Exhaust Smell In Cab - Diesel Forum - TheDieselStop.com
Old 10-29-2009, 12:03 PM   #1 (permalink)
When Idleing With The Ac On Normal Or Defrost On I Have A Exhaust Smell In The Cab When The Ac Is Pulling Fresh Air Into The Cab Where Should Look For A Leak I Dont See Any Soot On The Pipes Or Hear A Leak
2005 F350 XL REGULAR CAB 6.0 11 FOOT SERVICE BOX DRW STOCK 212,347 ON THE CLOCK
1997 34.5 FLEETWOOD AVION 5TH WHEEL
2003 F350 XLT CREW CAB 7.3 STOCK DRW 85,000 on the clock
JOHN 3:16
timbo2 is offline
Old 10-29-2009, 12:16 PM   #2 (permalink)
teamroper60's Avatar
Probably a cracked y-pipe.
pics
#43
SLAPS President and Webmaster
teamroper60 is offline
Old 10-29-2009, 12:53 PM   #3 (permalink)
the y pipe tends to crack in the corrugated part. concentrate on that area. another common spot to leak is where the y pipe mates to the turbo
6.0 tech is offline
Old 10-29-2009, 12:54 PM   #4 (permalink)
It could also be a leak between the exhaust manifolds and the block since there isn't a gasket between them from the factory. Look for soot around the flanges at each cylinder. Mine were leaking and the dealer's shop installed gaskets per a TSB.
'06 F350 Lariat SRW X-cab,4X4,Torqshift 5-speed Auto,w/23000lb GCVWR and many other options, Vandal Alert Cyclops, Pressure Pro TPMS, Extang Tuff TonnoIII, Duraflap mud flaps and Roadwing mud flap system, towing a Hitchhiker 33' Discover America 5'er and a Lund boat. Stock and doing fine. Coolant filter, Fuel regulator upgrade.
bobsherrie is offline
Old 10-29-2009, 01:47 PM   #5 (permalink)
Thanks Guys
JOHN 3:16
timbo2 is offline
Old 10-29-2009, 04:38 PM   #6 (permalink)
BogSpores's Avatar
I don't want to hijack this thread, but I've had the same trouble since I bought mine in 2004.....It was never really bad enough that I considered taking it in for service....
I had the turbo replaced in 2008 at the direction of the dealer (warranty covered) and after about 250 miles, began to notice puffs of soot from under the hood when sitting still, at idle and burping the throttle... And, the smell in the cab is BAD now, much worse than before! I've run the thing for over 10k miles this way, and other than smell, soot deposits (drivers side, below exaust manafold) and occasional sluggish acceleration it runs fine....(yeah, that sounds rediculous!)
I thought maybe the dealer didn't install the Y-pipe correctly when installing the new turbo? How hard is it to replace the Y-pipe?
BogSpores is offline
Old 10-29-2009, 05:10 PM   #7 (permalink)
not too bad. there are 4 bolts that hold it to the manifolds, 2 on each side. head is 10mm and nut is 13mm. replace these when you remove them. your gonnaneed to pull the turbo to get the y pipe out. then there is a heat sheild that bolts to the head and the back of the hpop cover then just pull the pipes out.
6.0 tech is offline
Old 10-29-2009, 05:17 PM   #8 (permalink)
BogSpores's Avatar
Thanks for the speedy reply! Ballpark on what the dealer might charge?
Old 10-29-2009, 10:23 PM   #9 (permalink)
dikkstarr's Avatar
No offence, and off topic, but damn!! why do you capitalize every word? Its hard to read.
Isnt it hard to type that way?
The 6.0l motor has surpassed Hot Chicks as the greatest Money reducing Agent known to Mankind.
2004 F-250 Lariat late build 4X4 CC/LB auto,fully loaded with sunroof, power slider and backup sensors , White with 12" ICON lift, 6 superduty valved bilsteins, flip steering, 38" MTZs on 20x12 chrome Fuel Hostage wheels, stock gears, superlift truspeed, fumoto, high idle mod, large case high amp alternator, floating traction bars, airraid intake with elbow, 4" turbo back, studded, powerslots with hawk pads, billet grill, 55 watt HIDs 6000k heads and fogs, clear corners, 7" Eclipse AVN6620BT NAV w/ back up camera, massive JL stereo 300/4 and 500/1, 2 12s behind back seat, amp research steps, sirius, '08 diff cover, redhead steering box,, coolant filter kit, hush panels and door seal mod, quad pod with boost, EGT, water temp, and fuel pressure gauges
dikkstarr is offline
