Exhaust leak - Diesel Forum - TheDieselStop.com
Old 11-20-2007, 11:04 PM   #1 (permalink)
Exhaust leak
Was under my truck today and noticed slight evidence of soot around exhaust ports where they meet the head. Are the manifold bolts known to work loose? Is there a gasket there or just metal to metal? Or is some leakage normal? Thanks.
2005 F250 XLT Super Duty Crew 4WD. White/Silver. K&N intake. Hypertech programmer. No muffler. Stock everything else. Other trucks: 1979 Kenworth W900A, 1982 Kenworth Cabover (BJ and the Bear) 1997, 1998, and 2000 Kenworth W900's. All Caterpillar Power. 1979A model just got marine application 2-piece pistons, nozzles, and ATAAC. Sure is sweet!!! 500 to the ground, and no smoke!
Transporter and Operator of a Bauer Built Championship Unlimited Tractor Pulling Sled for the United Pullers of the Carolinas, Region IV affiliate of the National Tractor Pullers Association (NTPA), and damn proud of it!!!!
ericjack is offline
Old 11-21-2007, 01:18 PM   #2 (permalink)
Re: Exhaust leak
6.0 does not come with exhaust manifold gaskets but if it starts to leak there, there are gaskets available.
2005 F-250 Lariet, 6.0, 3.73, LB, CC with coolant filter and Bilstein shocks
1969 Mustang, Mach 1, 428 Cobra Jet, Ram Air, All Stock
1971 Triumph Trident
69cj428 is offline
Old 11-29-2007, 05:47 PM   #3 (permalink)
donseye's Avatar
My Photos: (21)
Re: Exhaust leak
Do you know if there is such a thing for 7.3?
If so, where would I look?
don
My Rig
donseye is offline
Old 12-01-2007, 11:04 AM   #4 (permalink)
Re: Exhaust leak
The exhaust manifold bolts could have worked loose. I know they did on my 7.3. And there should not be leakage. If there is try to tighten the bolts.
'06 F350 Lariat SRW X-cab,4X4,Torqshift 5-speed Auto,w/23000lb GCVWR and many other options, Vandal Alert Cyclops, Pressure Pro TPMS, Extang Tuff TonnoIII, Duraflap mud flaps and Roadwing mud flap system, towing a Hitchhiker 33' Discover America 5'er and a Lund boat. Stock and doing fine. Coolant filter, Fuel regulator upgrade.
bobsherrie is offline
