F350 transmission slip 20005 - Diesel Forum - TheDieselStop.com
Old 03-27-2008, 09:09 AM   #1 (permalink)
I recently purchased a used F350 Superduty FX 4X4 with Auto transmission and 43,000 miles. Sometimes the transmission slips (allows engine to rev up slightly) a bit when it shifts from 3 to 4. 1 to 2, 2 to 3 are very precise. This happens generally when it is warmed up (hardly never when cold) and with no load as well as a load (although I think it happens more so with no load). Before I take it to a dealer and fork over my life savings, I wonder if anybody else has this issue or knows of the problem. Thanks much.
mysuperduty is offline
Old 03-27-2008, 09:12 AM   #2 (permalink)
Mark Kovalsky's Avatar
It's a fairly common problem. Sometimes a reflash of the PCM will cure it, sometimes it needs a new solenoid, but sometimes disconnecting both batteries for a few minutes will cure it.
Mark
Mark Kovalsky is offline
Old 03-27-2008, 09:15 AM   #3 (permalink)
Thanks Mark. It doesn't sound too serious.
Old 03-27-2008, 10:37 AM   #4 (permalink)
ebusa's Avatar
when it slips does your Tow Haul light flash?
-Evan
2005 F350 Crew Cab LB FX4 Lariat
5'' Tuff Country Lift
35'' Toyo MT on Race Line Renegade 20's
AFE Magnum Force Stage II CAI
CFM+ Black Powder Coated Intake Elbow
MBRP 4'' Exhaust Turbo back,
ARP Studs, Coolant Filter System
SCT X3 tuned by Innovative Diesel
ebusa is offline
Old 05-19-2008, 11:39 PM   #5 (permalink)
My tranny started to have a long pause when going from Drive to Reverse. Then it started slipping, even though its an automatic, when shifting gears. Then I got on the highway and it would not shift into 4th or 5th gear. Then the Tow Haul light keeping flashing. Is this a tranny solenoid issue or something else?
Thanks,
Tim
tar6day is offline
Old 05-20-2008, 07:44 AM   #6 (permalink)
Yes, it's something. Without knowing the code that was stored in the computer's memory when the tow/haul light flashed NOBODY knows what's wrong. Once the code is read then a proper diagnosis can start.
Mark
Old 12-01-2008, 09:25 PM   #7 (permalink)
My truck has the same problem same gear set. Thw tow light does not flash the PCM was just changed under warranty. My truck is a 06 250. I guess the next thing is the solenoids.
07powerstroke is offline
Old 12-14-2008, 08:26 AM   #8 (permalink)
I have a 2006 F250 and it is experiencing the same problems. How hard is it to replace the solenoids? I am going to change the tranny fluid soon and was wondering if I could do it them without much problem?
FXWGvette is offline
Old 12-15-2008, 12:27 AM   #9 (permalink)
JMAN0660's Avatar
my 06 does the same thing, solenoids replaced a few months back, but it is doing it again. maybe a pcm change. my t/h light does not flash either.
http://i1024.photobucket.com/albums/...AN8880/292.jpg
11 F250 Lariat CC SB Dark Blue Pearl FX4-
06 F250 XLT cc sb silver FX4-Traded
04 F250 XLT Sport CC SB 2WD Black/Black-SOLD
JMAN0660 is offline
Old 04-27-2009, 10:53 AM   #10 (permalink)
To date I have had the solenoids replaced, ECM reflashed/replaced, fluid change and the problem is still there. 3 weeks at ford with no answers other than We need to take it apart to clean it. only 400 miles left on warranty and has me looking for a replacement trans to have just in case it ever fails and give me a reason to build it up. Has anyone managed to get this problem fixed?
Old 04-27-2009, 10:57 AM   #11 (permalink)
Feedback Score: 2 reviews
Yeah... what he said
Disconnecting the batteries worked for me....thanks again Mark!
2006 F-350 XLT CC Lb. 5" Expandit exhaut, ACCUFAB elbow, AEM Brute Force Intake, 8+2" Fabtech 4 link, AMP Steps. BCP mod (Switch #4), Mega ZooDad. Infinity Kappa seperates and BasslinkII. DVD,MP3 & USB. Jack Rabbit. I LOVE MY DUHA! Road Armor Front bumper, need a new back.
BFG 37x12.50-18 KM2 Mud's onBALLISTIC Jesters
....and Mr. Avery's bumpers didn't work out...... he still has my money though, so one of us got a heck of a deal!!
DieselMank is offline
