Old 10-13-2009, 05:53 PM   #1 (permalink)
Send a message via AIM to novimustang
External Transmission Filter Housing Leaking?
This might seem like a stupid post but I replaced my entire external transmission filter housing not long ago, and I was under the truck changing the oil today and I noticed it (the ext. trans filter housing) was leaking. Not terribly, but pretty significantly. I added about 1.5qts of fluid and it still wasn't full (that's all the SP I had lying around) so I decided to take the cup off and take a look at everything. The filter was in straight and everything looked fine so I put it back on and this time I used a Snap-On 1/2" cordless impact to get it pretty darn tight. I started the truck and laid underneath it and watched the cup and slowly but surely it's still seeping every so slightly.
From what I can tell, the cup appears to be a bevel fit like AN fittings but did Ford leave out some kind of gasket or o-ring? Low tranny fluid isn't good for any tranny but especially not one towing 15,000lbs! I mean I can't get it much tighter without getting ridiculous, and that was my problem in the first place - the old one was on so tight I couldn't get it off (which I STILL can't even on a bench vise).
Anyway any help or suggestions would be greatly appreciated.
novimustang is offline
Old 10-13-2009, 07:41 PM   #2 (permalink)
There should be an O ring and you should not have to torque the hell out of the housing. The O ring does the sealing not the threads.
2005 Lariet, 6.0, 3:73 1969 Mach 1, 428 CJ
1971 Triumph Trident
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline
Old 10-14-2009, 12:43 AM   #3 (permalink)
That's so weird, cause like I said I bought a complete unit from Ford that came with everything, the housing, cup, filter, everything all assembled together. So apparently that o-ring is separate and doesn't even come in the new "complete assembly" kit? That makes no sense but whatever, I guess I'll call the dealer tomorrow and see if they can find it, cause I sure need it.
Thanks brother
Old 10-14-2009, 08:50 AM   #4 (permalink)
Thanks brother
The O Ring should be there, if not it was missed in production. I used to work for the company that made the filters. There were a lot of issues with the threads on those so don't tighten it down to much or you will wreck the threads and have to buy another new one.
pkzochow is offline
Old 10-14-2009, 03:42 PM   #5 (permalink)
Thanks guys, yeah I called my Ford dealer and they were cool about it, offering to warranty out the entire assembly but I ended up just paying $5 for an o-ring cause I don't want to wait for them to order another kit.
Sucks though that my "complete assembly" wasn't so complete.
Old 10-14-2009, 05:22 PM   #6 (permalink)
would you happen to have the part # for the o-ring?? I am going to change my fluid soon and was wondering if I should replace the o-ring also??
2004 F-250 Crew Cab XLT, Auto, Short Bed, Arizona Beige, Fx4/Camper Pkg., 265's, Built 4/23/04, Delivered 4/27/04
Retrax Bed Cover,Crimestopper Alarm/ Keyless Entry/ Remote Start/ Skweeker Idle Up Mod/ Marinco Built in Heater Plug/ Dieselsite coolant filter
My Truck
2004/1997 Powerstroke Pics, Ford 9N Tractor,6.0 Bible
dwelch1 is offline
Old 10-14-2009, 06:11 PM   #7 (permalink)
Every filter I have bought had a new o-ring with it.
2003 F250 XLT Sport Ext Cab ESOF FX4 6.0L TorqShift, Sonic Blue/Black Leather.
BrakeSmart Trailer Brake controller.
Leer Cab high Browning Edition Cap.
2004 SunnyBrook Solanta 28' TT small slide 7800#
35 Years in the trenches!
Retired Machinist & Manufacturing Engineer for fuel control systems for very large Diesel Engines. Locomotives to Super Tankers.
Designed and trouble shot manufacturing processes for stuff from Design Engineers. Sometimes had to wrestle for design changes.
Designed and built tools and equipment to machine, assemble, disassemble, repair and test.
Wisdom comes with age, but sometimes age comes alone.
"Nothing is FOOLPROOF because fools are too ingenious"-Mark Twain
johnmart is offline
Old 10-14-2009, 06:29 PM   #8 (permalink)
Not in the MC FT-145 box that I have? I bought two filters new in box, neither had o-rings with them??
My Truck
dwelch1 is offline
Old 10-14-2009, 06:31 PM   #9 (permalink)
The Motorcraft FT-145 filter does not come with a new O ring. They are re-useable if you don't dammage them. Mine is on the 3rd change and no problems. Some A/M filters come with new O rings. New O ring at dealer is approx. 5 bucks.
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline
Old 10-15-2009, 02:46 PM   #10 (permalink)
The Ford part number for the o-ring seal is 3C3Z-7J126-AA, and cost me $5, though I think the dealer said they marked it down for me, given my situation.
BTW I did FINALLY get my old cup off (from the entire unit that I took off a while ago) by getting it in a bench vise and using brute force cybernetics and a BFH! Man, NO WAY would I have ever gotten that thing off on the truck. And the filter was pretty dark, so I'm glad I took the time to change the whole thing out, despite the minor hassle.
