Just had Ford dealer do a tranny flush, and they couldn't break loose the external filter housing bolt. The tech infofmed me that there was a 50/50 chance that it would break if forced. My truck has 53k on odometer, and that filter has not been changed yet. Is there a sure way to break the bolt free without colateral damage? Any help would be appreciated.
2006 F350 6.0L SRW FX4 Lariat CC SB
Dark Stone/Arizona Beige
Stock & Loaded
The following procedure worked for me years ago
-Apply & then maintain steady pressure with a proper sized wrench
-Spray down the bolt & surrounding area with a Good quality Rust loosen product
-Leave overnight
-Then next morning determine if the bolt broke loose
-If NOT repeat above procedure
Hope this helps
You have to use a air impact wrench to break it loose. Trying to slowly break it loose with ratchet and socket sometimes results in broken lines on the housing. They (filters) should be changed at most, every 30,000 miles along with the fluid.
If you've ever looked at one @15,000 you would do it every other oil change. JMHO.
2005 Lariet, 6.0, 3:73 1969 Mach 1, 428 CJ
1971 Triumph Trident(SOLD)
2007 Road King flhp
2007 Jazz 5er, 11k
173rd Airborne
I do look at them because I change all truck filters myself 90% of the time. In fact the last time I changed the trans filter it had 17,000 miles on it, only because I drained the fluid to put a new TFT sensor in. It didn't look that bad.
I just changed the filter and oil at 17000 miles as all my truck does is tow our 5'er and boat. Oil looked and smelled okay and the filter had some crud in it but not much. There is not a 'bolt' on my filter. The bowl has a nut formed into the bottom so spraying with a rust spray won't help. An impact gun worked great though, turned down a bit and I didn't have to hold the trigger open.
'06 F350 Lariat SRW X-cab,4X4,Torqshift 5-speed Auto,w/23000lb GCVWR and many other options, Vandal Alert Cyclops, Pressure Pro TPMS, Extang Tuff TonnoIII, Duraflap mud flaps and Roadwing mud flap system, towing a Hitchhiker 33' Discover America 5'er and a Lund boat. Stock and doing fine. Coolant filter, Fuel regulator upgrade.
Mine is the same as yours but I have always been able to remove with a socket and ratchet. The O ring does the sealing so you only need to bottom the threads out for it to seal. I also coat the O ring with motor oil or vaseline.
2007 Road King flhp
2007 Jazz 5er, 11k
173rd Airborne
Follow-up on external transmission filter siezed bowl
Originally Posted by Walter Werbeck
Hello Fellow Dieseliers',
Seasons Greetigs Fellow Dieseliers',
I have some update information on the siezed external transmission filter bowl situation. A friend told me I should try to break it free when it is very cold, as when cold, the internal metal parts are contracted and more likely to break free without breaking anything. Is my friend correct? Also, I have found a local filter and lubricant supplier that carreis correct Ford replacement filters for way less than dealership prices. Example: Dealership wants $45.00 for filter FT145, supplier wants $21.00.
I'm going to attempt this service myself (dealer wants $90.00), so any help would be appreciated.
Stock & Loaded
i have 76,000 and am not changing it till over a 100,000 .this is tranny fluid filter here not engine oil filter why get on your back if you dont have to ,my tranny fluid is as new/red as the first time i looked at it there is a ford recomendation matenence chart that tells you what mileage n when you should change it give or take some depending on how hard you use your vehicle
Yep.. That mileage is 30K.
__________________ 2003 Toreador Red/Arizona Beige CC, DRW, Lariat, FX4, 6.0 PSD, Torqshift, born early Feb. 03; AIC; Silverline turbo-back dual exhaust; 155cc injectors from Full Force Diesel (Casserly); SCT with tuning by Tony Wildman (Total Diesel Performance) & Innovative Diesel; ARP studs; Dfuser regulated return; AFE PG7; Fumoto valve; B&W hitch, Di-Pricol gauges; DIESELSITE Coolant filter; Timbrens; Rancho RSXs; Michelin XPS Traction's; a whole bunch of "bling"; Connex 4300hp; Pioneer DEH6100BT; JL Audio 275w amp driving a 12" sub; JL Audio 50wx4 amp driving the Alpine door and rear seat speakers. 380.3hp/786.7ft-lbs (on my tow tune!)
The color is a good indicator that it is not burned but does nothing to tell you the status of the additives and conditioners that go into the fluid during manf.
2007 Road King flhp
2007 Jazz 5er, 11k
173rd Airborne
