The first order of business would be to pull your EGR valve. If it is badly plugged, I would replace it (or at least clean it). Whenever you clean the EGR valve, you really need to ensure that the MAP sensor hose and the EBP tube is clear. Note that on vehicles built before Sept 23, 2003 - the EBP sensor is no longer part of the PCM strategy (if you had your PCM updated in late 2004 or up).
Mark
