Exhaust gaskets - Diesel Forum - TheDieselStop.com
Old 01-11-2013, 10:39 AM   #1 (permalink)
Exhaust gaskets
I'm in the middle of replacing my head gaskets, and noticed there were no exhaust gaskets between the head and the exhaust manifold.
So as I have really only wrenched gas engines is it ok to install the exhaust manifold to the head without a gasket.
I did find an exhaust gasket from IPR, would this be something that will help with sealing the flanges. Is it necessary to install a gasket on an engine that has 125,000 miles?
IPR Valve Cover & Rocker Box Gasket Set 2003-2007 Ford 6.0 F250 F350 F450 F550 Powerstroke
Thanks for any help,
Tom
tom135 is offline   Reply With Quote
Old 01-11-2013, 10:50 AM   #2 (permalink)
fordsforever73's Avatar
My Photos: (21)
Feedback Score: 2 reviews
Mine was like that too...no gaskets. I did notice a couple of ports did leak a little as there was soot under the manifold. I assumed if there was a leak at the manifold, the turbo is less effective. So I bought a set of gaskets, and I only wanted to that job once.
2005 F-350 CC, LB, 4x4, Dually, 6.0 Powerstroke, Torqueshift, 4:10 Gears. Gooseneck and rear pull hitches. "Truck Covers USA" roll up aluminum tonneau cover. Putco Boss Running Boards. Aluminum finned diff covers. Bilstein HD shocks. ProComp steering stabilizer. XRF ball joints. NC Hornet CCV mod. RCD egr delete kit. AirDog fuel system. Strictly Diesel's regulated fuel and coolant return lines kits. Amsoil oil bypass (by NUC Motorsports) and homebuilt coolant bypass kits. CFM intake elbow. ARP head studs with factory gaskets and all upgrades. MBRP 304SS "Cool Dual" exhaust system. SCT Livewire tuner with pyrometer. Autometer 'A' pillar gauges (Boost/Trans temp/Pyrometer/Fuel Pressure). 850 CCA Motorcraft Batteries. Using Rotella T-6 synthetic oil. Upgraded degas tank and cap. Hayes deep aluminum trans pan. GoGo Diesel modified direct clutch solenoid. Retro Solutions HID head and fog lights. High idle mod. Jimmi-Jammers. Many other custom features.
fordsforever73 is online now   Reply With Quote
Old 01-11-2013, 01:30 PM   #3 (permalink)
They originally installed the exhaust manifolds when they were yellow hot and still a little malleable so no gasket was necessary. Once you pull them off then you do need to use a gasket.
Member # 23075 Reged: 07/18/02
2005 Excursion w/ 6.0L PSD - Edge Insight, RCD EGR delete, Turbo Drain/Blue Spring/Oil Cooler Updates, Dfuser Coolant Filter, 240amp alt, fumoto.
2008 FX4 F250 CCSB w/ 6.4L PSD - Edge Insight, H13 Bi-HIDs, custom coolant filter, fumoto.
rock_doctor is offline   Reply With Quote
Old 01-13-2013, 05:07 PM   #4 (permalink)
Thanks for the replies, looks like I better order some gaskets.
Old 01-13-2013, 07:40 PM   #5 (permalink)
I have never put exhaust gaskets on these motors, though I don't see where it would hurt to have them. I always just polish them up and bolt them back on. Never had an issue with leaks or smells in the cab from doing this.
2011 F350 Lariat DRW 6.7L
25' PJ Flatbed Equipment Trailer
2005 XLT F250 6.0L(Wife's truck)
2005 Bobcat T300
gtstang462002 is offline   Reply With Quote
Old 01-14-2013, 09:47 AM   #6 (permalink)
bobsherrie's Avatar
I have had the opposite experience with both my former 7.3l and present 6.0l. Both had exhaust leaks at the manifolds and Ford installed gaskets in both cases. In fact, the 7.3l leaked bad enough that it could be heard in the cab.
'06 F350 Lariat SRW X-cab,4X4,Torqshift 5-speed Auto,w/23000lb GCVWR and many other options, Vandal Alert Cyclops, Pressure Pro TPMS, Extang Tuff TonnoIII, Duraflap mud flaps and Roadwing mud flap system, towing a Hitchhiker 33' Discover America 5'er and a Lund boat. Stock and doing fine. Coolant filter, Fuel regulator upgrade.
bobsherrie is offline   Reply With Quote
