all the injectors since they know there has been a problem? Is this something that is in the wiring harness? I have heard that there has been problems with those also.
Thanks for your help.
Nathan
ford861 is offline
post #2 of 14 (permalink) Old 06-02-2008, 06:58 PM
ICP sensor and wiring harness are both common failure items on a 2003.
Mark
bismic is offline
post #3 of 14 (permalink) Old 06-04-2008, 01:19 PM
my03psd's Avatar
I second the ICP sensor and harness.Had the same symptoms, had them changed and no problems since.Good luck.
3/28/03 F250 6.0L PSD ,TORQSHIFT,CC,SB,FX4,LARIAT
Charcoal Gray/Black,
Tint,RhinoLined,Sirius,Roll&Lock,Strobes,
SCT X3 Custom Tuned by Innovative,
58v FICM Tuned by Innovative,
MBRP Stainless 4" Turbo Back,
ISSPRO Pyro,Boost, & Trans Gauges
Prodigy Brake Controller,Remote Start and Turbo Cooldown,
High Idle Mod., PM-13A on the Oil Pan,
HFCM Plug Upgrade,DieselSite Coolant Filter,
Blue Spring Mod, 08 Diff Cover,
Banjo Bolt Mod, Energy Suspension Bushings,& Stanadyne every tank
my03psd is offline
post #4 of 14 (permalink) Old 06-04-2008, 04:38 PM Thread Starter
Is the wiring harness to the ICP sensor the one that has had problems? Could the IPC sensor and/or wiring harness cause the engine to die all of a sudden? It has only done this at idle, but quite frequent.
Nathan
ford861 is offline
post #5 of 14 (permalink) Old 06-04-2008, 08:18 PM
my03psd's Avatar
I was told that oil leaks around the sensor and runs down the pigtail,swells the wires and causes the sensor to get false readings.This causes problems for firing the injectors.
my03psd is offline
post #6 of 14 (permalink) Old 06-04-2008, 08:25 PM
PSV8TD's Avatar
The main wiring harness that runs around the EGR, FICM, and top fuel filter may be chaffed. Check the harness for cuts. Tape up anything that touches metal. My truck would just die all of a sudden then I replaced the ICP and harness then taped up all points the harness would touch metal and it runs fine. Good Luck, AJ
2003 F250, 6.0L, Fx4, CC, SB, Lariat, Arizona Beige, MBRP Turbo Back Straight Pipe 4inch, Bilstein shocks, Isspro pyro and boost gauges, Banks Six Gun & Speedloader, Auxillary idle, XM radio, CB, Backup lights, Recon Smoke cab & mirror lights, Timbrens
PSV8TD is offline
post #7 of 14 (permalink) Old 02-11-2009, 02:30 PM
I have the same problem with my truck. 2003 6.0l 4x4. But something that has happened along with the idle problem is when I have the cruise set it tries to down shift then can't find it and slams back in to gear. I was wondering if these two would be related. I called the Ford dealership to see what it would run for a complete diagnostic and that's $80 bucks starting out. And I just don't want to do that. Autozone didn't have the any help for the code though. They didin't have any associated parts with it.
Snoman03 is offline
post #8 of 14 (permalink) Old 02-12-2009, 11:50 AM
teamroper60's Avatar
P2285 is the code you get when the ICP sensor is bad.
#43
President and Webmaster
teamroper60 is offline
post #9 of 14 (permalink) Old 02-13-2009, 08:42 AM
Yeah, I understood the ICP, and I have that part figured out. But my question I guess is, it would seem if this is the problem, would that be causing the tranny miss-shift. It's believeable to think, the ICP sends out a bad input, the motor stalls for an instance, thus causing the tranny to try to downshift and then catch right back up. Any of this seem logical?
Snoman03 is offline
post #10 of 14 (permalink) Old 02-13-2009, 02:59 PM
Theoretically, I guess it would be possible that if your ICP is so out of whack that your rpms fall to a certain point, the trans might want to downshift, but I have never seen that happen and I have had my ICP replaced twice.
To the OP:
Even though the early 03 injector issue is well documented, Ford's stance is that they will only replace injectors under warranty upon a failure. Your dealer has no choice in the matter. They have to follow what Ford tells them or they eat the cost of the repair (including the parts cost).
#43
post #11 of 14 (permalink) Old 08-31-2015, 04:55 PM
I replaced the ICP sensor today, and the light is still on! Ford is tell me it could be the FICM and it could cost $1200. plus labor to replace!!! Can anyone help???
ConFoxx is offline
post #12 of 14 (permalink) Old 09-01-2015, 12:20 AM
Did you replace the pigtail when you replaced the sensor? It should have been. If not, do that and see if your problem clears up.
#43
post #13 of 14 (permalink) Old 09-01-2015, 06:14 AM
Hey tr60 - great to see you posting again!! Hope all is well!
ConnFoxx - listen to the advice above!
Also, if your FICM indeed is bad, you can remove it yourself and send it to FICMrepair.com and have it repaired and/or upgraded with a lifetime warranty for WAY less than $1200 ($425 for lifetime warranty and upgraded components). It is not that hard to remove and reinstall.
Mark
bismic is offline
post #14 of 14 (permalink) Old 02-06-2016, 04:33 AM
icp question
i have a buddy with an 04 6.0 and since he has had the truck it has a rough type idle where it is rough sometimes and smooths out then does it all over again. its also hard to crank when it is cold and he has had an oil leak on it that is coming from up under the turbo. well that went from a slight trickle to a gushing guieser yesterday and his turbo also quit. <- would those two be related or not? we had googled it and determined that the leak was from the icp sensor but we haven't messed with one of these motors before so we weren't sure. also, since the oil leak turned worse the motor no longer has enough oil (if any at all) to even touch the dipstick anymore. if the guts of the icp blow out will that empty the oil out of the motor? thanks for any help because i want to try and get his truck up and running again bc its the only vehicle he has.
dieselenthusiast is offline
