F350 4X4 Brakes are Junk - Page 2 - Diesel Forum - TheDieselStop.com
Old 07-24-2005, 03:28 PM   #16 (permalink)
frostyjhammer's Avatar
Re: F350 4X4 Brakes are Junk
Yes good point, I watched the Dealer do it so am sure they are correct.
You watched him use a torque wrench, or an air tool?
2005 F-350 6.0L TorqShift Crew Cab Short Box 4x4 with the "Lance Resort" in the bed.
frostyjhammer is offline
Old 07-24-2005, 05:29 PM   #17 (permalink)
Banned
FWIW.... we have some customers that are plagued with warped rotors but most rarely have any troubles.
Our local Fire Chief and his Deputy both drive near identical SuperDuties... the Chief can't go 3 months without a warped rotor and his deputy has never had a problem.... I'm trying to get them to swap trucks for a while...
GrampyJim is offline
Old 07-24-2005, 05:51 PM   #18 (permalink)
My Photos: (12)
Jim, It's 100% driving habits. I have had 3 superduties and NEVER even put pads on them! My 00 towed my 5er over 40K miles and had 117,000 when i sold it. I did have an Exhaust brake but i still say it's driving habits......... [img]/ubbthreads/images/graemlins/shrug.gif[/img]
95 F350 CC PSD 5SPD Gear Vendors O/D 4x4
92 Explorer Eddie Bauer
05 Expedition 4x4 5.4 3 valve.
Former trucks:
2003 F250 CC 4x4 6.0 HEADACHE! Traded before it blew!
89 F250 2wd 7.3 5spd with 256K when sold
94 F250 4X4 IDI Turbo 7.3 5 spd 160K when sold
95 F250 S/C 4x4 PSD 5 spd with 146K when sold
00 F250 C/C 4X4 PSD 6 Spd with 126K when sold (180K now)
mjstef is offline
Old 07-24-2005, 06:04 PM   #19 (permalink)
DecreasingDave's Avatar
I agree with the driving habits statement and so will the rest of you. Stop and think....how many times have you seen someone driving UPHILL with their brakelights on??
Far too many people are taught to drive with BOTH feet these days. Probably as a defense mechanism so they can "stop quicker" in an emergency. These are the folks that cause traffic accidents on the freeway 'cuz they jam on their brakes everytime the vehicle in front lets off the throttle (I almost said "gas". What was I thinking on a diesel site? [img]/ubbthreads/images/graemlins/blush.gif[/img])
Dave
2003 F-250, 4x4, CC, SB, 6.0 PSD w/Torqshift, Lariat, Toreadore Red/Arizona Beige
- Airaid intake
- MBRP Turbo-Back Exhaust
- Cross Over Fuel Line and 1/2 Banjo Bolt Mod
- Quadzilla Commander
- Zoodad Mod.
- Doorseal Mod.
- X-Springs and F-350 Blocks
- Full Traction 4.5" Hanger lift
- ProComp Add-A-Leaf and Velvet-Ride shackles
- BFG 35" All Terrains on Ultra Predator 17x10s (Hub-centric)
- Centramatics
- Timbrens
- Extang R/T Tonneau Cover
- EZ Down Tailgate Strut
- C.R. Laurence PowerSlider Rear Window
- Sirius Sat. Radio
- Polk Ex3 5x7s and 2 JL Audio 10w0s
driven by a 6 channel amp
- SCT from Innovative (WOW!!)
OH, and new heads from Ford along with an EGR Delete and Oil cooler at 195,000 miles.
DecreasingDave is offline
Old 07-24-2005, 08:39 PM   #20 (permalink)
The biggest cause of damaged rotors IMO is from driving down a big grade and then standing on the brake pedal at a stop light at the bottom. It puts a dent in the hot rotor and fuses brake pad material on one spot in the rotor. This leads to a pulsing brake pedal that some call "warp". When I go paragliding, (like hang gliding) we drive a load of people up a 5,000 ft mountain called Crestline, dump them off and then the truck gets driven down the mountain fast and there is a stop light at the base. If the driver stands on the brake pedal at the light after getting the brake rotors cherry red, then the "warp" will occur.
When I drive the truck down, I use lower gears to do engine braking, as do all of the experienced drivers. When a newbie drives the truck down, they might drive down in OD and drag the brake pedal all the way down and then stomp the brake pedal while waiting for the red light. The pressure from the brake caliper over the stationary hot disk causes the dent and deposits.
This happened to my F-150 2 times and then I learned; Dont keep the brake pedal stomped after a hard stop. Release the brake and put it in park if you have to until the light turns green. I have never warped a brake since I adopted this strategy.
2004 F-250 CC Lariat 6.0 PSD SRW SWB. Engine build date, 6-25-04. Prodigy brake controller, Husky floor liners, Tuff Skin spray-in liner, Fumoto drain. Pulling 2004 15 ft Toy Box with ultralights and dirtbikes. Other car, 05' Mazda Tribute.
Dieselhound is offline
Old 07-25-2005, 06:25 PM   #21 (permalink)
I agree 100% These trucks have very good brakes on them. However, if your foot is on the pedal all of the time, it will generate alot of heat, and warp the rotors. My '02 had 50K on it, and never a problem, my '05 has 9k on it, and it's OK- and I have made several emergency stops in both trucks. As a habit, though, I keep my nose off the bumper in front of me, and look over top of the cars so I can see brake lights, and decellerate gradually. No matter how good the brakes are on these trucks, the Neon in front of you with his brake lights on will stop faster than you will- and if he's a pedal-rider, you'll never know when it's coming.
Red 2002 F-350 XLT SRW 4x4 7.3L reg. cab 6-speed rubber floors traded at 50K for:
Red 2005 F-350 XLT SRW 4x4 6.0L reg. cab 6-speed rubber floors BFG 12.5x35 mud-terrains, no lift traded for:
Red 2008 F-350 XLT SRW 4x4 6.4 reg. cab 6-speed. Got carpet this time- audiophile stereo deletes rubber floors. BFG 12.5x35 mud terrains, no lift.
Traded at 45K for: Red 2011 F-350 XLT SRW 4x4 6.7L reg cab BFG 12.5x35 mud terrains, no lift. "optioned" out of- stick shift, rubber floors, audiophile stereo, fog lights, chrome step bars GRRRRR!
torino73 is offline
Old 07-25-2005, 08:50 PM   #22 (permalink)
my 2000 f350 duelly ate front brake rotors 4 set by 139000 and they were shot again when it was traded had them turned several times early on but never had a set of turned rotors last more than 10000 miles w/out warping was one of my pet peeves about this truck ( most of these miles were empty and not in mountains) not that I did'nt "drive it like I stole it' most of the time just my .02 [img]/ubbthreads/images/graemlins/shrug.gif[/img]
danxltsport new 08 lariat sc lb 6.4 ....... traded 05 black cc lb diesel xltsport black leather trailer tow....... traded 00 cc lb duelly diesel "lariat LE" w/banks stinger+
drmaland is offline
